Question about Element Electronics FLX-3211B 32 in. LCD HDTV
Cant get digital cable channels - Element Electronics FLX-3211B 32 in. LCD HDTV
How do I get channels
ok,if you have a subscription to cable,you will have a cable box,you will only need to put your tv on cable and ch 3 or 4 on your tv,you dont need to search for channels,if you dont have a subscription,then you are trying to pick up over the air channels,they are called digital channels,you will need a digital tv antenna and your hdtv,you will change the settings on your tv to air or antenna,then you can search for digital channels,there are no more analog channels like we had when we are kids,they are all digital and dont need to be tuned in,if you still cant get channels please have someone help you.
May 19, 2015 | Polaroid TDAC-02212 22 in. LCD HDTV/DVD...
Samsung lcd tv problems
TV IS OK RETUNE THE SET TUNUNG CABLE CHANALS DIGITAL AND ANALOGUE IT IS ON SET UP MANU
Sep 07, 2014 | Samsung Televison & Video
Jvc hd56g786 channels stuck on digital cant get them changed to analog
Using the television's remote control, enter the user's menu. Search for video input and change from cable to antenna. If still experiencing difficulty, visit the JVC website and download the owner's manual to learn the procedure of changing the video input type and deactivate the television's digital decoder.
Dec 22, 2013 | JVC Televison & Video
Recording on a STB and being able to watch a DIFF channel.
It is possible to record a channel and watch a second channel. If your cable vision has digital-only signals, you will need a Digital tuner or a second cable box.
If your cable has conventional channels still, you can buy a splitter and run the cablevision to the TV and the CableBox at the same time.
Switch to the TV tuner, you see cable.
Switch to the recorder (connected to the CableBox) and you see what you can record.
Mar 28, 2010 | Televison & Video
Rca hdtv channel changed by mistake
RCA channel setup and selection is not easy to understand. You may try to add channel 3 on the add/remove channel section. If that doesn't work try pressing the input button. Good Luck.
Feb 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
UNABLE TO VIEW ITV CHANNEL 4 OR SKY SPORTS NEWS ON MATSUI TV
try tuning tv in another room, if it works it is then your cable or socket, try the cable next. If it wont tune its a faulty set.
May 26, 2009 | One For All URC-3445 Remote Control
I have a durabrand 1907a and cant' get digitalchannels, please advise how I can get all digital channels? thank you duraproblem
Go into the CH SET menu. Go to the TV CABLE line. Set it to TV for antenna reception or CABLE for cable without a cable box. Go to AUTO CH MEMORY. Press the VOL + button to start the channel search. WAIT until search screen goes away. Check ALL your channels. Hope this helps.
Feb 17, 2009 | Durabrand DU1901 TV
3 Digit Channels
Make sure the tuner is set for Cable and not broadcast...accordianman
Aug 04, 2007 | Hitachi 43FDX01B TV
Element Electronics FLX-3211B 32 in. LCD HDTV Logo
18 people viewed this question
Top Element Electronics Televison & Video Experts
Josh Whitehead
Josh Whitehead
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
