Question about Samsonite travel sentry 3 dial combination locking luggage strap,tsa
Samsonite TSA LUGGAGE strap lock instructions
How do I set my code on TSA LUGGAGE STRAP ? Strap has lever on rear marked A B in L shaped grove. Thank you
SOURCE: I HAVE THE TSA COMBINATION LOCK ON A SAMSONITE GRAVITON G LUX
I can't answer the problem - but am interested as we had an identical failure on holiday in South Africa. We had to force the case open as the lock and the mechanism seemed to have come adrift in that when moving the lever with the correct combination - the case neither opened or closed. I'm sending it back to Samsonite under warranty to hopefully get it repaired/replaced. I rang the UK number listed on the Samsonite website. Bit disappointed as Samsonite should be more reliable - particularly given the price of the case, at £295, isn't exactly cheap.
Posted on Oct 11, 2009
Obertelli
  • 3006 Answers
SOURCE: TSA locked our TSA002 lock on our samsonite bag
No. That's part of the whole purpose of TSA passkeys; they're held securely and only at ports. If it were easy for anyone else to get hold of them the locks which are TSA approved would become pointless.
You only have three options if you do not want to return to the airport:-
1. Get a locksmith;
2. Cut the lock off/drill it out;
3. If your lock is usually key operated (not a combination) then there will be a number next to the lock barrel (not the TSA number, that just tells the TSA which of their passkeys to use). A Samsonite dealer can order the correct key for you using the number and some even keep them in stock.
Posted on Oct 23, 2009
SOURCE: Problems to open a Samsonite TSA 007 lock on suitcase
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
Posted on Dec 04, 2009
SOURCE: HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE
I forgot my locker combination and my luggage is locked.How can I open it??
Posted on May 18, 2011
  • 136 Answers
SOURCE: I just purchased a piece
Samsonite have a lifetime warranty, so taking the luggage into one of their stores will endeavour to replace it for you.
Posted on Jul 26, 2011
How to Reset t tsa lock on a Mia toro luggage
How do I set a Mia Toro luggage lock? - Fixya
www.fixya.com/support/t26581106-set_mia_toro_luggage_lock
Apr 30, 2017 - Release the reset button after you set the numbers to the new combination. ... If you still can't open the lock, contact Samsonite Customer Service at .... TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to ...
Amazon.com: Questions And Answers: How do you set the luggage ...
https://www.amazon.com/forum/-/Tx1WRFLRQIYMJR0/ref=ask_ql_ql_al_hza?asin... Jun 20, 2016 - Mia Toro Metallo Composite Hardside 26 Inch Spinner, Blue, One Size ... The factory setting is 000 make sure lock is set to this press the reset ...
How to Set A Luggage Lock / LuggageFactory.com - The Travel ...
https://www.luggagefactory.com > ... > How to Set A Luggage Lock Sep 10, 2014 - TUMI: TSA Combination Padlock: Make sure the combination is set back to (0-0-0), the factory setting if new, or the existing combination if it has been used already. Make sure the mechanism is unlocked. Press and hold the button on the side of the lock. Select a new combination.
how to Reset tsa lock on Mia toro luggage Google Search
Jul 26, 2017 | Locks & Locksmithing
Samsonite luggage
That keyhole is so that TSA can open that lock and take it off. They only time they would do that is if your are flying on a plane and the bag is in checked luggage and it needs to be searched.
May 01, 2014 | Samsonite Large Dial Travel Sentry Combo...
Tsa lock instructions
I have forgotten my lock code on a task lock on a Tripp suitcase anybody know how to resolve the problem
Dec 06, 2013 | Samsonite Silhouette 11 Hardside Spinner
Eminent luggage lock
TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to change it to YOUR personal number)
Put the code numbers to '000'
Take the lock levers OFF the lock
Push the round opening button UPWARDS.
IMPORTANT :
KEEP holding the button UP until you have changed the numbers
Change the TSA code numbers to what YOU want
Release the round opening button
Now your case combo lock numbers have been changed.
To lock the case put the two lock levers into the holes, spin the numbers and your case will be locked.
To UNLOCK the TSA code spin the numbers to YOUR lock code, push the lock button UP and, hey presto, your case will open.
If you forget your NEW lock number you will NEED to go through ALL the numbers, starting at '000' to '999', to be able to open the lock/case.
REMEMBER to PUSH the ROUND OPENING button UPWARDS on EVERY number change.
Only THEN, when it finds YOUR correct three digit number, will it eventually open the suitcase/luggage/baggage.
Good luck
Aug 31, 2013 | Luggage & Travel
How to release rear seat when strap brokes in a 1999 chevy tahoe
If you want to fold down the rear seat when the strap is broken there is a solution to help you out,please follow the instructions given below;
1.Take a flashlight and look down into the square recess where the two seat belt locks come up through the backseat.
2.Besides the straps you will see two pieces of metal, one in "J" shaped and inside of the "J" you will see another piece right in the middle.
3. Take a screw drive and press down on the one that's inside of the "J" while you are pulling up on the strap. The seats will lift out.
That's it,problem solved,so funny you just will have to do that each time.
Thank you for using fixya.
Mar 17, 2011 | 1999 Chevrolet Tahoe
HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
I have a somesonite 30in hardshell , uprite about 20 yrs old. has 2 key locks, as well as combanation center lock. question how can i set these locks so that, they are TSA excessable locks??? PLS. Help ...
You can have the locks changed but, that will cost almost as much as new luggage. They will have to be kept unlocked and a TSA strap will be needed around the suitcase.
Oct 07, 2010 | Samsonite Silhouette 11 Hardside Spinner
Nov 08, 2009 | Samsonite Tripod
Samsonite travel sentry 3 dial combination locking luggage strap,tsa Logo
152 people viewed this question
Top Samsonite Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Samsonite Lock and Locksmithing Expert? Answer questions, earn points and help others
