Question about Canon PIXMA MP495 InkJet Printer
Cartridge slamming to side of printer
When I turn the printer on the cartridge case slams to the side of the printer and does not return to the center position. I get a flashing on/off light and alarm mode. The error message is P02. The paper path is clear and could not find anything that might have fallen in the paper shute that would interfere and cause a paper error. Any assistance is greatly appreciated.
SOURCE: Alarm light on, Display indicates error message: Check Ink U150 M
I added my post today with the same problem, and thought I'd share what I since learned. Apparently this "Alarm light/U150" is common with several Canon models. The U150 indicates a faulty electronic chip (on the ink cartridge). Though I tried cleaning the sensor with isopropyl alcohol, and also tried removing all the cartridges, unplugging the printer for 45 seconds, then reconnecting,etc. as I had read might help, I still had the same frustrating problem. Contacting Canon was the solution that worked for me. First I emailed, but decided I didn't want to wait for their response. A call to Canon Tech Support (1-800-385-2155) was quick and painless. They will more than likely send you a new cartridge, but you'll need to have your serial # & date of purchase handy.
Posted on Dec 11, 2007
geemarie
  • 876 Answers
SOURCE: Error 5100 for canon mp530
I would do all of the following and see if yo can clear this code. It is not on any Canon list of possible codes, so I have no idea what it means., but let's do this:
Turn off the printer and unplug it.
Remove the print cartridges. Look at them, are they leak free? Look into the cartridge holders. Are they clean?. Dried ink or blobs should be cleaned off with a little alcohol and a qtip.
Are the little wire holders bent or broken? Do they look exactly the same?
Turn the printer back on reinstall the cartridges.Check in your printer preferences/services and clean your cartridges.
Now turn it off again and unplug it. Open the paper jam door and gently push the paper roller forward until it clicks. At the same time, look for even the tiniest scrap of anything in there.
Close the paper jam door and plug your printer back in. Restart your computer.
If the problem is not solved. You may need to reinstall the printer. Do You have your original disc? Be sure to do a clean install. ( Turn off all running programs in the lower right corner including your virus control. Also go to Toolbar>tools>internet options>general>and delete all you cookies and temporary internet files.) Turn off and unplug your printer.
Reinstall the software. When it is finished if it has not told you to plug your print back in do so now. Restart your computer and turn your printer on.
I hope this helps. Good luck to you.
Posted on Aug 24, 2008
SOURCE: Canon MX310 paper jam
"Gclanton" had it right.
I had the same problem today. I ended up taking a piece of paper and from the back side started lightly forcing the paper in the back slot. I had the top cover open where you replace the ink cartridges. Towards the back you can see the paper start coming into the printer next to some rollers. On mine there was a small black switch about an inch from the right in the middle of the plastic piece above the rollers. Once I started pushing this paper in I could see this switch was stuck in the down position. After several minutes of pushing the paper in and out the switch moved up and out of the paper path. I then pulled out the paper and hit the ok button and it came on line. This may work better with a piece of card stock.
That switch is the issue.  I ended up finding an object lodged against the switch.  Needed a flashlight, plastic giftcard and a tweezers to get it out.  Works great now.
Posted on Jan 05, 2009
dejoebad
  • 4 Answers
SOURCE: In canon pixma ip1700 Alarm light orange flashes 15 times
i've post a solution here in fixya. same condition with u. just do a temporary reset. it explained there. c ya......
Posted on Jun 03, 2009
SOURCE: /*mp250 error code p03 alarm
manual replacing the print cartridges --> try rotating the left white gear back and forward releasing the mechanical lock of the print head it is a small plastic peace in the back of the of the head ...replace the cartridge as you need ...
about the error p03 it indicates a mechanical jam (head carriage - paper jem - paper pickup mechanizm - head cleaning mechanizm ) also clean carfully all sensors from inside ... it can give you a mechanical jam if blocked
Posted on Dec 23, 2010
The cartridges keep slamming to the right. I unplugged it and every time I connect it again it just slams the cartridges to the right. any ideas?
two possibles the home position sensor is bust requires cleaning or replacement or the sensor unit board which is housed on the mother board is bust if this is case cheaper to buy another printer
Oct 13, 2010 | Lexmark X4975 Wireless Color Multifunction...
Lexmark x83 carrier stall
Hello there.
I have checked lexmark's website on troubleshooting this problem for you.
As per the link here we need to try the following steps to resolve the problem.
Carrier stall" Error and the Carrier Slams in the Printer ID:ENUS12078 null.gif null.gif null.gif
If the printer carrier is slamming into the side of the printer, please try the following:
  1. Disconnect the power supply from the back of the printer.
  2. Open the front cover of the printer where the cartridges are located.
  3. Look for two black bands that span from left to right (they should have one serrated side and one smooth side). Just above the black bands there is a transparent strip; this strip is called the Encoder strip.
