Question about PowerBright Power Bright 2300 Watt Power Inverter - 12V DC to 110V AC
The remote won't turn it on or off.
I can it on by hand, but the remote will not turn it on or off.
FAN WON;T SHUT OFF EVEN WHEN UNIT IS TURN OFF WINDOW UNIT
The switch may have rusted a bit and won't let the switch turn off. Sometimes a whack with the side of your hand might jar it loose and turn off. Or the switch is bad and needs replacement. You probably got it at Lowes. Ask them to suggest a good repairman.
Jun 14, 2014 | Frigidaire 5,000 BTU 9.7 EER 115 Volts...
Vivo tv won't turn on lost the remote and the
These are the universal remote control codes to Vivo TV. 0004 0005 0009. Check this link to know more codes and proceedings to other brands of remote controls, and buy one remote control that has setup codes with your TV. The above said codes are for GE remote with Vivo TV.
Jan 23, 2013 | Televison & Video
Xtn series won't transmit through remote microphone
Here are a handful of problems you might be having:
1) Be certain the radio is turned OFF when plugging in an audio device.
2) Be certain the remote mic is plugged all the way in, until you feel a slight click.
3) Your accessory jack could be wobbled or worn from plugging and unplugging chargers/audio devices. If so, the radio would need repair.
4) Your remote mic is not working. Try it on another unit to confirm.
5) Or the remote mic is not the one designed to go with the XTN radio.
Best regards.
Jun 18, 2012 | Motorola XV2600 XTN Series Portable...
Remote hand control won't turn system on. Batteries are OK
1) Change by new batteries type alkaline
2) Clean the contacts batteries with special spray contacts cleaner
3) Retight the springs contacts batteries with plier very well for good contacts.
4) Resolder wires contacts batteries.
5) Reset the code again download for free from www. fitness.manualsonline.com or www. remotecodelist.com
Otherwise you must opent the remote and clean any contact from keypads very well, or go to the repair shop
God bless you
May 14, 2012 | Televison & Video
HV mega quilter hand wheel won't turn and it won't turn on
it could be the switch or motor, it would be a good idea to have the machine checked
Apr 05, 2012 | Sewing Machines
My remote will not cut on my Bose Cinemate system. I have changed the batteries in my remote and the red light on the receiver is illuminated, so I know the system is operational, . I've also unplugged...
It seems to be a common misconception that the remote is necessary to turn a device on. All devices have hard-wired power controls. Does THAT work? It is unclear which device (remote or the Cinemate) is malfunctioning. If the Cinemate won't turn on by its own power switch the remote won't magically bypass whatever the problem is.
The Cinemate Manual offers some steps to take if it won't turn on, as well as other guidance.
Bose.com
Jul 31, 2011 | Audio Players & Recorders
I've got one single 12000 btu ac unit and one double 24000 btu unit and three wall units controled by 3 remote controls.Recently one of the remotes stoped to work.I've changed the batteries(were...
Taking apart the hand held remote won't serve any real purpose as none of the parts inside are replaceable. Since you have 3 different units, with 3 different hand held remote. I'm wondering, if perhaps, you're using the wrong remote on that one unit. As each one has a different remote code.
In addition, I have learned from experience, that if the display screen on the hand held works, the problem is not in the hand held. Now, that's not to say, Operator Error can't play a role in it. But, most times, it's the receiver in the unit,that may be causing the problem. Or the hand held is to far away or something is blocking the signal in between.
Almost every appliance we sell, has a radio frequency remote control. The most problems we incur is with weak or dead batteries or operator error. The problem with batteries is that you don't now how long they sat in a warehouse, before making to a retail outlet and then how long they sat on the shelves there, before they were sold. They may have enough power to activate the handheld remote, but not enough to transmit a strong signal. So, check the strength of the new batteries you installed.
Hope this helps and thanks for choosing FixYa.
Jul 29, 2011 | LG LS-K1830CL Cool Mini Split Air...
I need help I just won a tv but it didnt come with a remote but I have a RCA remote transmitter. Im trying to program it for the tv but I dont have the book anymore can you please help me The tv is on but...
This Web page should allow you to find the codes for any devices you want to add for this remote.http://remotefinder.rca.com/default.aspx?site=rca
Other than that there is an easy way to program this remote.
1. Turn on the device by hand. 2. Hold down the device name key.(hold the TV button to program a TV) 3. While holding down this key also hold down the power key until the red light turns off and comes back on. Then release both buttons. 4. From here hit the power button repeatedly until the device turns off. 5. Hit the stop key at the bottom. Now the remote is programmed for that device.
May 05, 2011 | Televison & Video
I turn on the TV and seconds later it turns off on it's own.
Sounds stupid, but where is the remote control? I had a weird issue a few years ago where my TV would turn itself off constantly. Turned out the remote control 'off' button was wedged down.
Try covering the IR receiver with your hand and turning the TV on (make sure the IR window is well covered and no Infra-red could leak in!). If it is ok then something i transmitting an 'OFF' signal. If TV still turns off on its won then sounds like it could be quite ill, possibly dying.
Oct 07, 2010 | Televison & Video
Turned off a/c remote < now it won t turn back
It sounds like the remote sensor pc board is bad, you need to replace the sensor board.
Nov 03, 2009 | Fujitsu 24C1 Air Conditioner
PowerBright Power Bright 2300 Watt Power Inverter - 12V DC to 110V AC Logo
Top PowerBright Electronics - Others Experts
Jay Finke
Jay Finke
ray gallant
Are you a PowerBright Electronics - Other Expert? Answer questions, earn points and help others
