Question about Sewing Machines
Feed Dogs, Thread Tangle
I have a Singer portable, mfgd in 1941 (Model AG008912).  After trying to sew over a very heavy seam, feed dogs started bumping against the chrome plate beneath the presser foot. (The plate the needle goes thru.)
Also, when trying to catch bobbin thread, the thread from the needle wraps around the bobbin housing (??-not the bobbin case, but the stationary housing the bobbin case snaps into.)  When the plate is removed, the feed dog moves freely, but the thread still tangles, as described.
I tried replacing the needle, removing the feed dog (couldn't), switching the direction of the threaded bobbin, cleaning & oiling moving parts.
Great if you could tell me how to fix this!  The little machine is a gem.
Thanks, Jeanette
  • 1 more comment
  • Anonymous Mar 12, 2014
    bobbin wont move to connect thread
  • Anonymous Mar 14, 2014
    As i took the plate off the bottom of the machine to check if something was missing, I found a padding of fiber around the gear. As I understand it, there is supposed to be a spring to make the feed dogs go back up. That part is missing.
  • Anonymous Mar 15, 2014
    thread gathers under seam, when you try to bring uptge needle won't move it kinda locks, won't move the needle.
  • 255 Answers
Hi Jeanette! You have a Singer Featherweight--the best sewing machine ever made! (Mine dates from 1950/51 and I wouldn't trade it for the world.) These beautiful, sturdy machines were designed to be easily repairable at home, but you'll need a copy of the Service Manual (get the Instruction manual too, if you don't have one.) Go to www.singer-featherweight.com and check out what they have available.
I had a similar problem (needle thread not catching the bobbin thread) and the problem was that I hadn't put the needle in correctly (flat side to the left). Also, I will occasionally get thread wrapped around the bobbin housing--sewing along just great and then everything comes to a screeching halt. I'm not sure why that happens, but I'm getting pretty good at taking the bobbin housing apart. The manual is pretty clear on how to do it. You can contact me direct at robbie1949@comcast.net for more information.
Thanks!
Robbie
Posted on Jan 10, 2008
Singer touch tronic 2000 feed dog will not advance fabric
Confirm the feed dogs are raised. Make sure the feed dog teeth, area under the needle plate and the bobbin area are clean of any debris, thread, or buildup. Some machines also have a presser foot pressure adjustment that increases the pressure the presser foot applies to the feed dogs. The feed dogs could be worn (never run the sewing machine without fabric between the presser foot & feed dogs).
https://www.manualslib.com/manual/508740/Singer-Athena-2000.html
Or, the machine has not had a thorough cleaning and oiling recently and the feed dogs are sticking from old oil.
Wheel on right side that controls the needle up and down is very tight...
Jul 30, 2017 | Singer Sewing Machines
Hi, Janome 124 - top thread picks up the bobbin thread, motor sounds good. Th feed dogs won't pull fabric (or paper) thru the machine - dogs don't stick up much above the plate. Help please! Jan
Remove the needle plate and clean the feed dogs with a brush...remove any lint and bits of thread.
A couple of drops of sewing machine oil might help to loosen the feed dogs up. (maybe let the oil seep in and then turn the handwheel towards yourself to help things along.
One other thought:
If your machine has feed dog lowering capability you might want to move that lever/switch back and forth a couple of times.
The feed dogs might not appear to raise or lower, but some machines will only re-engage raised feed dogs when the machine starts to stitch.
Also...verify that the presser foot tension isn't too strong/heavy...and temporarily try using a longer stitch length setting.
Mar 19, 2017 | Janome Sewing Machines
Singer model no 9022 feeder feet does not move material thread bunges under material
Check that the stitch length is set high enough that the feed dogs will actually advance the fabric. Setting the stitch length too low will cause the machine to basically sew in place.
Also, check that the feed dogs have not been "dropped" to allow darning or free motion quilting. Dropping the feed dogs lowers them so they will not rise above the needleplate and will not grip nor move the fabric.
If your machine is mechanical (not computerized), it may need a good cleaning and oiling. If the old oil has solidified, it could be preventing the feed dogs from moving like they should.
Aug 27, 2016 | Singer Sewing Machines
Thread continues to tangle on Ellure Plus even after changing out needle, bobbin, etc. Noticed that a small 'bar' was across front of feed dogs-pushed this back to the left but problem contin
Your post made me laugh with the funny bone remark. :) I'm glad you found and posted a solution to your own problem. Bravo!
Happy sewing.
Sep 15, 2012 | Baby Lock Ellure
When i start to sew on my Janome sewing machine model Sewist 525S it does a couple of stitches on any stitch type then bangs then sews then bangs then stops. I look to see the problem and the bobbin and...
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Sep 25, 2010 | Brother LS-1217 Mechanical Sewing Machine
Thread bunchingup on bottom of material on singer
Here are some solutions to try.
* Re-thread your machine
It may be threaded incorrectly.
* Raise your feed dogs If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Dec 28, 2009 | Sewing Machines
Every time i sew something the bottom thread keeps clumping up
Here are a couple of things to try.
Re-thread your machine. It may be threaded incorrectly.
Raise your feed dogs. If your machine has this feature.
When you start to sew a seam, hold on the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting hung up.
I hope this helps you out.
Sep 18, 2009 | Singer HD-110 Mechanical Sewing Machine
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Singer model ce100 does not sew with pedal
Check your feed dogs. On the front, left at the bottom is a manaul switch. If you push it to the right it drops the feed dogs, for embroidery and when you push it left it lift the feed dogs. Just remember to turn the handwheel towards you after switching it to the left, until you hear a clicking sound and the feed dogs engage. Hope this solves your problem.
Nov 06, 2008 | Sewing Machines
Sewing Machines Logo
446 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
