Question about Technics SL-MC400 110-Disc CD Changer
Says error and will not read or load cd's
Says error and will not load or acknowledge disks
Hi having problems with my partners Fujitsu Siemens ScaleOP Desktop Computer. She recently reformatted the PC with a Genuine copy of Windows XP which installed perfectly without any hitches but when...
Can the drive read other disks? I'm guessing no. If no, it would appear as if the drivers for the CD rom are not loaded. If this is the case, you will need an internet connection to download the drivers for the cd rom so it will work. Other than that,you can try to install generic cd rom drivers through windows, that may work. Good luck.
Sep 26, 2012 | Computers & Internet
Disk read error
it is entirely possible that the boot sector is damaged. if this is the case you need to boot with the cd that came with the machine, or a recovery cd you've made, and load the recovery environment. once their load the command prompt. it should just be a button in vista or 7 and it will automatically load in xp. once loaded type "chkdsk c: /r" no quotes. let it run, this will check for bad sectors and should fix the issue. try and reboot, and let me know what happens. if you don't have the recovery cd's or installation media you can download msdart, which has the recovery console built in. i went ahead and uploaded msdart, download the version you think you need. https://rapidshare.com/files/2296685117/ERD50_x86_WinXP_SP3_blueforce.ziphttps://rapidshare.com/files/2914560443/ERD60_x64_WinVista_SP2_blueforce.zip https://rapidshare.com/files/267688033/ERD60_x86_WinVista_SP2_blueforce.ziphttps://rapidshare.com/files/1400985026/ERD65_x64_Win7_RTM_blueforce.ziphttps://rapidshare.com/files/3314839442/ERD65_x86_Win7_RTM_blueforce.zip
Jan 05, 2012 | Dell LATITUDE Computers & Internet
My playstation 3 has recently developed a problem with reading certain disks. Some blu-ray's I put in it will not even acknowledge that the disk is in the system and some of my games freeze up when I...
You need the DVD DR. cleaning disk that is made for blu-ray players...I've used my disk over 20 times now to fix drive errors in ps3 systems!
Please rate if this helped!
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
JLMS DVD-ROM XJ-HD166 DVD/CD ROM Drive does not acknowledge disc in drive after having the computer set back to factory
Does it not acknowledge dvd disc only or cd or dvd both. If it doesn't read the dvd disc, or able to play dvd disc, but able to exlpore regular cd's, then you have a codec error, and you need to download a dvd codec like powerdvd for it for your system to play dvd disc. Check to see if your dvd-rom drive appears in the "my computer" window, if it is there, but wouldn't be able to play anything, then it could be a driver issue. so make sure in the hardware , the drivers is installed and working properly. If it is working properly and driver is installed, then you got a bad drive, the optical laser lenses isnt reading or the spindle ain't working anymore if you don't hear disc being loaded when inserting the disc.
Jan 30, 2011 | Lite On XJ-HD166S Internal DVD Drive
I purchased a GE webcam model 20671. It is supposed to be compatible with Windows Vista, which I have. When I try and insert the software disk into my cd drive, it is not recognized. There is no error...
Sorry to read about your problem, I hope this helps you out.
goto this site look up your cam, and you can download a driver from this site, plus their is a patch for some DVD issue's and reading them.
http://www.jascoproducts.com/products/pc/GE-Webcams-c14.htm
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | Office Equipment & Supplies
My CD drive wont read certain disk (example; Ufile 2009, norton antivirus) But it reads games (warcraft etc) Once i put the cd in you can hear it running but nothing is happening. I have windows vista...
one idea is to check and make sure they are all cds and some not dvd or blue ray. and verify that your rom drive is cd/dvd,also try to load the cd and open my computer and see if it even acknowledges that there is a disk in it.if so just double click te icon for the rom drive and run the cd that way.
Mar 24, 2010 | Computers & Internet
When i start my lap top is say's a a disk read error occurred press Ctrl+Alt+Del to restart an it keeps bringing me back to the samething?
Remove any CD-ROM disk from the CD-ROM drive.
Disconnect all USB devices.
If your computer has a 3.5" diskette-drive, remove any media from the drive.
Restart.
Your computer is trying to read from your disk-drive,
but it has not been successful, i.e., an "Input/Output Error" (I/O error) has occurred when trying to "read" from your disk-drive.
Find a qualified technician, to see if _any_ of your files can be recovered from your disk-drive.
Mar 02, 2010 | Acer Aspire 4315 Notebook
How to fix a disk read error occured?
Sorry, it's time for a new hard drive.
Nov 19, 2009 | ASUS Eee PC 900 16G Notebook
Disk drive not reading disk
Try using another computer or laptop to rip the CD if you encounter the same problem then the cd is unreadable or dirty try cleaning the cd
Nov 18, 2009 | Acer Aspire 5520-5908 Notebook
67 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
