Question about Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM0497000
Generator will not start but will backfire - Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM0497000
Black max generator hard start backfires ,if it does start doesn't stay running
will be motor issues
start with carby and adustments
spark issues
governor
valve clearance
Black Max Generator Parts mastertoolrepair com
Oct 28, 2016 | Electrical Supplies
Honda gx160 petrol generator,gets very hot on the muffler,then starts to backfire and flames come out of the exhaust on the muffler
You need to get the exhaust away from the generator (heat shield) because it is getting to hot and this will cause it to backfire
Dec 31, 2014 | Motorcycles
Plug fouls out turns black and starts to backfire
What does the oil look and smell like? Also what conditions is it been ran in lately, and what fuel are you running?
Sep 12, 2014 | Coleman Powermate Premium Plus 6250W...
Yamaha ef2800 backfires and will not start
check the KEY on the fly wheel at the engine shaft.try youtube
Mar 03, 2013 | Yamaha EF2400iS Portable Generator
Honda generator starts, runs, then stalls and backfires
Honda makes quite good gasoline motors. I doubt it is a valve timing issue but it might be a burned valve or a valve adjustment issue. What does after a while mean? A couple of minutes or 4 hours? Is it running for just a short while and then stops or it runs well for a long time and then stops?
Aug 01, 2012 | Honda Generator Eb4000x Eb5000x Eb6500x...
I have a new Kohler 12kw res generator on propane - backfiring
Is the outside air temp cold. These generators will backfire if it is real cold and if the propane pressure is low. It is suppose to be 11 to 12 inches of water colume at the generator fuel input. drygwals
Feb 18, 2010 | Kohler 12 kW Emergency Power System -...
Generator hard to start and backfiring
Sound like you've done things in the correct order, tecumseh's are notorious for carb problems if you let as sit in them. Backfiring is timing related (flywheel key) or valve problems. I would take a closer look at the exhaust valve I don't believe it is closing all the way.
Mar 16, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM0497000 Logo
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
