Question about Fenix E11 Flashlight, Silver
My e11 goes on seemingly on its own and is difficult to turn off . how do i resolve this?
How do you fix e11 code?
Hello friend, thanks for your post!
I see that your Electrolux washer is giving off an "E11" error code. An "E11" stands for water is not entering, which can be several possibilities. The water supply to your home has been interrupted or water pressure may be low. Check the hoses to assure they are not kinked and the drain pipe is proper per installation. If these steps have not resolved your issue it could be a problem within the control panel and I would perform a reset on your appliance, which is disconnecting power from it for roughly ten minutes. Hopefully this helps. -Matt
Sep 06, 2014 | Electrolux Washing Machines
WHAT does E11 meens washer does not take in water
Good Afternoon Friend,
I understand that your Frigidaire Affinity washer, model# ATF705BZHS, is not filling with water and showing an E11 error code. The E11 code means that your washer is taking a long time to fill. First, make sure that the incoming water faucets are turned on. Next, you will want to make sure that the pressure is above 30 PSI. I suggest resetting your washer, by either unplugging it or shutting the power off at your home's circuit breaker for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire AFFINITY WASHER ATF705BZHS FOR...
Eternal hot water heater error code e11
I cannot find what e11 means but it seems most people have just unplugged it an it came back on. Code goes away.
Mar 29, 2014 | Eternal Hybrid Tankless Hot Water Heater...
417-44052400 Fills with water, washes, drains/spins then comes to a stop. If I did the diagnostics right it indicates E11? Anybody else have this problem?
e11 is a water problem filling to slow,you could have a problem with your cold water fill line,clogged sediment in the valve or something like that,when it goes into rinse the machine uses cold water so the clothes won't wrinkle and it sounds like it's filling to slow.
Nov 26, 2011 | Washing Machines
How to remove the glass cover on a 5tv52whd ceiling fan and where i can buy the bulb
Regards, Tony
May 11, 2011 | Monte Carlo 5DI52WHD Discus White Ceiling...
My Frigidaire washer is reading error code E11..how do I resolve this problem?
E11 = Long Fill Time
Check to see the water valves are opened all the way. Check water hose screens for buildup.
Jan 30, 2011 | Frigidaire GLTF2940ES Front Load Washer
I have a Hoover vhd sensor Dry Washer Dryer and its come up with error E11. Can you help ?
Hi I had the same problem about once a week and every time it happened I had to turn off the washer off and leave for a while and start new wash cycle. It worked for a while but eventually it started to throw E11 once I put it on (not the middle of cycle it used to do). I had to result to call the repair man. He checked all the hardware and nothing was wrong and re-install the program on the board and it stopped throwing errors. After 4 month of problem free period, it gave me E11 again today though..
Jun 23, 2010 | Washing Machines
FAFW3577KWO washer-code E11 washer will begin wash cycle and stop after 5 or 6 minutes. display reads PAU- when start and cancel buttons are simultaneously pushed I get an E11 code. What is E11?
Your machine may have short circuit with the inlet valve since you are facing problem after 5 to 6 mins you are suppose to change the inlet valve
Dec 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Fenix E11 Flashlight, Silver Logo
35 people viewed this question
Top Fenix Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Fenix Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
