Question about Zoom R8 Digital Multi-Track Recorder, Interface, Controller, and Sampler Bundle with 10-Foot Instrument Cable, 10-Foot XLR Cable, Headphones, and Polishing Cloth
How to factory setup the zoom r8
Can not make new project ,unit is brand new
Why zoom g2 point blinking ?
There is damage/burnt at Transistor Q4 or Q3 or both. Usually followed by R8. Replace it.
Q3 = BC337 (SMD marked as 6C) NPN.
Q4 = BC327 (SMD marked as 5A/B/C/D) PNP.
R8 = 470 ohm (SMD marked as 471).
May 06, 2014 | Zoom G2 MultiEffects Guitar Pedal
Will not zoom all the way
Hi Russell, Sounds like drive function problem. Almost like it is trying to over-travel. This is going to need service / repair before any damage is done.
Best Regards, Russell
Jan 20, 2013 | Ricoh R8 Digital Camera
Roland r8 has flashing green light
Are you using the correct AC adapter? An aftermarket unit will do this if the power is insufficient, or the polarity is wrong (- / +). If you're using an aftermarket unit, it may not be providing the right amount of Amps and Voltage to the unit; causing the display to blink. You can try this cord to help: http://www.powerpayless.com/ac-power-adapter-for-roland-r-8-r8-drum-machine.html
Jan 13, 2013 | Music
I have a Zoom H4N and i am unable to select different modes on my recorder. There is actually no 'mode' available in my menu. How do i fix this? It is brand new out of the box.
If your H4n is in STAMINA mode (Switch in battery compartment) then MODE is not viewable in the MENU. Simply Turn off the STAMINA Switch and restart your H4n (Turn H4n OFF then ON again)
Hope that Helps
Cheers
Jaysan
Nov 19, 2010 | Zoom H4 Handy Recorder
Remote broke how do I zoom my rca d52w20 piture out without remote? Can't find anything in the setup menu to help.
U can't.Don't have that function in the manual controls.Try website 1-800-Remotes Factory original.To buy an original remotes.
Feb 16, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Oil level dipstick measurement on Audi R8 4.2 FSi
I believe that this vehicle doesn't have a dip stick and should be serviced by the dealer only.
Jul 19, 2009 | 2009 Audi R8
How to reset my Denon DN-V210 DVD Player to factory default?
Hi Jason,
I have just bought this unit and have been using the menu recently. The only ways i can see to do it would be to either, (as you say) plug it into a HDTV, or navigate the menu blind and hope for the best.
If you press SETUP on your remote once to get to the menu setup screen and then push the RIGHT navigation button 3 times this should take you to the system setup screen. Then push the DOWN navigation button 4 times and then push ENTER. At this point it asks you for a 4 digit password to reset the unit which is a factory preset, 5555, so type that in. This should then reset the DVD player to factory settings.
Hope it helps,
Nick
Nov 14, 2008 | Denon DN-V210 Player
SamsungLE26 R8 Picture Settings Problems
tv had reverted in to shop mode.I accessed the secret bmenu and restored the normal settings. Thanks
Apr 07, 2008 | Samsung Televison & Video
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
Picture cut off
No adjustment needed on these LCD projection. Your problem is in your setup menu. Your default is now is set ZOOM. That is why the bottom of the picture is cutting off. Go to Menu, setup and screen size or something close to that.
Best regards
Circuitcity
Jul 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Zoom R8 Digital Multi-Track Recorder, Interface, Controller, and Sampler Bundle with 10-Foot Instrument Cable, 10-Foot XLR Cable, Headphones, and Polishing Cloth Logo
44 people viewed this question
Top Zoom Audio Players & Recorders Experts
Jaysan Lunt
Level 1 Expert
Paul Bade
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
