Question about Bosch & Tankless LP Hot Water Heater
250sxng Water heater keeps clicking off
    New Friend:
  • 42 Answers
The display should show an error code. Here's a list http://hometips.me/Tls/Bosch-error-codes.pdf
Posted on Feb 17, 2014
Water heater keeps shutting off
1) Product unknown,. Copy following link:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#ECO
2) Add comment with brand and type water heater if more help needed. Jan 2013
Jan 25, 2013 | Bosch & Tankless LP Hot Water Heater
Help! I can't get the water heater to go on! I KEEP TRYING to set the dial, but it's not working
If I understand correctly, you have the WH40 water heater timer.
If timer dial will not rotate, then use manual override to turn on circuit to water heater.
If manual override will not move back and forth, the tripper pin might be wedged against the lever.
Lift and rotate dial out of way.
If manual override does not click back-and-forth, then timer is probably bad.
If manual override clicks, but water heater does not turn on, then check electricity.
If you need more help, post a comment and I will respond
Oct 28, 2010 | Intermatic WH40 - Water Heater Time Switch...
I have an AO Smith Model EES 52 917 hot water heater. This morning my hot water suddenly disappeared. I have tried resetting the breaker with no luck.. I am not sure what else to try.
You have electric water heater.
Inside the upper panel on water heater is a thermostat with red reset button.
1) Click the reset.
2) Put insulation back over thermostat so it is not exposed to cooler air, so it reads correct temperature.
After resetting thermostat, you will have hot water.
The reset automatically clicks off when thermostat detects temperatures in excess of 150 degrees.
The re-set is a safety device, and it keeps everything safe.
If reset will not 're-set' with cold water in the tank, then thermostat is bad, replace thermostat.
You can repair electric water heater yourself following steps on links below
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
If the reset clicks off again, just reset it
This is not a dangerous situation
Reset thermostat as many times as necessary until you can fix the problem
If you have trouble fixing the problem, add a comment at bottom of this page and it sends me an e-mail and I will help further
Thermostats with ECO red reset
Oct 26, 2010 | Water Heaters
Water heater pilot and burner keep going out.
If this is a common occurrence, then it may be time to replace the thermocouple that controls the pilot part of the gas valve. If it still keep going out, gas valve may be faulty.
Jun 29, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
My suburban RV hot water boiler ignites but won't stay lit. The ignitor keeps clicking
Could be the flame sensor is bad,it looks like a thermocouple scratch it with a knife then try again.
May 16, 2010 | RTO Suburban Rv Water Heater Dsi Gas Valve...
Reset keeps triping
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXTechSupport/Troubleshoot/tabid/563/Default.aspx
click on this link and it has the troubleshooting in strucktions for the unit . hopt that it helps you out.
Jan 11, 2009 | Bosch Water Heaters
Bosch & Tankless LP Hot Water Heater  Logo
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
