Question about Acer AL712 17" LCD Monitor
Acer AL712 17" LCD Monitor no power - Acer AL712 17" LCD Monitor
Ic number of acer lcd monitor v193hqv?
Hi guys the pwm ic number in acer v193hqv is TEA 1530 AP.......
Aug 05, 2014 | Acer Computers & Internet
Acer AL1711 17" LCD Monitor showing white screen
A white screen indicates the power supply board is not putting out the correct voltages to properly power the monitor, just the back light. This type of issue is caused by a failure of the filter capacitors on the power board. You can rebuild your power supply board and bring the monitor back to life by just replacing the the bad capacitors. The problem is that model the Acer AL1711 could come with 1 of 4 different power supply boards install depending and the date manufacturer and supply on hand. If you want to repair the monitor if you could open the unit and get either the model number of the power supply board or send a picture of the board to me I will be glad to help you repair the unit and get it back up and running. You can contact me to send the information at tech@ccl-la.com
Nov 30, 2012 | Acer AL1711 17" LCD Monitor
Acer Monitor Lcd 22in B243w Monitor goes black and shuts off
try to turn on again the power button or in the remote then if did not work or power on.Your monitor have problem in power supply.need a technician for repair.If the power on then check the timer settings.
Oct 05, 2010 | Acer B243w 22" LCD Monitor
What can i do if my acer lcd monitor haven't power
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 19, 2010 | Acer AL1917W LCD Monitor
How do I get sound from the Acer LCD monitor?
connect stereo audio cable from monitor to pc audio output
Mar 27, 2010 | Acer 22" X223w LCD Monitor
ACER LCD monitor has no power.
It is probably the inverter which powers the backlight. It should say inverter right on it.
Feb 08, 2010 | Acer AL1916B 19" LCD Monitor
Power on , then goes off in a seconds
Hi:
Unfortunately, that symptom usually is caused by a failure in the power supply board , that is internally mounted inside your LCD monitor. It is possibly repairable, but usually it is about as cheap to get a new monitor.
Dec 10, 2009 | Acer AL1715 17" LCD Monitor
Power cord
This one should do the trick.
http://insidecomputer.stores.yahoo.net/ac-adapter-for-acer-al1714-al1714b19volt-l1714171419.html
Feb 09, 2009 | Computers & Internet
Acer AL712 17" LCD Monitor Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
