Philips 42pfl5432d will not turn with remote, I have to unplug power chord and plug back in and press power button to turn the tv on. sometime no picture just sound. I have to keep repeating until tv turns on.
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Power supply regulator board [SMPS] fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Feb 17, 2014
SOURCE: AKAI LCT2785TA TV does not turn on
look closely at the electrolytic capacitors in the power supply. If you see any with the tops bulging out, replace them. Especially the 1000mfd caps labeled EC9, EC10, EC18, EC19, EC20
Posted on Sep 22, 2008
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
  • 61 Answers
SOURCE: TV freezes at "Philips" screen
a professional. -These electronics go threw a self diagnostic when they start up, normally they turn off when they find a problem.
Posted on Jun 01, 2009
dave1645
  • 834 Answers
SOURCE: My polaroid TV will turn on but there is no picture or sound
blown caps in the power supply a 470m at 16 volt cap it will be puffed up
Posted on Sep 18, 2009
Testimonial: "You were right. It was blown 1000uf caps. Great job. Thank you very much"
My tv won't switch on?
Sometimes this procedure will get an electronic device to turn back on. First check that your power cable is seated in the back - remove it and plug it back in if you can just to be sure. Then unplug the power cord from the wall. Press and hold the power button on the TV (don't use the remote) for 15 seconds. Plug it back in and try turning on the TV using the power button (not the remote).
If that doesn't work - try leaving the TV unplugged for an hour or so then plug it back in and try it again.
Good luck.
Sep 02, 2015 | Sansui Televison & Video
Need information on a philips t.v. model 32PT6441/37
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 12, 2008 | Televison & Video
The print cartridge can not move
turn on the printer then try to move it manually..
if it does not work turn it off and try to move the carrriage manually.
still does not work then do following steps...
1) connect printer directly to wall
2) remove the power chord from back of the printer and then press and hold down power button for 30 sec. release the button and plug in the power chord..
3) if still it does not work out then unplug the power chord from the back of the printer.. press and hold the pound(#) and number 6 key together. then without releasing the button plug in the power chord.. once the power chord is plugged in release the buttons.. the printer would align .. if still it does not work then replace the product as it is an issue with the carriage
Mar 26, 2011 | HP Officejet 5610 All-In-One InkJet...
C309a ink level shows low after replacing cartridge with cosco refilled original HP cartridges???
1) remove all the orange tape from the cartridge properly...
2) plug in the power chord directly to the walloutlet
3) unplug the power chord from the back of the printer.. then press and hold down the power button for 30 sec... then release the button.. the plug in the power chord and turn on the printer..
check the ink level...
4) if it does not work press the setup button on the printer >>> press the right arrow and go to Tools >>> clean printhead...
5) after it is done again press setup >>> Tools >>> Align Printer.
after that is done check the ink level again...
if it still does not work follow the next step..
6) unplug the power chord from the back of the printer.. then press and hold the pound(#) and 6 key together.. then withough releasing the button plug in the power chord... after you plug in the power chord release both the buttons... alignment will continue... do not stop the alignment...
after it is done again check the ink level...
7) you can also check the ink level by pressing the setup button >>> Tools >> Display Estimated Ink Levels...
Hope this works for you...
Jan 25, 2011 | HP Photosmart Premium C309A All-In-One...
Remote control work very slowly and sometime do not work
Please follow the troubleshooting steps:
  1. Remove the batteries from the remote control.
  2. Press each button on the remote control twice.
  3. Make sure none of the buttons on the remote control are jammed.
  4. Install fresh batteries into the remote control.
  5. Make sure nothing is blocking the Infrared (IR) sensor on the TV.
  6. On the remote control, press the TV FUNCTION button.
  7. Press the POWER button and other buttons to test the operation.
  8. Try using the remote control at varying distances from the TV.
  9. Power reset the TV by follow the steps:
  • Unplug the television power cord from the electrical outlet.
  • Let the television remain without power for 60 seconds.
  • Plug the power cord back into the electrical outlet.
Jan 09, 2011 | Philips 32PF9964 32 in. Television
Power button will not come on either manually or with remote. Cable is working and power is on the circuit.
I have a Phillips. If you have a menu remote press tv. I panicked when that happened to me. I have RR and if you press the yellow A
and ctr at the top left for about 30 seconds should reset remote.
May 24, 2009 | Philips Televison & Video
Reset power when it 's plug in
as you are getting the error RESET POWER..
turn off the printer..unplug the power chord..connect the printer directly to the wall outlet..and then turn on the printer..if you are still getting the same error message..perform these steps..
1)unplug the power chord from the back of the printer..
2)press and hold the ON button..while pressing the ON button plug in the power chord to the back of the printer..
3)after you plug in the power chord do not release the ON button for 30seconds..
4)after 30seconds if the printer is off, go ahead and turn on the printer..
the solution should resolve the issue..if its still the same please get back would give you some more steps..
Mar 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Magnovox HD2763C401 dead sometimes
MINE STARTED DOING THE SAME THING RECENTLY BUT HAS WORKED WITHOUT A GLICHE FOR 22 YEARS
Oct 30, 2008 | Philips Magnavox 27MS343S 27" TV
Helpme please
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 25, 2008 | Philips 150S4FB 15" LCD Monitor
27 inch Panasonic TAU tv won't turn on, then sparks when you unplug and replug it in
You first need to rplace the outlet if it sparks where the surge protector is plugged in as it should not spark for any reason. then you need to make sure thast its not the outlet causing your problem by running an long extensition corn or moving the set to a differant outlet.
Sep 11, 2006 | Panasonic CT-32G11 32" TV
Televison & Video Logo
Top Televison & Video Experts
