Question about InFocus ScreenPlay 7200 Multimedia Projector
7210 premature shutdown
My 7210 projector prematurely shuts down after an indeterminate length of time. The green light is on (not blinking) and the fan is running, but the lamp just goes off. Sometimes it will work all evening and sometimes shuts down after less than 30 mins. The unit was sent back to the manufacturers in the Netherlands and it was returned stating that it was not faulting. They had cleaned dust out of the unit and downloaded a firmware upgrade. I have had it for just 18 months and the lamp hours are 1910. The unit will not even display its own logo or menu, it just goes out. If I switch it off and back on again, it usually works for a while, but you never know for how long. Is this a known problem or do you have any suggestions before I have no more hair to pull out. The dealership just doesn't want to know. Regards, Mike.
  • dman10 Dec 27, 2007
    Projector is broken but the bulb is still on
  • 2,237 Answers
Make sure the colorwheel is working. if it is, replace the ballast. the caps are dried out.
Posted on Dec 29, 2009
After working for a while, the lamp goes out, and a red light will appear on the lamp indicator. Even after allowing it to cool down, once you turn the projector on, the red light appears on the lamp...
check the physical nature of the lamp in the projector. around the filament of the lamp, you might notice dark corrosion building around it. this what normally cause premature shut off.
Sep 14, 2011 | Optoma ES520 DLP Projector
Colours have gone and picture quality became very dark. Now wont stay on for very long...will switch off after about 10 mins of viewing.
Unfortunately dim image and premature shut-off are normally due to a defective lamp assembly. I'd recommend removing the lamp and inspecting its condition. You'll notice black corrosion build up or a bubble is starting to form around the filament of the bulb if it is what's causing the dim image/premature shut-off.
Aug 01, 2011 | Panasonic PT-AX200U Projector
My infocus 1503 works however once it is turned on the unit sounds as though it is ready to take off. The fan is very loud then after a few minutes it quiets down and then the fan becomes very loud again....
I own two of these projectors. You need to update the firmware to 1.03 which can be found on the infocus website. This solves the fan issues which also causes premature shutdown of the projector. Once you download the update, open it, there will be step by step instructions on how to do this procedure. I could not get this to work with Vista 64 so you might need to run this on XP or 7.
Mar 11, 2011 | InFocus IN1503 DLP Projector
I have a VPL-CX70 that has a new lamp (less than 50 hours) and the hours were reset to 0 when the new one was installed. However, today, the lamp cover LED started blinking and the projector shut itself...
The bulb is not lighting correctly.
Take out the bulb and check the connectors are not dirty and reinsert.
See if you can see the bulb looks ok, you may be unlucky that the bulb has prematurely failed (hope not)
Try again to start it.
Please dont forget to vote this answer was helpful
Many thanks
Feb 17, 2011 | Sony VPL-CX70 Multimedia Projector
It powers up and runs for about 3-4 min. then shuts down. It has 57 hours on the lamp.
Depending on the age of the projector it is likely the power supply. If the first 4 letters of the s/n are ANEL or anything other than ANEV it could be that the power supply is an older model that did'nt get the upgrade that was used to fix the premature shutdown issue which was fixed by soldering a ground wire from a point on the bottom of the power supply to the top of the main board. If you take the top off you can see if a wire coming from the bottom of the power supply to the top of the main board and it should be soldered and not screwed in by a screw.
Oct 06, 2010 | InFocus LP70+ Multimedia Projector
Projector keeps shutting down every 20 minutes. Could it be the fan or the bulb? or something else?
look at the lamp and check to see if there is foil tape over the seams on top of the lamp. The top is the side under the top cover of the lamp when installed. If the foil tape is absent, then the heat escaping from the seam is triggering the thermal sensor in the lamp housing causing the premature shutdown. If your lamp does have tape on it then your lamp is probably going bad.
Aug 05, 2010 | InFocus IN24 Multimedia Projector
LP70+ picture flashes and jumps cintinually as if it is trying to reset resolution
cheapest thing to check is your cables. get new ones. if it is jumping and flickering leading to eventual premature shutdown of the projector then you need a new power supply/ballast with the wire upgrade on it.
Jun 03, 2010 | InFocus LP70+ Multimedia Projector
IN24 Multimedia Projector: Orange light bulb light came on....does this mean ...
if it runs for a few minutes before shutting down, it could be the lamp. check to see if the seams of the lamp that are closest to the underside of the top cover have foil tape covering the seams, if not then this has been known to cause premature shutdown.
May 17, 2010 | InFocus IN24 Multimedia Projector
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Just replaced bulb when cold it has trouble lighting.
it's not the lamp, it's the ballast. when it's fully discharged, it needs too much power to start. once it has the caps charged (when it's been running and warm), it'll start right away. it sounds as if the capacitors on the ballast are drying up. best to replace the ballast. after you do, make sure the projector is free of dust and dirt. excessive dust will cause premature power and lamp failure due to lack of cool down.
Jul 07, 2009 | Sharp XR-10X Multimedia Projector
InFocus ScreenPlay 7200 Multimedia Projector Logo
167 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
