Question about Ski-Doo MX Z 50TH Anniversary 600 H.O. E-TEC Winter Sports
Rough running when worm up - MX Z 50TH Anniversary 600 H.O. E-TEC Ski-Doo Winter Sports
    New Friend:
  • 3 Answers
Winterize your machine. Winterized mine it quit running rough, oil and coolant were frozen. Block heater, in-line coolant heater, battery heater might help
Posted on Feb 21, 2014
I have missfire in #4 cylinder 2000 doge neon
I'm not sure that is a valid trouble code for your car. The code for Dodge is for a wastegate solenoid which is normally used on turbo engines.
The miss could be ignition, fuel, or something mechanical.
Feb 13, 2013 | 2003 Dodge Neon
My Chevy 2500, 2001 runs rough when it cold outside
It can be issue with low fuel pressure,the fuel pump is getting old both needs to be checked.Also get the IAC valve checked.
Go through the related help links with similar problem,it may help:---
Click the links below:---
Engine Idles Rough and Dies? http://whatisbyme.blogspot.in/2012/05/1994-lexus-es300-engine-idles-rough-and.html
van idles rough? http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
runs lean and idles rough? http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
Car still runs Rough after tune up?
http://howtobyme.blogspot.com/2011/12/car-still-runs-rough-after-tune-up.html
2006 kia rio runs rough http://technoanswers.blogspot.com/2012/10/2006-kia-rio-runs-rough.html
Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed? http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
Rough idle, staling and Erratic shifting? http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
These details will help.
Thanks.
Nov 06, 2012 | Cars & Trucks
MY kitchen Aide mixer was running alittle rough /loud and now has stop completely. It is approx 24 years old and has never had any problems. It is hard to find a local repair [place. any suggestions
Two things you can do for a 24-year old machine:
1. Replace both motor brushes (Black large plastic Caps on each side
of the Moto Housing). Without these, the motor wouldn't even run.
2. Replace the Worm Gear (the cause of the Rough Loud noises)
Download a copy of the Repair Part List from Kitchenaid.com for
your model KSM90.
Also don't forget to tighten all the screws inside the mixers and use
fresh Kitchenaid Grade Food Grease for all the gears.
Jun 21, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Car idles rough in park also runs rough in overdrive
Sometimes a rough idle like that is a fuel filter. As you've already done the plugs and wires the fuel filter would be my next bet.
Mar 15, 2010 | 1993 Buick LeSabre
Hard starting first time and ideling rough RPM jump up and down about 500 sometimes when it's put in reverse to exit the garage it stalls. It also smells of gas when started. I have replaced all the...
i have a 1986 chevy corvette, when you fist start the motor it idel fine, when it wormes up, it ideling rough and RPM jumps up and down, and you can smell gas when you fist statrt it but there is no leaks,also when your driving about 45mph it puags down until you push it and then runs fine. please help me with this issue.
Sep 08, 2009 | 1990 Chevrolet Corvette
Car trouble
Its because that the engine is very cold, try to worm it up more time before you start driving.
Jun 14, 2008 | 1999 Daewoo Lanos
Winter Sports Logo
356 people viewed this question
Top Ski-Doo Winter Sports Experts
ptpumpman
David Harrelson
David Harrelson
Noel Bennett
Level 1 Expert
Are you a Ski-Doo Winter Sport Expert? Answer questions, earn points and help others
