Question about Arctic Cat 2012 Bearcat Z1 XT
Arctic cat bearcat trnmission wont engage
I shifted from forward to reverse and now it wont engage inot either forward or reverse. both clutches just spin on the belt. the engine runs fine....its a gearing issue
3 Suggested Answers
5keepers541
  • 3425 Answers
SOURCE: 2009 arctic cat 4x4 auto 500
Unless you have a few special tools...flywheel remover, case splitters, crank installer, clutch tool, factory service manual.etc.. TAKE it to a professional!!
Posted on Aug 10, 2014
5keepers541
  • 3425 Answers
SOURCE: 2004 arctic cat 500 4x4 starter turns doesnt engage starts with pull cord
1. Never jump start an ATV, Motorcycle, UTV..etc from a automobile! The amperage is TOO high, you can damage a lot of expensive electrical components!! ..very quickly!
You cannot home trouble shoot without a new battery or fully charged battery with good solid clean connections!!
2. Have the battery tested or simply buy a GOOD new one!
3. Does the starter spin at all? Is there a clicking noise when you push the start button? No - solenoid is bad(?) . you can check this by jumping the two large connectors on the solenoid... A good screwdriver works well...(CAREFUL - SPARKS WILL FLY!) If the starter works while jumping, the solenoid is bad - just replace it (disconnect battery while replacing).
4. If the start spins while "jumping" and nothing happens the starter may need rebuilding if the new battery/fully charged battery/jumping solenoid does not expose/solve the problem.
Do this and repost.
Steve
Posted on Mar 11, 2016
Backfires while in reverse
Hi, Anonymous and the usual suspects are:
1. A severely drained battery.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/2014+arctic+cat+bearcat+570
Feb 20, 2015 | 2014 Arctic Cat Bearcat 570
1998 arctic cat 300..... hard to shift you have to
I do not know much if anything about an arctic cat but if you have a shifter you have some kind of a transmission and if you need to get it into gear or neutral but cannot do so without rocking the machine or the shifter back and forth a slipping clutch would not likely have anything to do with the problem. You likely should not be trying to shift gears with the clutch engaged and the clutch normally should be FULLY slipping ie completely disengaged when you are shifting. It sounds like you could have sticking shifter linkage parts, worn shifter parts or internal transmission parts, bent shifter forks, worn shifter cam or drum grooves or shifter fork pins or other worn parts or maybe even low or no transmission fluid.
Oct 05, 2014 | Cars & Trucks
Cdi wiring diagram FOR ARCTIC CAT 250 4X4
Hi, Anonymous I am sorry you can't find the first and best tool you ever bought for your Arctic Cat but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/arctic+cat+250+4x4
May 28, 2014 | 2014 Arctic Cat Bearcat 570
Has trouble shifting into reverse
LInkage may be out of adjustment. To check,put in forward position,loosen shifting rod jamb nuts then turn the rod until you have just a touch of play. This will allow the reverse to be completely ingaged when shifted.
May 06, 2014 | Arctic Cat 2012 T 570
No reverse
Adjustment between the shift lever and gearbox
here are the service manuals for all Arctic Cat ATVs
Parts House Lawn Mower Parts and Chain Saw Trimmer Parts
Mar 25, 2014 | Arctic Cat ATVs
Foward/reverse linkage adjustment
Most of the time people over tighten the shifter linkage.I have found that if you leave just a hair slack in the rod while in the forward position it will shift fine.
Mar 14, 2014 | Arctic Cat Sabercat 600 EFI LX Winter...
Arctic cat zr900
Open your chain case. Youll probably find your chain laying in the bottom.
Mar 03, 2014 | Arctic Cat 2008 CrossFire 8
Clutch does not engage at low rpm and causes machine to lunge severely
Sounds like the clutch weights are sticking
here are the service manuals for all Arctic cat ATVs
Mar 01, 2014 | Arctic Cat 2009 400 H1 TRV 4x4
My 07 f8 keeps popping out of forward gear when I let off the throttle
could be a problem with adjustment on the shifter it has electric shift but its still a mechanical gear box
Jan 19, 2014 | Arctic Cat 2009 F8 EFI Sno Pro
Arctic Cat 2012 Bearcat Z1 XT Logo
Top Arctic Cat Winter Sports Experts
ray gallant
 steve
steve
rhodesworks
Are you an Arctic Cat Winter Sport Expert? Answer questions, earn points and help others
