Indesit faults does not spin
My indesit wixl143s, fills with water normally but immediately it drains. washing movements do not start. When manually set to rinse and spin cycles it works.
I would like to know is there any fault code?
Identification of the error code using the 4 LEDs. One or more different combinations of LEDs indicates the failure.
25889772-23mqg50qavgoaobxweiobkxp-5-0.jpg Dado
Oct 02, 2015 | Indesit Washing Machines
Iwde7145k indesit still going into f13 fault even in spin mode
f-13 is a taco fault its needs a new motor possible windings on motor are shorting out if need to check get back in touch and i will send link of way to check both from you tube
Jun 27, 2014 | Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Indesit iwe8123 not spinning
Its an old belief that the motor is at fault when a machine doesnt spin on full speed.
Most of the time its because its not emptying properly. Firstly check the filter for any blockages and if thats clear unplug the machine and tilt it over so you can see the pump. If your not sure which is the pump then follow the drain pipe in from the back and what that connects to is the pump. You will have to remove the pipes from that and make sure they are clear and also the pump if possible. If thats all good then it may be a carbon brush problem in your motor thats at fault. That is an easy job even for a novice. If you get no joy with the pump then let me know and i'll talk you through that too.
Nov 11, 2011 | Indesit W 123 Front Load Washer
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Indesit WIE127 Washing machine which flashes error code F08 when it goes to spin. Can this be fixed. What do I need to do to mend it?
I HAVE THE FAULT CODES FOR SOME INDESIT MACHINES THEY ARE ONLY SUPPLIED TO THEIR ENGINEERS BUT A MATE OF MINE WORKED FOR INDESIT/HOTPOINT (ONE COMPANY NOW) UP UNTIL A MONTH AGO , HOWEVER ,THEY ARE AT WORK & I WONT BE IN UNTIL FRIDAY IF YOU CAN HANG FIRE UNTIL THEN I MIGHT JUST BE ABLE TO HELP YOU OUT!
Jul 30, 2008 | Indesit Washing Machines
Indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Mar 28, 2008 | Indesit W 123 Front Load Washer
Washing machine fault
lg trom showing E and on display won't drain
Mar 26, 2008 | Washing Machines
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
