Question about Ionic Pro Air Purifier Model CA-500
Where is the fuse on ionic pro ca-500 - Ionic Pro Air Purifier Model CA-500
My ionic pro ca500 has the blue light on but also is making a intermittent sizzling sound, I have wiped the blades, the clean light is not on.
What does the blue light mean? I had 4 Ionic breeze air cleaners, ionizer wires are broken. I was thinking about buying the Ionic Pro cleaners, but have no input about how well they work.
Dec 02, 2013 | Ionic Pro CA500 Air Purifier
Request of where to send Warranty Card to activate warranty for Model No CA5000. Card came back as undelivable.
Hi, Elizabeth! Here's all the contact information Iconic Pro:
Ionic Pro
P.O. Box 4134, Los Angeles, CA, 90048
Customer Service: 800.875.8577
Website: www.ionicpro.com
Hope this helps you to contact them.
Apr 27, 2011 | Ionic Pro CA500 Air Purifier
I have bought Ionic Pro Turbo Air Purifier recently in USA and moved out of the country after the purchase. When I plugged in with right electricity voltage & watts, my purifier starts with green light...
Hi Sathish, I work for the Ionic Pro company. What country are you trying to use the unit in? This will help me determine how to assist you. Thank you, Mary
Feb 15, 2011 | Ionic Pro TURBO Air Purifier
MOdel CA-500 is making a type of hissing sound. Almost like a zapping sound.
you need to turn it off and remove plates,put in kitchen sink and spray with windex and dry with paper towels, now clean the bottom of the three plates too.
before you reinstall the plates look down inside you will see three thin lines of metal,make sure there is no lint or dust on them,reinstall and let set for five min. to allow any windex that might still be wet then turn on low for a couple of min.then go to medium
Dec 15, 2009 | Ionic Pro CA500 Air Purifier
Have a ta-500 unit no matter how much you clean it
probably the power supply, no real fix, you can try to remountt it or loosen the screws and that MAY fix it
Jul 06, 2009 | Air Purifiers
Ionice breeze quadra Model # S1637
had the same problem with ionic pro ca500. i took the unit apart and found a fuse that was blown and it works now. sorry but i don't know if there is any repair shops.
Aug 02, 2008 | Sharper Image Ionic Breeze 3.0 Air...
My Ionic Pro doesn't turn on
i have taken the unit apart and found that if there is a broken wire you have to be a magician to fix it even if you had spare wires.
also found a small fuse in the bottom of the unit but it is soldered in. i am currently in the process of replacing and will post results asap.
Dec 12, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Can't clean Ionic Pro CA-500 inside?
This unit is a pain in the @$$ to disassemble but it CAN be done. The way I always look at it: Someone ASSEMBLED it.
Remove the four screws on the bottom stand followed by two screws on the bottom side of the unit. Then remove the tiny little screws up each side that hold the grill together (you will need a precision screwdriver).
Carefully pull apart- don't force it.
One half comes off (clean that half) in bathtub. The other half does not come off-vacuum that half out and use q-tips.
When re-assembling, watch for two things: First the wire cleaner (that slides) runs on a track on each half- pull it out a little to best allow for fitting. Second, there are little tabs at the top that fit under the control panel-watch for those.
email me at originalpairadice@yahoo.com if any problems.
Oct 19, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Ionic Pro CA-500B Power On Instant Clean Light
If the plates are clean, there is nothing wrong with them. They are just 3 strips of metal... they don't even connect to each other unless they are in the unit. NO NEED TO REPLACE THEM.
Sep 13, 2006 | Ionic Pro CA500 Air Purifier
Ionic Pro Air Purifier Model CA-500 Logo
Top Ionic Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Ionic Air Purifier Expert? Answer questions, earn points and help others
