Question about HP Photosmart Plus All In One Printer b210
Open b210 opening printer
Printer does not reconize paper loaded HP B210
try this. the hp way with video- please mail back if this doesn't work
Jan 17, 2015 | HP Photosmart Plus All In One Printer b210
My printer HP photosmart plus B210 series displays error message
>> Remove the print head and gently clean the head.
>> Check is there any obstructions on it.
>> Turn Off the printer for 2-3 minutes and turn On.
>> Re-insert the print head and check the status.
It may help.
Nov 25, 2013 | Computers & Internet
How to clean print heads
Wipe down the printer with Clorox wipes.
Nov 29, 2012 | HP Photosmart Plus All In One Printer b210
Can you print two sided
yes... go to start, click on printers and devices on your computer, right click on the printer you want to use' select properties, then select two sided printing....
Jul 14, 2012 | HP Photosmart Plus All In One Printer b210
Samsung b210 insert sim pls fast soluson sir
sir i want to know the jumper of b210 insert sim problem.
Feb 22, 2011 | Cell Phones
I have just bought a HP Photosmart plus B210 printer. I have installed it ok and it is wireless connected. everything seems ok for printing but when I try to scan to Paint shop Pro 7 or from Word 2003 it...
Hello Carol,
The first thing you want to do is check to make sure the scanner driver is installed properly and working.
If you are running Windows XP or Vista; go to Start Menu \ Control Panel \ Scanners and Cameras
NOTE: For Vista user you must select "classic view" in control panel to see scanners an cameras.
For Windows 7; go to your Start Menu, in the "search programs and files" section (found below "all programs") type in "scan". You will see a result for View Scanners and Cameras.
Now you should see the HP scanner here. If it is not here then you need to reinstall because the scanner was not installed properly. If the scanner is here, right click on it and select Properties. (For Windows 7 you do not have to right click, you will see Properties at the bottom of the window).
In the properties select "test scanner". If this test fails, the driver is not working and you should uninstall and reinstall the HP.
If this test works then the driver is properly installed. HP should have provided you with some sort of scanning software, try scanning using that. You can also try scanning using Windows Fax and scan (for windows 7), Windows Photo Gallery (Windows Vista) or the Windows Scan wizard (Windows XP).
Thanks,
Pat
Nov 07, 2010 | Office Equipment & Supplies
How to unlock samsung B210 sim lock
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } If your phone is blocked. You will have to take it to your nearest network provider outlet to get it unblocked.
If your sim card is blocked. You can go to your network suppliers website, where you can obtain the puck code to unblock the sim.
Dec 03, 2008 | Cell Phones
HP Photosmart Plus All In One Printer b210 Logo
18 people viewed this question
Seeker5211
Seeker5211
