HP B209 printer getting "Ink System Failure" oxc19a0022
Is there a way to bypass this "Ink System Failure" code?
  • 4 Answers
SOURCE: ink system failure
NOT A SOLUTION, JUST SOME FACTS>
First of all, your printer is "NOT" the worst model ever made, every printer that hp (as you probably noted I used small letters hp because I think hp is a small worm of a co.) makes is a problem waiting to happen. The worst of it all is that the don't care about there customers. I have a almost $300.00
photosmart that is a few months out of warranty, even though it stayed new in the box for over 6 months because of a heart attack I had. I ran out of two of the colored Inks, but continued to use the printer for word documents only till shortly after, the printer said it was unable to print till the two empty colour cart. were replaced. I continued printing all other items on my up stairs computer. About a month later, I purchased the cart. needed, installed them in the photosmart,(which I think is a oxymoron) and the printer came up with,"Ink System Has Failed" Error code oxc18a0306.
I know this is getting long winded, but it's the only way to get my point across fully. I contacted hp and after over 40 min. they told me that the error code was fatal and could not be fixed!!!!! They said It was out of warranty and would not be replaced for any amount of money besides paying full price for a replacement. ( Ya Like I Would Buy Another hp product). I have since then had the printer checked out and a small pc board with, a valve or sensor for all the ink supplies is not letting the yellow ink out of the pump to the print head. I contacted again, like a fool, hp and was on the phone for another 52.min. till they told me that part was not available..... End of story
P.S.
I hope this story gets out to every person that had, or has a hp product and
had a problem that was not resolved by hp, besides telling the customer they will fix the problem by selling to you ,at full price another printer.....
I'm All For Boycotting hp!
P.P.S.
I hope this gets back to hp
Ron Trovato (702) 633-4298 rtrovato@embarqmail.com
Posted on May 21, 2008
Semi-Driver
  • 434 Answers
SOURCE: Ink System Failure
1) With the printer On, make sure you have new cartridges installed ready to initialize. Replace as necessary.
2) Press and hold the <OK> and <Cancel> [or <X> if you do not have Cancel] buttons down at the same time and turn the printer off with the power button.
3) Keep holding the buttons down until the printer turns off.
4) While pressing the <OK> and <Cancel> buttons, turn the unit back on. It should cycle a bit then turn itself off again.
6) Press the <Power> button to turn the printer back On.
7) The printer will reinitialize the ink cartridges. Do not disturb this process. After completion (approx. 5 minutes), it should be ready to print.
Posted on Jan 07, 2010
MUKHTAR
  • 2017 Answers
SOURCE: HP Photosmart C6180 Ink System Failure Message
just follow this steps may help you out otherwise you need to change it.
Check to see if the installed cartridge is the correct one for the printer. . If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the HP Customer Care Center listed in the printer's User's Guide.
Reinsert the cartridge and try printing again. If the error continues,then you can go for repair or buy a new one .but i advise you to dont go for repairing bcoz it is 3 year old .
Have a nice day and do not forget to rate please...!
Posted on Feb 02, 2010
pineworks
  • 4041 Answers
SOURCE: Ink System Failure code appears on Hp Photosmart D7360 printer
Hi ok try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
Angel Bird
  • 287 Answers
SOURCE: My HP B 209a All
Hello and Welcome!
The error 0xc19a0022 is mostly occurred in HP printers
To solve the error code 0xc19a0022, Follow the given steps
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
Error will automatically remove.
But if u face still this error then printer service required. In that condition best option is to Contact HP Service Provider
I hope this solution helps you
Thank you for using FixYa
Posted on Apr 09, 2011
I am having problems with printing......this is error message on the printer screen Ink system failure......0xc19a0022
Hello and Welcome to FixYa!
The error
oxc19a0022 is mostly occurred in HP printers. To solve the error code oxc19a0022,Follow the given steps
Aug 27, 2011 | HP Photosmart 3310 Printer
Printer displays "INK SYSTYM FAILURE" error code
Printhead assembly needs to be replaced. call hp support. if printer is still in warranty replacement will be for free.
Jun 02, 2011 | HP Photosmart 3310 Printer
C6380 hp printer displays message: ink system failure Oxc19a0022 I have reset the system and then cleaned the printhead but the message persists
Try resetting the printer a second time. If you have done this step, unfortunately, you either need a replacement print head or the printer needs service.
Print heads are not returnable if a new one doesn't solve the problem.
You can order a replacement print head either by phone or by entering your printer's model and serial numbers here: http://h20141.www2.hp.com/Hpparts/Default.aspx?mscssid=7E679E4B5EF640FF85D318BA520F8C9A .
I wish that I had better news.
Mar 22, 2011 | HP Photosmart C6180 All-In-One InkJet...
Hp c6380 printer; having problems with the ink system failure; ox
Follow steps below to reset Hewlett-Packard (HP) All-in-one Printers (products with keypads only). Resetting your printer will reset your printer to its original state.
For products with keypads on the control panel:
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold “# and 6′ keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
For Box-type models:
1. Unplug the power cord from the printer.
2. Wait for 30 seconds.
3. Plug the power cable back in the printer and turn it on.
Jul 09, 2010 | HP Photosmart C6380 All-In-One InkJet...
Ink System Failure
Jan 07, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
22 people viewed this question
jasbo
jasbo
