Question about Hobart Food Mixers
Mixer won t turn off
My mixer won't turn off I have to turn the timer switch off in order for it to go off
What is the difference between a H800 and L800 mixer
I have used the H600. Nice piece of kitchen kit for hard use.
Model H600 is a heavy-duty 60-quart mixer which features a two-horsepower motor, a timer and a #12
Attachment Hub as standard equipment. With the use of bowl adapters and special agitators, 30- or 40-
quart bowls may be used on the H600.
Model L800 is a medium-duty 80-quart mixer designed primarily for use in general kitchen applications.
This mixer features a timer and #12 Attachment Hub as standard equipment and is powered by a
two-horsepower motor. With the use of bowl adapters and special agitators, 30-, 40- or 60- quart bowls
may be used on the L800.
A Bowl Guard is standard equipment on all H600 and L800 models.
A programmable timer controller is optional on H600 and L800 models.
These mixers can be ordered with a stainless steel finish.
A variety of attachments and accessories are available for all mixers. These are described in a separate Use and Applications Handbook, which is furnished with each mixer.
Here is your manual.
http://www.cvrsupply.com/manuals/hobart/Hobart_L800_Manual.pdf
May 07, 2016 | Food Mixers
Mixer is dead
If this is being used in a commercial setting (I presume it is as it's a D300) the first things I would check is
1 outlet / breaker box /main electric panel
2 Cable from outlet to mixer if the outlet is hot
3 Timer Start Stop switch
4 Motor capacitor
5 Motor (this is ugly as it has a number of electric parts that could have gone bad)
That's the best I can do without further clarification. How did you find it was dead? Did it die while it was in use? Did it make any strange noises? Did it smoke? Do you get any response at all when you turn it on? My first reaction if the cord and outlet are good then I would be looking to the On/Off Timer control switch. It is the most logical if the mixer has not had any other instances of smoking lagging struggling with mixes or advance warning of a problem. It is the most likely answer that a contact is not working. Press all switches and buttons to see if any feel stuck in place. It may be that you only need to open the switch panel and clean out the flour and other gunk. I hope this helps, if so let us know we love hearing from you about a good solution.
Sep 18, 2012 | Hobart D300 Stand Mixer
My machine simply won't turn on .
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Remove both Brush Holder Caps (34), one on each side of the
Gearcase Motor Housing (1). The Carbon Brushes (29) are keyed
and designed to go into the Housing but only one way. Both must
make contact with the Motor Coils in order for the Motor to turn.
If they are improperly inserted or too worn out (replacement is
required) then your mixer will not run.
Jul 26, 2011 | KitchenAid KSM103 Professional 5 Series...
KitchenAid stand mixer KSM50PWH. Was kneading dough with dough hook attachment and it quit turning. Motor works fine but the part that's supposed to go round and round doesn't. Can I fix this?
The Nylon Worm Gear has stripped. This is designed into the part so if the Mixer gets overloaded, it won't burn out the motor. Which is odd if you have the reset switch like I do.
Part# 4162897
You can buy it online at Kitchenaid.com
Jan 17, 2011 | KitchenAid Food Mixers
A - 200 3 speed mixer needs a wiring diaram
how do you know diagram is wrong , you could have wired it wrong the timer kit i belive comes with 3 or 4 different diagrams for that mixer you need to pick the right one
Aug 27, 2009 | Hobart A200 Stand Mixer
Timmer assembly
this a 115 volt single phase timer you can buy the timer at hobart.com or jump the timer by jumping the red and brown wires but the timer will not work if you want the phone # of hobart tell fixYa to email me and i will leave the number they are located in jackson hieghts N.Y
Oct 30, 2008 | Hobart D300-6036 Mixer
On/off switch
if the mixer is pretty old then the timer is bad.If its a newer unit the timer or the bowl height sensor is bad.
Jul 01, 2008 | Hobart A200 Stand Mixer
Hobsrt Mixer problem
Its ok to by pass the timer.You can bypass it and the switch will work.Let me get my service manual and ill post back on how to do it.
Feb 20, 2008 | Hobart A200 Stand Mixer
A200T HOBART MIXER
is there a bowl cage on the mixer?if not bypass the timer and see if it starts.
Oct 19, 2007 | Hobart A200 Stand Mixer
Food Mixers Logo
26 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
