Question about As Seen On TV Micro Touch Nasal/Ear Trimmer
Micro touch green razon head fell apart - As Seen On TV Micro Touch Nasal/Ear Trimmer
How do I repair micro sd slot
I would remove the old socket from the laptop mother board with hot air or infra red heating and source a replacement to fit back to the mother board. I am highly skilled in reworking PCBoards and if the track is not damaged have no trouble.
Oct 07, 2014 | Computers & Internet
How do i get to the vacum hose to goes inside the wheel well (or so it seems to) on the drivers side.ii
new peice [plastic] vac line duct taped to coat hanger.ream old line out.phillips screwdriver.insert hanger and pull through from inside.splice to old ones.if you dont want to pull a/c control head.small rubber line 1/2inch splice.
Aug 25, 2014 | Cars & Trucks
How does the hansgrohe hand held shower head md # 17850831 snaps together
The 17850 is not designed to be taken apart and put back together. They are pressed together in the factory. If it was dropped and came apart it is most likely broken beyond repair. If you need further help fell free to contact Hansgrohe Tech 1-800-334-0455.
Dec 08, 2012 | Hansgrohe Carlton 17850831 Polished Nickel...
My Igia AT7352 micro hair trimmer fell and came apart. I need a drawing to show me how to reassemble it please
mcdevito75 here, You try online at Igia.com or you can try a drugstore to re-assemble the shaver for you if they can, some parts may be broken.
Jun 30, 2010 | Igia AT7352
A/C unit fell out window, pulled out wiring
You should have two terminals marked L1 L2 That is wherer the two power wires go. The green is connected to ground. Rsuty
Jun 04, 2009 | Sharp AF-S80FX 8,000 BTU Comfort Touch Air...
My shaver head broke! PLEASE HELP ME!
I just fixed my husband's razor. I took everything out and washed it all. Then I took the three things that touch the skin and put them in the three holes so that they fit comfortably. Then I put the sharp parts inside those thin parts. The I took the gray thing with three holes and snapped the little brown thing to it and turned the arrows on the brown thing so it snapped it securely to the things with holes. Then I put the head onto the handle by sliding the hook into it's hole, than brought the head onto the handle and snapped it shut. It fell apart the first time I tried it but I put it all back together and after that it worked like a charm.
May 08, 2008 | Norelco 8170XLCC Electric Shaver
As Seen On TV Micro Touch Nasal/Ear Trimmer Logo
37 people viewed this question
Top As Seen On TV Health & Beauty Experts
Tom Chichester
Are you an As Seen On TV Health and Beauty Expert? Answer questions, earn points and help others
