Question about Precor Exercise & Fitness
Stuck on incline error code 45 - Precor Exercise & Fitness
  • Precor Master
  • 914 Answers
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Posted on Jul 17, 2014
Error code E6 (XQB70-DB14)
An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
  1. Turn the power OFF, wait 5-seconds and turn back ON.
  2. Get into test mode and enter through the I/O testing step. This screen will display the potentiometer value of the incline motor. Different models will have different values. Check to see if the running deck is raised to high incline level or if it is at the low level. If the running deck is at a low position press the incline up button. This will cause the incline motor to raise the running deck up. When the deck gets to a mid-level position, press the incline up button a second time to stop the deck. If the running deck is in a high incline position, use the incline down button to adjust the deck to a mid-level position.
  3. Once the unit is in the mid-level position, power the treadmill off for 5-seconds and then power it back ON.
  4. Start the treadmill.
  5. Once the treadmill starts the running deck will move to the level 0 position. If this does not resolve the issue or it will not adjust please contact customer service.
24 Hour Locksmith Local Locksmith Locksmith Cheektowaga Ny 716 710 7399...
Aug 07, 2016 | Heating & Cooling
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
Error code AC-6
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION ...ERROR 1-2: AC SERVO ERROR - MOTOR IS OVERHEATING (SPEED RESTRICTED ... error codes listed by category: treadmills, bikes, elliptical trainers.
[PDF]Precor Error Codes
I have a Horizon HTM 3000 treadmill which is stuck on max incline and require the incline calibration code.
hi, i also have problem with my horizon htm 3000, incline motor stuck.
did anyone know where to buy brand new incline motor?
and how much it will cost?
Nov 16, 2013 | Exercise & Fitness
E2 error lift error
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
You have posted this question in the Stair Climber section, but the error you are listing is a treadmill error code. The following information should help.
Probable Cause A) Incline control error.
B) Insufficient power source.
C) User exceeds weight limit.
D) Unit will not lift.
E) Unit thinks it is always at 0% incline and only lifts up.
F) 3 amp circuit breaker has tripped.
G) CPU board has stuck relay.
H) Lift motor is faulty.
Corrective Action A) Access the incline manual mode in diagnostics by pressing 9, 1, 9, ENTER and then pressing HILL program key. Incline the unit with two people on the unit. B) Ensure treadmill is connected to a dedicated 120V, 20 Amp circuit.
C) Advise user of unit's weight limit of 300lbs (137kg).
D) Perform the lift test procedure by pressing 9, 1, 9, ENTER and then pressing HILL program key.
E) Inspect the home switch for smooth operation and inspect the wiring of the home switch for damage or poor connections. Inspect the lift motor cable connections and for the presence of the suppressor board (should only be 1).
F) Test the circuit breakers and replace if necessary.
G) Replace the CPU board.
H) Replace the lift motor.
LifeFitness 9500 Treadmill Lift Control Error
Jul 31, 2013 | Life Fitness Exercise & Fitness
I have an Insight DK614 Tredmill that will not run. It displays an error message "E6" and the running deck will not lower. The motor is still running albeit at a much lower rate. No movement...
E6 or E7 An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
  1. Turn the power OFF, wait for 5-seconds and turn back ON.
Also, note that not all models will have the ability to adjust the incline motor. If the adjustment procedure is not found in the Owner's Manual then contact customer service. Treadmill Error Codes Troubleshooting
Oct 26, 2017 | Exercise & Fitness
Wheel alingment specs for toyota land cruiser
Camber
Left−right error
1°00’ ± 45'
Caster
Left−right error
3°00’ ± 1°
Steering axis inclination 13°00’ ± 45’
Camber, caster and steering axis inclination are not adjustable.
If measurements are not within the specification, inspect the
suspension parts for damaged and/or worn out parts and replace
them as necessary.
INSPECT TOE−IN
Toe−in
(0.08 ± 0.08 in.
This is the only Land Cruiser Specs I could find, hope it helps
Apr 09, 2009 | 1996 Toyota Land Cruiser
Exercise & Fitness Logo
129 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
