Question about Locks & Locksmithing
Lost key and batteries are dead - Locks & Locksmithing
TSS safe E1N lost key battery dead
lost key battery dead Donald, call a locksmith.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 25, 2016 | Home Security
My key fob is lost and I need to get into a avalon
You'll need the door key with a dead battery because the key fob won't unlock the doors with a dead battery lost or not.. Toyota dealer is the only place a new key fob can be purchased that will work.
Oct 01, 2014 | 2009 Toyota Avalon
3300CE charging problems
The battery on my unit is dead. What could be the cause? Possible causes for a dead battery on battery operated units: 1. Battery has lost its ability to hold a charge
2. Charging system on unit has failed (battery cables, alternator, or alternator control board)
3. Stuck key on the display is causing a constant draw from the battery.
The battery on my unit is dead What could be the cause
Jan 14, 2014 | Stairmaster Exercise & Fitness
My range rover 2007 key is completely dead
surely my friend your key has lost its program. Need reset the program even I believe the ignition key. Refer to main dealer about it
Sep 14, 2012 | 2008 Land Rover Range Rover
We have a S3877 Sentry safe. The battery appears dead so I can't use the code. I also have the key but since the battery is dead it is no help. What can I do?
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Dec 07, 2010 | Sentry Fireproof Safe
Dead battery! CANNOT OPEN SAFE
This model is supplied with a key for emergencies. There is a plastic panel in the middle of the door with a silver sticker on which the moel number GXB0709 is printed . Lever off the plasic panel to reveal the keyhole.
May 09, 2010 | Safe International Digital Electronic Safe...
I have lost my pin and backup keys + battery dead!
i got the same problem i lost my key and cant open now
any idea what to do
May 28, 2009 | Safe International Digital Electronic Safe...
Locks & Locksmithing Logo
26 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
