Question about Ovens
Gaggenau eb180/181-610 oven will not heat up, even on automatic mode or manual. The heat up light will not turn on.
SOURCE: DOUBLE OVEN,GAGGENAU
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Posted on Dec 19, 2007
  • 441 Answers
SOURCE: Older Gaggenau double oven unit...heating elements stop working
Shut off te breaker for the oven for an hour then turn on again and it should come back on, just so you know Gaggenau appliances are super high end, if it needs service it will cost you
Posted on Jul 10, 2009
milten1
  • 1304 Answers
SOURCE: oven light (surface heating) won't turn off
it is normal for it to stay on until the glass gets below 110 degrees it is for safety reason
Posted on Oct 05, 2009
SOURCE: Gaggenau Ed 220/221 Error Code F 70
I had the same fault F70. Poured several liters boiling water no result. I decided to take the oven out the kitchen and put on the table. Be carefull, its edges are sharp. You need to disconnect water supply, first close the tap, then remove the water pipe from the oven by hand. Remove also the drain pipe from the sewage connection. You cannot detach it from the oven. Unplug power supply. Then start unscrewing the top panel. Once removed you can unscrew also the side panel left side (by looking at the oven from the front door side) and finally remove the back panel. You will need a special screw driver as the screws are star type.
I found out that there was some little water on the bottom panel of the oven. There is a safety sensor which is in contact with the bottom panel on the left side of the oven near the electronic board.
If this get wet, the faul code F70 appears.
Also some water was in the hole of the level sensor in the pump chamber next to the other sensor (white plastic box)
So dry all the water with the help of kitchen paper and finally with hair dryer.
Put back all teh parts and voila', it works again.
Posted on Sep 15, 2010
ZJLimited
  • 17970 Answers
SOURCE: I need a manual for my Gaggenau 378-610 wall oven. I've tried the company site as well as manuals online, and it's not available.
I suggest visit Gaggenau Site or call Gaggenau at: 800-828-9165
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Posted on Nov 24, 2011
Gaggenau fan oven lights and fan are on, but there's no heat and the triangular heating signal light by the dials doesn't light up. What could be wrong? 3900W, 400V, 50Hz. E-nr EB140210
this could be a simple and easy thing check your clock is not in auto mode it need to be in manual mode ok if the clock is ok then its your heater element has gone ok
Oct 15, 2012 | Ovens
Gaggenau EB944-110 Pyrolytic oven stuck in some kind of mode after power outage. Oven worked perfectly but there was a mains cut. After restoring power it appears to be stuck in some kind of strange...
Yes this could be the problem. If you can't set the timer to manual mode the oven will not work. Turn the oven to on so that when power goes to it you will see the oven indicator light come on. Play with the timer buttons until the oven indicator light comes on. If it won't work you probably need a new timer.
Feb 11, 2011 | Ovens
Changing from C to F temperature on Gaggenau EB
your oven has no ability to change from celcius to fahrenheit here is the link to the manual:
http://www.gaggenau.com/AP_en/products/product-detail.do?contentId=cc4fb38a-ea89-4593-a268-95ea093f9d3f
there might be a secret mode but only the manufacturer might know that.
all dealers are in other countries.
Sorry I could not resolve this issue for you.
Feb 14, 2010 | Gaggenau Ovens
Large oven doesn't heat up. Heating element gone??
Hi, In a word yes. As for who you can contact, I'd suggest only an authorized b/s/h (bosch/thermador/gaggenau) service provider. I used to be one for over 10yrs. but now work exclusively for sears...I'm not sure if I made a good choice or not yet, lol ! I digress. It is quite possibly not even the element as the gaggenau have cut-outs (they are actual thermal fuses that cannot be reset, they must be replaced) built into the bake circuit that can open often times. This of course unless you're certain the bake element is defective. Check your local directory under appliance service or a vendor who sells that line may be well equiped to direct you for quality service in someone they trust and are proficient. Hope that helps, good luck. macmarkus :)
Nov 10, 2009 | Gaggenau EB294/295 Electric Double Oven
Jul 10, 2009 | Gaggenau Ovens
Door locked after power surge/failure
The question here is how long did you leave the breaker off? Gaggenau ovens have a memory and I always advise turn the oven off for 5 mins before turning the breaker back on. Give that a try. The first thing the oven does when the power is reapplied is go thru a test phase which included locking and unlocking the door. The key symbol will go on and off during this. Sometimes you have to also can run a self clean then cancel it to reset the lock. This works as well.
Jan 06, 2008 | Gaggenau EB270 Electric Single Oven
good luck
Dec 16, 2007 | Gaggenau EB 270/271 Electric Single Oven
Ovens Logo
41 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
