Question about Kocaso 7" Capacitive Touchscreen Tablet Android 4.0
Kocaso m736 won't charge
My Kocaso m736 won't charge. New charger--won't work. Connect to computer with USB cord--won't work. It will turn on to show dead battery, then automatically turns off.
    Master:
  • 680 Answers
Sounds like you may need a new battery.
Terry
Posted on Apr 02, 2014
2 Suggested Answers
SOURCE: Drivers for M760S
Take it to a computer worker people!!!!!!!!!!
Posted on May 13, 2013
How can I change the battery in m9100 kocaso
Try the follow to see if it will fix it:
There is a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
After performing the power reset on the device the device will behave in one of the following ways:
1. The tablet will turn on like normal.
2. The tablet will show the battery icon only.
3. The tablet will show nothing on the screen at all.
All of these are normal for the device and should not be cause for alarm. If the device still fails to power on after being left on the charger for 4-6 hours,
Then most likely the battery will need replacing.
Here is a link to where you might be able to get a new battery:
Replacement 4000mah Battery for Kocaso M9100 M9000 9 MID All Winner A13...
Jan 23, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
How to hook up my key board to my kocaso m736
The M736 only accepts USB keyboards.
It should work as soon as you plug it in to the OTG socket.
Jul 12, 2014 | Kocaso Tablets & eReaders
Trio stealth G2-9 battery life will not charge
It's possible your charger is faulty. If your unit can charge with a USB cord through a computer try that. If it charges then your charger is faulty. The charger can be tested with a voltmeter by someone knowledgeable. The other problem possible is that the charging receptacle is faulty. That would show up if the USB method doesn't work. If the charger is o.k. then your battery won't hold a charge and needs to be replaced.
Mar 20, 2014 | Mach Speed Trio Stealth G2 Tablet -...
HOW TO UNLOCK A M736
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
Jan 28, 2014 | Kocaso Tablets & eReaders
Kocaso M736 is stuck on the Android screen
Support Troubleshooting Guide
Jan 23, 2014 | Kocaso M730w 12ghz 4gb 7 Capacitive...
Kocaso M736-how you I set date and time
how do you change the date and time on a kocaso-m736
Sep 22, 2013 | Kocaso Tablets & eReaders
Kocaso 7" Capacitive Touchscreen Tablet Android 4.0 Logo
88 people viewed this question
Top Kocaso Tablets & eReaders Experts
CrisO
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
