Question about Matrix MX18002 1800 Watt 2 Channel Amplifier
Matrix 1800 watt amp in protection mode
Protetion mode
    Top Expert:
  • Matrix Master
  • 74,243 Answers
Check for shorted component/s at its audio output section circuit. Contact any service technician. Gopakumar Gopalan Google
Posted on Feb 17, 2014
I have performance tecknique amp icmb 781 1800 watt 2ch It turns on but as I crank up the volume it gos into protection mode anybody help.
improper wiring. familiarize yourself with paralleled versus serial wiring and ohms law. otherwise, ensure that there is proper clearance for the amp to cool.
Aug 17, 2014 | Car Audio & Video
I have a dub2502 amp with the red protection light on and will not go off. The amp is a 1100 watt peak amp @ 4 ohms and my sub is an Audiobahn 1100 watt peak, 4 ohm. wired perfectly. so how do I fix the...
The unit will need to be repaired by a technician. Most likely you have a bad transistor that is causing the protect mode to turn on. The only way to get the protect mode to turn off is to remove the bad part.
May 04, 2010 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
My 1800 watt kenwood keeps goin into protect mode as soon as i turn it on.. why?
disconnect load (speakers), check if it still goes in to protection if so then your output stage might be faulty
Apr 17, 2010 | Kenwood KAC-9152D Car Audio Amplifier
The red light is on the amp
protection, protetion, protection. fault on amp
Apr 15, 2010 | AudioBahn A2200HCT Car Audio Amplifier
I have a 1800 watt amp but the red light is on but it dose sound like the bass works but not it its prime
the red light is for power in protect mode it should be orange and it will not emmit sound if you think you should have better sounding bass or more bass you can try to play with the gains on the amp or possibly if you have the negative or positive hooked up wrong from a speaker to the amp this will cause the bass to be lower and somewhat distorted double check your positive and negative wires from the speaker to the amp and make sure they are correct
Feb 28, 2010 | Kenwood KAC-9152D Car Audio Amplifier
Amp goes into protect mode after volume is turned up
Not enough juice, check the power and ground connections, another possibility is to have dc in the input, try to use in line filter available from radio shack to cut the dc, also test the with one speaker at the time, you could have a bad speaker (shorted) too.
Apr 08, 2009 | Pyle PLA4240 Car Audio Amplifier
2006 12" Kicker L7 4 ohm
first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Prower acustic amp in protect mode
1) Make sure the amp is properly connected to +12V power source. 2) Make sure the amp is grounded well, directly to metal - if you have a voltmeter, an easy way to check the first two is to see if there are 12 volts across the power and ground wires. 3) Make sure the speaker output wires aren't touching each other. If none of these are the case, there is an internal problem with the amp and it should be serviced or replaced.
Sep 18, 2007 | Car Audio & Video
Open Questions:
See all Matrix MX18002 1800 Watt 2 Channel Amplifier Questions
Matrix MX18002 1800 Watt 2 Channel Amplifier Logo
35 people viewed this question
Top Matrix Televison & Video Experts
Electro Med Services...
Are you a Matrix Televison and Video Expert? Answer questions, earn points and help others