  4. Flick this strip lightly with your finger to make sure that it is running smoothly from left to right. You may need to do this two or three times. CAUTION: Do not pull the strip!
  5. Close the front cover of the printer and reconnect the power supply.
  6. If the problem persists, you may need to contact Lexmark Technical Support.
Let us know how this goes and we can assist you futher, if the printer is damaged and is under a year old, lexmark may be able to repair or replace it for you.
Hope this helps.
Jun 16, 2008 | Lexmark X83 All-In-One InkJet Printer
Ink cartridge slams from side to side and lights
Epsons often experience this odd problem. This is a sort of tempory fix.
turn printer on allow carriage to leave its base and disconnect the power cord.
Clean the rails the cartridges run on. You should notice the cloth comes away with black stuff.
Use a small amount of sewing machine oil on a cloth and wipe the rails again ( or small amount of wd40 on a cloth.
Slide the carriage along and back a few times. then return it to home and reconnect power cord and turn on. That should get it to behave for a few more weeks/months. If it continues, then the head is damaged and will have to be renewed or buy a new Canon Printer. ( NOT EPSON)
Please rate my help++++Thanks for using FIXYA
Jul 01, 2010 | Epson Stylus C88 InkJet Photo Printer
Lexmark 5400 cartridge carrier slams up against back???? Won't stop!! It's a new printer, put in a high cap black and low cap color cartridge. Any ideas how to fix this?
Cartridges may not be seated properly. Remove all the cartridges from the printer. Close the cover. Unplug the printer from the power source. Wait for about 10-15 seconds. Plug printer back to power source. If printer ink cartridge carrier still slams on the sides, encoder strip of the printer might be damaged. If it's still within warranty from where you bought it, have it replaced at that store. If ink cartridge carrier is not slamming to the sides, re-insert the cartridges. Make sure there are no obstructions along the carrier's path. Close the cover. Let the printer print the alignment page. If it's still going to slam the carrier, have it replaced.
Apr 07, 2010 | Lexmark 83 Color Ink Cartridge (Twin Pack)...
After replaceing an ink cartriage every time I turn the printer the ink tray slams to one side then all the way back I gert an error message to start it again and slam bam. I hope you can help.
The encoder strip may have come out of the sensor slot. Turn off power, slide cartridge carrier to center, place finger on each side of encoder strip which runs behind the carriage and push the encoder strip down and back up, slightly back and forward if necessary to get it into the sensor slot which is located behind carrier. If it is in slot, sliding the cartridge carrier back and forth to see if therre is movement. If so repeat.
Dec 26, 2009 | IBM Lexmark X83 All-In-One InkJet Printer
The cartridge bay goes crazy and slams both sides of the printer. Thus, this will not let me print. I was printing fine, and then I heard a slam, and a notification popped up sayin there was a problem with...
Clean encoder strip, thin plastic strip runs width of machine pararell to silver scan rail. Ensure it is running threw carriage smoothly otherwise the light that read it is dodgy, this will be unecomical to fix unless dirty strip
Nov 07, 2009 | Lexmark Z715 InkJet Printer
Long thin plastic piece fell out of Lexmark Z33
Google your printer, try pcappliancerepair.com. This item goes from one side of your printer to the other, passing through the cartridges holder. Look for the places it attaches. You may have to move the cartridge holder to the center to install the plastic.
May 01, 2009 | Lexmark JetPrinter Color Z33 InkJet
Error code 59.40 on laser jet 4250
Do you mean an HP 4250. If memory serves me right that error number refers to the main drive or cartridge drive. You may have broken the gear on the cartridge while installing it. Especially if your the type to slam it in there. It can happen with genuine and remans so don't go bemoaning reman cartridges...lol. Turn it off...put another cartridge in there...and see if if boots up. I work on printers for a living and had( I'm 95% sure ) that same error code a couple of weeks ago and fixed it for the customer over the phone this same way.
Mar 24, 2009 | Office Equipment & Supplies
Part FELL off!
It sounds like this is the is the position indicator tape. There should be a small hole on both ends of it that fits over a small plastic tab on eich side of the printer. It normally needs to fit in a small **** on the back side of the print carriage.
With the printer turned off & preferably unplugged, gently slide the print carriage to the center of its range of motion. Ensure that this plastic strip is still attached on the opposite end and it feeds through the back of the print carriage. There should be a small tab to attach the free end to similar to what you see on the other end. The strip should be taut but not tight enough to stretch and it should not sag. Exactly where the attach vary somewhat depending on make and model, but they are all similar.
Mar 22, 2009 | Lexmark JetPrinter Z515 InkJet Printer
Printhead
"Carrier stall" Error and the Carrier Slams in the Printer ID:ENUS12078 null.gif null.gif null.gif
Oct 26, 2007 | Lexmark X1150 All-In-One InkJet Printer
Canon PIXMA MP495 InkJet Printer Logo
62 people viewed this question
old marine
old marine
