Sharp developer leaking in imaging unit developer leaking ini maging unit
2 Suggested Answers
  • 100 Answers
SOURCE: developer leaking in imaging unit
yep!
just cleaning all the contract plates and groundings of the process unit (the drum unit and the developing unit).
Posted on Jun 14, 2010
Ar5516 developer spilling out
hi 1 might be developer is very poor quality (generic) 2 check biasing in sharp normally it,s developer issuer and also in this model if u turn mag roller while replacing or just turn and re install in your machine will spill developer
Feb 24, 2014 | Sharp AR-M205 Copier
My sharp ara5516 is showing F2 what should i do?
ur developer shd be empty.Pls buy a new developer and fill it in the developer unit
Oct 09, 2011 | Sharp AR-5316 Advanced Digital Imager...
How to clear u2-40 error for sharp ar m276
This is error for Error in MCU-CRUM chip communication. Probably because of developer unit has bad contact.
Try to reconnect developing unit and then turn on the copier. If problem persist call service!
Hope that helps!
Sep 06, 2011 | Sharp AR-5316 Advanced Digital Imager...
Developer leaking in imaging unit
yep!
Jun 02, 2010 | Panasonic DP-8016P Copier
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Installer of sharp AR-5316
Remove the screws marked and all tapes around the copier, open the tray and remove the screw supporting it. Open the front cover and unscrew the green screw holding developer unit and pullout the unit. Open the 3 screws and pour the developer evenly and return it back. Remove the seals on the toner cartridge and insert it. Power on the copier and make a copy.
Nov 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
How to chande the developer
you take the drum out, then unscrew the developer (it should be a greenish screw), it should slide out, empty the developer out, take bag of new developer shake it up real good... then pour evenly into developer unit, while turning the mag roller... reinstall..
Nov 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Sharp copier ar-5316
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
Jan 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
16 people viewed this question
k24674
