Question about Nikon D70s Digital Camera with 18-200mm lens
Picture is flashing on nikon d70 - Nikon D70s Digital Camera with 18-200mm lens
cammedic
  • 667 Answers
SOURCE: nikon D70 flash doenot fire
According to my information, the camera may need a new flash PCB (printed circuit board). Check the repair service search on this site for someone in your area. The part number for the circuit board is: 1S014-020-1 and runs about 50$
Posted on Jan 10, 2008
SOURCE: Nikon D70
I get the same problem from time to time-generally fixed by removing and reinstalling the CompactFlash Memory Card. I think it is apin problem-I did note a Company, Lezot photo www.lezot.com says it will repair/change the pin connector for $125. This would probably solve the problem.
Posted on Oct 07, 2008
  • 9 Answers
SOURCE: err on the lcd of nikon d70
Most digital equipment has some kind of manual reset. Refer to your camera manual to see if there is a sequence of buttons that will reset to the factory settings.
I had a similar problem with my Nikon D200.
I resolved it by setting the camera to manual mode (any aperture and any shutter speed) and firing the shutter release. Manual deactivates almost all other functions and may clear the error.
Try another battery, memory card, lens to eliminate all possibilities.
Have you looked to see if the mirror is locked up revealing the sensor at the back of the camera body?
Posted on Feb 07, 2009
SGNath
  • 170 Answers
SOURCE: D70 internal flash not firing
Check if something is preventing the flash to pop up 'fully'. Check for some dust or other particles trapped between the flash and the body. Does the screen say 'Subject is too dark'? If so, the flash has not popped up fully.
Posted on Feb 16, 2009
  • 4 Answers
SOURCE: when i try to take
I know of three causes:-
1. The first depends on what type of lens you are using. If you have a lens with a manual aperture setting ring, you need to turn this to its smallest aperture (biggest number) and then move the small locking ab acoss to lock it in this position.
2. Its also possible you have a damaged lens. There is a small tab which fits into the body of the camera and these can be broken. If possible try with another lens.
3. In my case I saw this a few times and it was just caused by the contact between lens and body not being 100%. Tightening lens a little solved it on each occasion.
Hope one of these helps you.
Posted on Apr 26, 2009
My nikon d70 will not regonize the sd card and gives a format signal
The D70 uses CF (compact flash) cards - I hope you are simply misnaming the CF card. But, if you did use an SD card, it would explain how you could have bent a pin.
I understand that Nikon is moving away from CF cards because of the 'bent pin issue' as well as the limited capacity of the CF card.
So, first I would try a CF card (any size) in the reader. If it still doesn't work, then I think you might check with a camera repair shop. If it is a bent pin, they can fix or replace the card reader. Note that the D70 body can be replaced with an EX rated used body for under $90 at https://www.keh.com/shop/nikon-d70-6-1-megapixel-digital-slr-camera-body-only-9782.html
Thus, I wouldn't pay $100 to have the reader fixed unless there are extenuating circumstances. Good luck.
Feb 06, 2018 | Nikon Cameras
Why does my pictures on my nikon D70 comes out balck and withpink horizontal lines
Do you see coherent photos in the camera's rear display when the CF card is still in the camera?
Aug 16, 2014 | Nikon D70 Body Only Digital Camera
Is this flash to use on a nikon D70 camera. It works on a F70 but on a d70 its not functioning
The Achiever Flash 630AF is for Film Cameras and will not work properly on the Digital D70 camera.
Nov 29, 2010 | Achiever 630AF for Nikon TTL Flash
Speedlight SB-600 TTL Flash: When I set my SB600 (mounted on D70) to TTL or TTL...
the sync speed for the sb-600 is onlt 1/200 on most cameras i think so if your shutter is faster then that then all you will see is black/ the curtans behind the shutter.
basicly just try again with a slower shutter speed
May 07, 2010 | Nikon Speedlight SB-600 TTL Flash
I cannot get my Nikon D70's flash to activate
I assume this is no longer an issue, given that more than a month has gone by without a response to my query.
Apr 07, 2010 | Nikon D70s Digital Camera
Nov 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D70 flah not working, used to
I had this problem a while back, but was fortunate to get it fixed under warantee as it was less than six months after Nikon repaired my D70 for the "blinking green light of death" fault.
I'm afraid this is a repair job for Nikon or an autorized workshop. It is most likley the flash tube. If you fancy taking your camera apart (I warn you it would be a fairly difficult job) then please be aware that you may get a significant electric shock from the flash capacitor, which will remain charged.
Feb 18, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Nikon d70 flash stopped working
Well, you are not going to like my answer. The troubleshooting guide for the D70 says it could be 1 of several PCBs (printed circuit board) being faulty or the connecting FPCs (flexible printed circuit).
You'll need to locate a local repair person or use the reapir service search here on Fixya. Nikon USA repairs will be $$$$
Feb 15, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Nikon D70 flash doenot fire
Sep 21, 2007 | Nikon D70 Digital Camera
D70 USB setting issue
Users of Windows 98SE, Windows ME, Windows 2000 and Mac OS 9.x may experience problems trying to download images from the Nikon D70 using Nikon View. Initial shipments of the D70 have the USB option in the "Set up" menu set to PTP - Picture Transfer Protocol. PTP is only compatible for downloading images with Windows XP and Mac OS X. To solve this issue please set the USB menu option to Mass Storage and then connect the camera to the computer. The D70's card will then mount like a removable disk and Nikon View will be able to transfer images
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon D70s Digital Camera with 18-200mm lens Logo
15 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
