Question about Panasonic KXDT343 Phone
Use temporary greeting - Panasonic KXDT343 Phone
How do I set up a voice mail with a Nortel M3904?
This is dependent on you being able to access your voicemail mailbox (a mailbox has been setup for you by the administrator and you know the codes to login to your mailbox). Go to your voicemail which should be:
  1. press the message key.
  2. Enter your mailbox number, then press #
  3. Enter your password, then press #. (if you don't know this then you will have to contact the administrator for the telephone system)
When logged into this:
  1. press 82.
  2. Press 1 for external greeting, 2 for internal greeting, 3 for temporary greeting, or 9 for Personal Verification (spoken name)
  3. Press 5 to record then wait for tone.
  4. Press # to end recording
  5. Press 2 to listen to the greeting
  6. Press 76 then 5 to delete the greeting and re-record it.
  7. Press 4 to return to your messages.
Nov 24, 2014 | Nortel Networks Meridian M3904 Corded...
Activate temporary greeting
What make and model answering system?
Dec 12, 2012 | Lands Phones
Hi, I am having a problem trying to update my phone greeting on my Panasonic KX-T7633 . Can you assist?
This is an answer to the question you asked, how to update YOUR phone greeting. Either rate this as a FixYA (4 starts) or don't rate it at all if you're asking a different question.
When you dial into your voice mail from your phone, if you use 500, you're in your VM greeting and the lady says "enter password" or "you have xxx" messages. Option 31 and 1,2 or 3 for greetings. Note: If it says something about "temporary greeting" then select option 5 instead of 31 to change or delete the temp greeting. The other VM access code we use is 165 instead of 500. It's a left over number from the TD series systems.
If you have ESVM, where you can go off-hook and dial *383 to retrieve your messages, You access the recordings by dialing *382. If it starts to play back, then you need to consult your OM (Operating manual) or listen to the prompts to change your greetings for day and night.
Carl
Jun 23, 2011 | Panasonic KX-T7633 Corded Phone
How do I change Voice Mail on my phone?
Dial your extension. Wait for the greeting to say that you are at your voice mailbox. This is also the "Quick Voice Mail Tutorial Set Up."
Follow the instructions provided in the tutorial. You will be asked to enter your name (or company name), password and greeting. Write down the password and keep it in a safe place.
Record other greetings, if needed. After the tutorial, you have an option to add different messages for different situations. Press "311" to change your general greeting. Use "312" to record a message for when the line is busy. Dial "315" to record a temporary greeting for when you are away for an extended period of time, such as vacation. Good Luck
Dec 25, 2010 | Panasonic Lands Phones
How do I set a temporary holiday company greeting?
Most of my customers called their dealer :-)
You need access to the voice mail system and a Holiday custom message or company greeting. After that, it's fairly easy to tell the system when the Holiday message should be played.
Carl
Dec 21, 2010 | Panasonic KX-T7633 Corded Phone
I have the samsung IDCS 28D, how do I change the voice mail to a temporary holiday greeting?
Hi, all you need to do is to go into your voice mail via the voice mail key, once in listen to the prompts until it says ' to assign your no answer greeting'. The prompts give the option to listen and record a greeting, however make sure that you delete the original and record a new greeting other wise the messages play back-to-back! I've posted a video to help you to do this, or visit www.abbeytelecom.com for further advise
Dec 21, 2010 | Samsung DCS 12 Corded Phone
How do I clean the lens? CD lends cleaner only provides temporary relief from fuzzy sound.
hi,
remove the cover, remove the spindle cover of cd player inside, thier you can see a little glas object
clean it with coton sticks and liquid that you use to clean the windows.
move over the lens gently once wet and once dry
now you lens is clean
thats all
greetings
cis
Feb 16, 2010 | NAD C542 CD Player
Change voice mail message from one person to another person
Step 1 Lift the handset for your telephone and listen for the dial tone. Dial the access code you were given by Verizon when you signed up for residential telephone service. Dialing the access code will call the voicemail system. If you do not have an access code, you will need to call Verizon Customer Servicemag-glass_10x10.gif (see link in Resources).
  • Step 2 Identify the telephone number you are setting up voicemail services for. If you are calling from that telephone number, enter the temporary passcode and then press "#." The temporary passcode is the last 4 digits of your residential telephone number. If you are calling from a different phone, press "*" when the system greeting starts to play, then enter the 10-digit telephone number when prompted. After this, you will be asked to input the temporary passcode.
  • Step 3 Choose a new passcode. The passcode must be from 4 to 8 digits in length. It should be easy for you to remember, but difficult for others to guess. Do not use easy to guess numbers, such as 1234 or 1111. Also do not re-enter the same temporary passcode, since it will be easy for anyone to guess.
  • Step 4 Record your name. Simply say your name, without a long complicated message. This recording is used by the voicemail system to identify you whenever you forward a message to another user. It is not used as the standard greeting when a caller is directed to your voicemail to leave a message.
  • Step 5 Record or change your personal greeting. This greeting is played any time someone reaches your voicemail box. Record a friendly greeting to announce that you are unavailable and will return all calls upon your return.
    Decide if you want to set up a different mailbox for each family member. Verizon residential telephone service allows you to set up multiple mailboxes so that everyone can have his own private message center. Callers who reach voicemail will be prompted to press "1" to leave a message for one person, press "2" for the next person, and so on.
  • Step 6 Hang up the telephone. When you have finished setting up the voicemail system on your Verizon residential phone line, hang up the phone to end the call and exit the voicemail system.
  • Nov 08, 2009 | Uniden Cordless Phone
    How do i record new outgoing message ?
    From your set, dial: -> FEATURE 9 8 1 -or- the voicemail key -> Put your password in (if this is a new install 0 0 0 0 is your temporary password) -> You'll hear your name and how many messages you have -> now press the number 8
    Pressing 8 is to get into the adminsitration of this mailbox, and listen to the prompts. This is where you can change the password, name, greeting. You want to change your primary greeting.
    Good Luck!
    Sep 09, 2009 | Nortel T7316E 2-Line Corded Phone
    Not able to access our main voicemail on Vodavi Starplus STS
    To access the System Administrator Mailbox:
    1. Dial into voice mail: From any phone on system dial 150
    2. When the system answers, dial [*] + [#] followed by the System Administrator Mailbox number: (# 0 0 )
    The system will announce: “Mailbox 15-00”, which is the System Administrator Mailbox number.
    3. When requested, enter the System Administrator password. Default = [9]+[#]+[56].
    How to program greetings
    1. Access the System Administrator Mailbox as described above. The System Administrator Mailbox Menu plays.
    2. Press [1] to access system greetings. The system will prompt you for the greeting number
    3. Enter the desired greeting number.
    For example:
    1 = Default Day greeting
    2 = Default Night greeting
    3 = Default Temporary greeting
    4. You will be prompted with the following three choices:
    Press [1] to Review.
    Press [2] to Record. You will be prompted to record the greeting
    When you finish recording, press [#] to save the recording.
    You can then
    Press [*] + [*] + [*] to exit the system completely
    Jul 07, 2009 | Vodavi Starplus SP7314-08 Corded Phone
    Panasonic KXDT343   Phone Logo
    37 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    george  peters
    george peters
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
