Question about Music
Peavey problems 115D keeps blowing fuses
Does this amplifier have a fuse?
Fuses check good. Transistors omn bad.
Oct 01, 2014 | Music
Peavey amp
Most likely a power supply problem. Take it to the repair shop.
Apr 06, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey tnt 115 blowing fuses
your either overloading something cause that's what pops fuses. My guess is that what your plugging in or into has a ground issue. I'm wondering if it does it with nothing plugged in at all. I would say if you have nothing in and it does it, you need to find where the ground issue is. that's my best guess
Feb 20, 2014 | Peavey Electronics Peavey Tour Tnt 115...
My Peavey Envoy 110 won't turn on
Most likely a blown fuse, but the real issuse would be why is blew the fuse. If you replace it and it quickly blows again, take it to a repair shop.
Jan 31, 2014 | Peavey Envoy 110 Amp Combo
Very unlikely, sounds like it's faulty. Was this on plugging in or were you using the amp, and if so doing what? What is your supply oltage?
Jan 09, 2014 | Peavey Electronics Peavey Tour Tnt 115...
One side of my peavey xr86000 power mixer blew a fusework
Any unit that blows fuses needs to be serviced. Do not keep putting in fuses only for them to be blown again. Each time you put in a fuse and it blows, it will create more damage to the amplifier.
Jan 14, 2013 | Peavey XR 8600D Class D Powered Mixer
Peavey Vyper Tube 120 keeps blowing fuse
You are either trying to: (A) push it too hard, (B) using the wrong type of fuse -- should be a "Slo-Blo" type, or (C) it has internal shorting or voltage modulation and requires service.
Jan 11, 2013 | Music
Why does the 1.6amp fuse blow when the amplifier is switched on?
The owners manual shows a AC fuse for the 8300 as 8amp / 250 volts but doesn't show an external fuse holder for the 8600d. It's unlikely that the 8300 would use a 8amp and your 8600 a 1.6 amp. Double check your original fuse values.
http://www.peavey.com/products/index.cfm/item/701/117405/XR%26nbsp%3B8600D
Oct 25, 2012 | Peavey Xr 8600 8 Channel Powered Mixer
Music Logo
18 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
