Question about Asrock Z68 PRO3 LGA 1155 Intel Z68 HDMI SATA 6Gbs USB 30 ATX Intel Motherboard
Asrock motherboard problems
A week ago started to loose USB ports, used for wireless keyboard and mouse. All USB ports have now stopped working, this also now includes the HDMI and DVI output. With no screen I have no way of finding out whats happening.
rajhbullhead
  • 42 Answers
SOURCE: vga problem
There is a problem with your VGA internaly, try to buy a VGA card to replace it. And your mouse not might work beacuse of your BIOS
(Basic Input Output System).
Posted on Mar 07, 2008
  • 7 Answers
SOURCE: ASRock K7VM4
In addition to advice from Solution 1 the MB I had was same as yours. Turned on computer and all I had was a spinning CPU fan and power supply fan, nothing else. Turned out to be the ram slots not making contact. Try swapping ram to unused bank or cleaning contacts on plugs with Micro-scrub and or electronic cleaner (Iso Pro). I used very fine waterpaper, then a vacume and then ISO Pro spray to clean cause I can never find the Microscrub when I need it. Make sure all is dry before reinstalling and power up.
Posted on Sep 09, 2008
dave836
  • 12 Answers
SOURCE: My keyboard, mouse and USB ports do not function
Are the mouse and Keyboard USB varieties? If so, then try plugging in a PS/2 mouse and keyboard and boot the machine up. You can then check your system hardware settings in control panel and reinstall the USB drivers. This would be my first step in solving the problem. If you need any more help then just ask
Posted on Nov 17, 2009
chalkperson
  • 147 Answers
SOURCE: I just installed an Asrock K7S41GX motherboard in
Try temporarily connecting a standard keyboard. If it now boots up o.k., the OS should write the prescence of the wireless device to BIOS and you should be able to boot up with your wireless devices only.
Posted on May 13, 2010
nonontech
  • 4737 Answers
SOURCE: PS2 KEYBOARD & MOUSE Not responding.
Try connecting one at a time, if you connect the mouse don't connect the keyboard, and if you connect the keyboard, don't connect the mouse, reboot each time and check which one is the culprit. One of the port or device must be creating the problem. Good luck.
Posted on May 24, 2010
My Genius Traveler 6000x wireless mouse suddenly stopped working
Double check the batteries, although the lights work and the computer sees it, the voltage could drop low enough to stop the sensors.
next, try another USB device in that plug. USB port can go bad.
If the port works, it could be the wireless USB connector starting to fail, if they are bumped to hard sideways it can cause loose connections internally.
then, you might just need to update drivers. Computer update s can conflict with drivers cause devices toss top working.
May 20, 2014 | Genius "Wireless Mouse - Traveler 6000X,...
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
I bought a gateway zx series computer 3 weeks ago. the wireless keyboard and mouse that came with it has stopped working for no apparent reason. the computer says that it doesn't recognize the device. i...
hi Karnarc.
How do I troubleshoot my Gateway wireless keyboard and mouse? How do I troubleshoot my wireless keyboard and mouse?
If you are experiencing issues with your wireless keyboard and mouse not working properly, perform the following steps to troubleshoot the wireless keyboard and mouse.
  1. Make sure the USB connector from the receiver is properly plugged into a USB port on the computer. Some systems ship with the receiver already preinstalled in the unit itself. Please check your mouse to see if there is a receiver inside of the battery compartment door.
  2. Make sure wireless keyboard is not on a metallic surface.
  3. Ensure that the receiver is 8-inches from other electrical devices.
  4. Try plugging the receiver into a different USB port to ensure that the USB port is working properly.
  5. Check the batteries in the keyboard and mouse to make sure they are installed correctly.
  6. Test the batteries to ensure that they still have a charge.
  7. Verify the On/Off switch on the keyboard and mouse are switched to On.
  8. Some receivers, keyboards, and mice may have a connect button. If so, follow the steps below:
    1. Plug the USB receiver into a USB port on your computer.
    2. Press the connect button on top of the receiver and the button will blink.
    3. Press the connect button on the bottom of the keyboard to activate the wireless connection.
    4. Press the connect button on top of the receiver and the button will blink.
    5. Press the connect button on the bottom of the mouse to activate the wireless connection.
Dec 03, 2017 | Gateway Computers & Internet
My mouse does not work. I originally could not turn the pc on for approximately 1 week. I took it in for repair , they could not find the problem. When I returned home and repluged all the wires the...
Are you using an USB mouse? If so you may like to try another USB port or there might be some wire to the USB port not plugged right. You can check the printing on the motherboard to see how it should be plugged. (There is several wires for each USB port with a certain order into an plug on the motherboard when the USB port is not on the motherboard). You can check the power and make sure it is connected well and enough for everything. Other options will be to use other mouse like wireless mouse or PS/2 to USB converter to make a PS/2 mouse an USB mouse or vice versa. Checking motherboard and measuring every voltage could be very complicated.
Jul 24, 2010 | HP Pavilion dv1600 Keyboard - 412374-001
May 24, 2010 | Asrock CONROE1333-DVI/H INTEL 945G CHIPSET...
My keyboard, mouse and USB ports do not function at Startup any more. The keyboard and mouse function perfectly on other machines. The motherboard is ASRock P4i45GV (5.0), with a Celeron. I've used the...
Nov 11, 2009 | Asrock P4I45GV R5 Motherboard
USB ports no longer working
After all done,
Did you think of replacing motherboard?
Feb 17, 2008 | Computers & Internet
Keyboard intermittent
There might be a problem with the keyboards PS2 port. You can bypass the PS2 port all together by buying a PS2 Y-adapter to usb port. This Y adapter will allow you to plug your PS2 mouse & keyboard into it and than you plug the other end into a free usb port. You do not have to plug the PS2 mouse in if you do not want to. Just plug in the keyboard. If your keyboard functions than there is a prolem with the keyboard's PS2 port. The PS2 Y-adapter to USB runs about $12.00 to $15.00. You can find one at Wallmart.
Jan 07, 2008 | E-Machines eMachines Desktop PC
Asrock Z68 PRO3 LGA 1155 Intel Z68 HDMI SATA 6Gbs USB 30 ATX Intel Motherboard Logo
14 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
