Question about Sony CDP-C445 5-Disc CD Changer
Sony cdp-c250z 5 disc cd player won't open up, tries to but just keeps making a jmping noise like 2 discs possible together??
SOURCE: player reads no disc
make sure you are putting them in correctly
Posted on Jan 27, 2008
welcomejee
  • 10594 Answers
SOURCE: My Power Button is pushed all the way in, can I repair it myself?
Below is an exploded view of Power Switch and board section and I hope will help you to fix power button issue.
2e010a8.jpg.
Power switch board has one screw to open it and you will remount power button and put back in power board in unit.
Posted on Feb 19, 2009
  • 35 Answers
SOURCE: CDP 265 5-disc player
If the disc is actually loading but won't read, try cleaning the laser lens with a cotton swab. Unplug the unit and remove the cover to access the laser. Spray a small amount of glass cleaner on the swab and gently wipe the lens of the laser assembly. Use the other end to dry it and remove excess dust. The only way you can tell if the disc is loading is to remove the top cover and observe if the disc at least loads and spins. If it does, try that procedure.
If the disc doesn't come up to the loaded position and spin (spin the disc by hand to confirm this), your gears may be out of alignment. Take the disc out, and use a screwdriver to manually turn the gear from the bottom of the unit. The gear should be visible through a small hole in the bottom toward the front of the unit. Take a slotted screwdriver and turn it until you see the laser assembly come up to the clamp that holds the disc in place. You may have to force it slightly if the gear has skipped a notch, it might "pop" as it goes past the tooth. Make sure you are turning it in the same direction as it moves when loading a disc! Once you do that, the laser should come up completely and be able to clamp the disc and read it.
Posted on Mar 02, 2009
smarthome2
  • 1114 Answers
SOURCE: Sony CDP-C225 will not read or play cd's
Try running a "Laser Lens Cleaner" thru it, preferrably one that uses fluid. You can purchase one at just about any retail store for 15-20. Good to have and great preventative maintanance. If that does not work, you need a new transport, they do not repair or align lasers. Too expensive. The replacement is 100-150 with labor and a new one is under 200. My suggestion would be if the cleaner does not work replace it and keep the new one clean. CD/DVD/PC etc. all can and should be cleaned 3 or 4 times a year. Best preventative maintanance you can do. Hope this helps
Posted on Jun 24, 2009
AREA51S4B
  • 30 Answers
SOURCE: my cd player does not recognize discs.
this could be several things , one would be the cd spindle motor, needs to be cleaned, if it starts out sluggish and then reads..it needs to be cleaned..this can as simple as spraying some contact cleaner into the motor
Posted on Jul 28, 2009
How do I fix my Sony cd player with 5 disc carousel changer in which the door keeps opening up? When I close the door the carousel moves around a bit but then the door opens up again.
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
I have a Sony mini hifi stereo(pixy) and when ever I close the tray it continues to ... my cd player drawer opens ...
ToddFun.com: Repairing a 5 disk CD player - YouTube
? 10:09
https://www.youtube.com/watch?v=aKE1CbHOBVo
Nov 23, 2011 - Uploaded by Todd Harrison
ToddFun.com: Repairing a 5 disk CD player ... Sony CDP-CX300 300 Disc Changer Belt Repair and ...
Jan 01, 2016 | Sony Audio Players & Recorders
Sony 5 disc cd player won't play 5 cds but plays just 1 disc
Check the mode of operation. There can be a setting where it just plays one disc. Random or mixed will give you more songs to get to other discs.
Dec 26, 2012 | Sony CDP-CE375 5-Disc CD Changer
Sony cdp-c215 wont read disc removed cover disc doesn't spin
The pladder motor that spins the disc is open, or the laser pickup is defective, the whole laser assembly would need to be replaced, not cost effective to repair cheaper to buy.
Apr 16, 2012 | Sony 5-Disc CD Changer with SA-CD Playback
Disc(s) jammed in sony 5-disc player--eject won't work
There are 6 or 7 phillips head screws that keep the top on; remove them and pop the top. This will give you access to all CD's. Remove them all, then plug the unit back in and press the open close button and check for normal operation. If it still wont open, it's broken a gear and needs to be serviced. You may consider replacement of the unit if inoperative, the replacement model is priced at $129.00 and a repair would probably cost the same if not more. If you need further help, post a comment and I can help you further.
Dec 22, 2009 | Sony CDP-CA70ES 5-Disc CD Changer
Five discs keep spinning; will not stop. Cannot open drawer
they button maybe stuck or the switch that open the cd player sticking try to push button to open then pull on drawer not to hard u brack then see if u can clean swith
Mar 22, 2009 | Sony CDP-C445 5-Disc CD Changer
Sony CDP-C235 CD Changer Dirty Laser Problem
Please replace optical block (laser) of CDP-C235.
It is available in Part Store.
Jan 15, 2009 | Sony CDP-CE375 5-Disc CD Changer
113 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
