Question about Belkin Basic Wireless Router
Belkin Security Hi I have my N150 wireless router hooked to my neighbors router via LAN hooked up as an access point and in a window so I can get wifi next door. Their router has a snooper setting in it... Is my surfing private and if not can I make it private?
  • Belkin Master
  • 7,733 Answers
Yes is private unlesss they are hackers
Posted on Jun 06, 2014
2 Suggested Answers
AlmostBob
  • 550 Answers
SOURCE: WIFI PHONE NOT RECOGNISING BELKIN WIRELSS ROUTER
the router is not configured by default as an access point.
to use the phone the router must be configured as an access point, which is more than disabling security, nat and dhcp must be removed..
page 53 of the user manual describes the proceedure.
online the manual is here
http://belkin.httpsvc.vitalstreamcdn.com/belkin_vitalstream_com/support/dl/p75170-d_f5d8231-4_man.pdf
Posted on Jul 12, 2008
Belkin Security
Your surfing is only private when you're using SSL (https) connections between your browser and the website[s], no matter what route[s] your internet connection takes.
Feb 16, 2014 | Belkin Basic Wireless Router
How to use router without using wifi in belkin n150
This model Belkin wireless router has 4 LAN ports so you can connect a LAN cable from this wireless router to your computer.
I suggest you disable the wireless in the router so no one can access your network and Internet. If you cannot disable the wireless then you can setup WPA2 encryption to secure your wireless network or just remove the aerial off the wireless router.
Mar 05, 2013 | NetGear WGR614 54 Mbps Wireless Router -...
I cannot connect to my belkin connect n150 router after enabling it as an access point. Green light shows up on router and wireless network shows up but no connection when clicked. I cant connect via
Pretty sure you have to have at least one router in gateway mode to connect to the internet. An AP allows wireless devices to connect to a wired segment. The same as a router in gateway mode. AP mode has the benefit of extending a networks wireless range. If this is your only device leave it in gateway mode.
Jan 28, 2013 | Belkin Basic Wireless Router
I purchased a belkin n150 wireless router. I have no problems with it at all. However I had my phone connected via wifi and my wife tried to get on the lap top and it wouldn't connect. So my question, is...
Your router should broadcast 255 IP addresses as long as DHCP setting is enabled, which it is by default.
Here is the manual:
http://cache-www.belkin.com/support/dl/MAN_F7D5301_v1_8820-00696_Connect_N150_Router.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 01, 2011 | Belkin Computers & Internet
My computer no longer recognizes my belkin router as a wifi access point. It's as if it stopped working. Any ideas?
Belkin products are all built from Refurbished materials. It is entirely possible that your wireless access point has simply stopped working. Try going in and restarting the wireless function on your router, you'll need to be plugged directly into the router via an Ethernet cable to do this though, if the wireless is not working.
May 17, 2010 | Belkin (F5D7230-4) Router (587009)
I have Belkin n150 but the security button turn off
When the Security light on your Belkin n150 is off, it means that the wireless security is off.
The WPS button is used to setup the wireless security. To enable security, you will need to determine which standard you want to use. To access the security settings follow the steps below:
1. In the address bar of your Internet browser, type "192.168.2.1". Then press the "Enter" key.
2. It will prompt for a password to access the Router’s Web-Based Advanced User Interface. By default the password is blank.
3. Click "Security" on the "Wireless: tab.
Nov 28, 2009 | Belkin (F5D5231-4) Router
Router problem
Connect a computer to any one of the four LAN ports of the Belkin wireless router. DO NOT use a wireless connection, use a cable.
Open your web browser and type the IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
Click Security under Wireless menu.
Under Security, Select 64 bit WEP (or 128 bit WEP).
Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you. Example (0102030405060708090a0b0c)
Apply the settings.
Please write down the key – You will need it later to configure your and your neighbors wireless computers with the same key.
Remember to set an admin password before you close down, other vice anyone can access you router and change the setup and admin password.
/regards
Teis
Dec 31, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Jun 13, 2008 | Belkin (F5D5231-4) Router
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
Belkin Basic Wireless Router Logo
79 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
