Question about Mastech 19-range Digital Multimeter Dmm Mas830b
Does the MAS830B have a circuit continuity function, please?
I wish to check electrical circuits and light bulbs on a Setra Coach with a 24 volt electrical system.
    New Friend:
    Problem Solver:
  • 16 Answers
What you need is either continuity, the symbol for that is a solid arrow, or you can check the resistance by using the ohm's setting. the only difference between the two is that, when using continuity setting if you are reading it, it will beep if in fact the device you are testing has continuity. with ohm's no beep, but with ohm's if you read ol. or ul. that means infinity, meaning no continuity. so whatever the specs are for the device in question that you are working on, numbers will come up. hope this helped
Posted on Feb 24, 2014
Back running lights won't work, blinkers and brakes both work changed the fuse and light bulbs any suggestions why the tail running lights won't run
Would need to test power from the headlamp switch . Go to http://www.bbbind.com/free_tsb.html free wiring diagrams. Enter your vehicle info , year ,make , model an engine . Under system click on lighting ,then under subsystem click on external lights .Then trace out where the tail lamps get power , do you know about automotive electrical circuits ,how to read a wiring diagram . Go on youtube check out videos on basic automotive electrical trouble shooting , how to do voltage drop testing an how to read wiring diagrams . Then get yourself a DVOM - digital volt ohm meter . Then test the circuit ! That's how automotive electrical problems are found .
Apr 08, 2016 | Cars & Trucks
How to fix a 2009 Honda accord brake light on the drivers side. I replaced the bulb on both side but still the brake light doesn't work on the drivers side.
Go to www.bbbind.com for a wiring diagram of the brake light circuit , get a DVOM - digital volt ohm meter an trace out the circuit . You know the right side works so the brake light switch is good . Take your volt meter an check to see which part of the circuit is bad . At the brake light bulb socket test for voltage on the power side , if battery voltage is there,then check ground side . I forgot you need to have some one press on the brake pedal while testing . You could have a bad ground or an open on the power side of the circuit , you need to find the wiring harness that goes to the back of the car , check connectors ,wiring etc... There is more to electrical trouble shooting then just replacing parts . Watch this video on voltage drop testing . Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Oct 28, 2015 | 2009 Honda Accord
The lights in my 2000 25ft Thor Tahoe slideout are not working how do I troubleshoot
use a meter to check the sockets for voltage either 110acv or, 12v dcv
if dcv it's is your batteries or inverter not supplying power check with a meter set on dc volts; if ac check your circuit breakers with a meter set for ac volts if these are fine then replace switches
Nov 26, 2013 | Thor Motor Coach RVs
Dryer light bulb burned out
follow this steps and fix it. God bless you
Light Socket
The light socket can get corroded or a wire connection can come loose. You will need to remove the front panel to access the housing on most dryers.
Door Switch
If your dryer has an interior light, it probably uses a standard 40-watt appliance bulb, but check your owner's manual to be sure. If the bulb is good but the light won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. To check the door switch check for continuity. You should have some when the door is closed and none when the door is opened.If not replace the door switch by removing the front panel.
It blows fuses or trips the circuit breaker
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. Loose connections on the power cord cause failures and or fires. This can be checked with the dryer unplugged and removing the service cover and visually check for burning and mechanically check for tightness.
If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jul 09, 2013 | GE Profile Harmony DPGT750EC Electric...
Dayton heater mod 2yu59 is not heating up?
Need to check the low voltage circuit for 24 volts, the 480 volt to 24 volt transformer may have a circuit protection reset or fuse installed. All the 3 phase electric heaters use a low voltage control circuit for operation of relays (24 volt coils).
Nov 22, 2011 | Dayton 2YU59 Electric Heater
Brake lights don't work. Replaced bulbs, checked
Yes, you need to of course check the voltage coming into and going out of the brake light switch, if 12 Volts are there going out and coming in while pressing on the brake pedal, your brake lights aren't getting a good ground or there is a break in the circuit between that switch & the lights.
On occasion the tail lights will work with a weak ground circuit where the Brake lights won't. Best way to determine this is to just hook up the 12 volt tester to the Brake light hot wire & there at the bulb ground, then in an area away from the bulb that has a good possibility of contact/ground.
Really that's it, if the 12Volts is getting to the bulb but it isn't lighting, if you aren't getting the voltage there and the brake switch is hot on both sides when pressed, the break in voltage will have to be traced from that switch to the tail light to find the problem.
good luck.
Feb 22, 2010 | 1999 Chevrolet Silverado 1500
Installed driver side headlight worked, an hour later both main headlights went out, when I went to check lights noticed that there was another headlight behind a little chrome cover that was out, could...
reasons bulbs keep blowning.your head light bulbs is halogen bulbs.dont touch with bare hands.the oils on your hands will make them over heat and blow.so use clean gloves on your hands when replacing the head light bulbs.if all is good.check alternator out put.it could be overcharging causing too much current flow through electrical circuit blowing out bulbs.use a digital volt meter hook it battery with car running battery voltage should be 13.5 to 14.5 volts. if it is 15 to 16 volts too many volts.alternator is faulty.due to lock out features turn off radio before disconnecting battery cables so you wont lose radio playing code.
Nov 24, 2009 | 2004 Honda Accord
My fredge rm 2652 not working
You need to check your fuses on the fuse panel inside your coach. The frig will not operate on gas or electric without 12 volt power to the frig circuit board.
Feb 03, 2009 | Dometic RM2652 Refrigerator
Mastech 19-range Digital Multimeter Dmm Mas830b Logo
560 people viewed this question
Top Mastech Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Paul Woodward
Are you a Mastech Measuring Tool and Sensor Expert? Answer questions, earn points and help others
