Question about Freezers
Kenmore 25314922101 not powering on
Pug in to a good outlet, no power, clicking or lights
  • Tim Stoltz
    Tim Stoltz Feb 23, 2014
    It does nothing, no sound or tripping
    New Friend:
  • 41 Answers
HI
Does it trip your mains? If yes disconnect and replace your defrosting element.
Posted on Feb 23, 2014
Chest Freezer Stopped Working 14 years old
The first thing you want to ensure is that power is actually getting into the unit. i suggest that you do that by plugging a night light into the outlet and verify the presence or power. If no power, check your breakers. If power is present note that A chest freezer has only two working parts; the start relay that help the compressor start and a compressor. If you are getting clicking sound, your start relay may be out (inexpensive if you can buy it and install it yourself) or a bad compressor. if you need to call a tech for the repair, you may be able to purchase a new chest freezer that now consume HALF the power and for less than cost of repair.
Mar 02, 2014 | Kenmore 12.8 cu. ft. / 362 liter Chest...
I have a kenmore chest freezer model 19502/19702. I had it unpluged for 5 months. When I plugede it back in the power light flickers. Tryed other outlet. Other then that it seems to be working
We purchased this same Kenmore chest freezer model 19502/19702 in 2010. In less than 2 years the compressor quit. If you do a search on this model you will see dozens of complaints. Don't waste your time or money on this freezer.
Apr 16, 2012 | Kenmore Freezers
Freezer not working
  • Make sure the freezer is plugged in
  • Check for a blown fuse or tripped circuit breaker
  • Test the power outlet for voltage
  • Inspect the electrical cord for damage
  • Eliminate use of an extension cord, if any is being used
  • Check the outage votageIf power is reaching the electrical outlet, trace the freezer wiring and test components as you go. Either there is a short, which must be located and repaired, or the freezer has sustained electrical damage.
Thanks.
Jun 26, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Doesn't draw power. Tried connecting to another outlet without result.
Try turning everything off including the temp settings, then plug it in and reset your temps. Good luck. If no go, It may need a start capactor.
Nov 19, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
It will not stay going
the compressor sounds as though it is buggered
May 02, 2009 | Kenmore Freezers
Freezer wont freeze - digital display has no display at all -
Melanie--
Because this occurred as a result of a power outage, you need to check that the outlet is OK. Plug something in the outlet like a lamp and see that it works normally. If that is OK, check the display for a light bulb that is burned out--incandescant bulbs do that occasionally in a power outage. If it is an LCD or LED display, the power supply is bad on the display board. Is the motor humming and making normal noises?--and your freezer is just not cooling? If no motor noise, look for a reliable and trustworthy appliance repair person. If the damage is costly, try to pursue a claim with the power company.
Dave M
Dec 17, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright - wont defrost, runs continuously and wont freeze properly
well don't be surprised, these electronic fridges run on dc electronics also and are sensitive to power surges. is this the freezer because there's no thermostats just the limit control. use a surge protector on the outlet to protect the electronics. if your still having problems get the limit sensors changed first (if applicable). if you want to go the safe way, I'd consider buying a surge protector and connecting it to the power.you can e-mail me with any questions @ hvac.tech7872pr@gmail.com
Jun 14, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer power problems
The on/off switch, power cord, outlet, based on the little info. I have, sounds like a power problem.
Dec 25, 2007 | Freezers
My kenmore upright freezer quit working after power outage
is there any lights on in the freezer? try plugging the freezer into an outlet you know is working. there is no "reset" on the freezer so if lights are on and it still isnt working it could possibly be stuck in defrost or the thermostat could be stuck in the off position.
for the defrost problem: pull freezer from wall and look in the compressor area and you will see a control under the unit left of the compressor. using a flat blade screwdriver advance the timer clockwise a few clicks and it will probably come back on. if that doesnt work lets check the thermostat.
thermostat stuck: this is easy but you need to check def timer first. using the handle of you screw driver tap the thermostat knob firmly. if the contacts are stuck open when you hit it the contacts will release and the unit will come back on.
hope this helps..
Dec 13, 2007 | Freezers
Freezers Logo
74 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
