Question about Cell Phones
How do I reset oil change light on 2007 suzuki burgman 400
I changed oil & filter.and change light is still on
  • 67 Answers
SOURCE: oil change instructions for atv suzuki kingquad
you can buy a fram filter at Fleet Farm My quad runner 500 calls for 10W-40. What I do is warm the engine a little then pull the plug to drain it then R&R the filter and refill. run it for a minute and recheck the oil level.
Posted on Apr 10, 2009
SOURCE: suzuki burgman 650 won,t change gear
I had the same problem until I found out that when you put the Burgman on it's center stand, it pushes a small round metal pin (spring loaded or something similar) that limits the Burgman to 1st gear only. Some kind of safety feature, I guess. You can see the little switch if you put the bike on it's side-stand, get down on the right hand of the bike and look where the centre stand meets with the body of the bike. My switch was stuck in permanent "on" so I just pulled the pin to it's full extention with a pair of pliars, then cut it with a junior hacksaw.
Posted on Jun 03, 2009
SOURCE: how do I change a headlight on a Suzuki Burgman
you reach under the front of the scooter between the headlight and the fender. find the wire that goes to the connector of the headlight. it is directly behind the headlight. unplug the connector, pull the plug off the headlight. remove the rubber cover/boot off the back of the headlight. this is now the tricky part. there is a clip that needs to be unhooked and moved out of the way. remember how you unhook it because you will have to rehook it when you install the new bulb. this hook is a stiff wire with a loop on one end. push on the loop and move it to one side and it will come off the back of the bulb. the clip is attached and will not come off. you should use gloves to remove the bulb. the oils on your hands are not good for the bulb. use glove on removing just in case the bulb is good and you need to use it again. use gloves to install the new bulb. there is only one way to install the new bulb. there are tabs the extend out from the base of the bulb. you can kneel in front and reach your hand under to install the new bulb while you watch the insertion through the glass. rotate the bulb until you feel the detent that allows the bulb to fit into position. both bulbs have the tabs in the same location, ie. the detent tab is about at the 8 oclock position. replace the clip (insure that it clips on to hold the base), the boot and the connector.
Posted on Jun 28, 2009
  • 33 Answers
SOURCE: 2007 Suzuki sx4 engine light on after oil changed
The solution is that when the oil filter is removed, oil gets on the O2 sensor and ruins it. Must cover the O2 and that keeps the oil off. To keep the check engine light off, is to replaced the O2 sensor. Problem solve. Later on sx4's they move the O2 in a different spot. I work on Suzuki cars. Don
Posted on Jul 20, 2009
SOURCE: Hows to reset oil light and oil filter light on 2007 nissan altmi
maintenace and oil filter. i got an oil change last month on my 2007 nissan altima and they did not reset the mileage so the lgiht on the leyboard came on and I cant fix it
Posted on Aug 22, 2009
2007 Suzuki Burgman 650 how to change the oil filter
Hi, Geoffrey for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Suzuki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Oil and Oil filter change on 650 Suzuki Burgman Forum
07 Suzuki Burgman 400 Oil Change Oil Filter Replacement
Suzuki AN650 Service Manual
https://www.partsfish.com/page/oem-parts-for-suzuki
http://mybikemanuals.com/suzuki
Mar 11, 2018 | 2007 Suzuki Burgman 650
What is part number for 2006 suzuki burgman an400 black plastic access cover for changing turn signal bulb ?
Hi, Bill for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Suzuki AN400 Service Manual
OEM parts for Suzuki
Suzuki Burgman 400 2006
Suzuki Burgman Wikipedia
May 22, 2017 | 2003 Suzuki AN 400 Burgman
Burgman 400 2008. At light throttle openings say 1500 rpm. the revs rise and fall by 500 rpm continuously. This fault occurred after replacing the throttle sensor. Jill
Hi, Jill sounds like your new sensor (TPS) is slightly out of adjustment for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Suzuki, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://burgmanusa.com/forums/14-burgman-400-pre-2007/26989-surging-slow-speed.html
http://burgmanusa.com/forums/15-burgman-650/38185-tps-adjustment.html
Suzuki Burgman 400 2008
Mar 11, 2017 | 2008 Suzuki Burgman 400
Does a 2001 burgman an400 rear wheel fit an an250 of same year
Hi, Derek after careful deliberation 4 out 5 Suzuki Gods give this one a thumbs up, but just to be on the safe side you should give your local dealer's parts/service department a call to confirm. For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://burgmanusa.com/forums/14-burgman-400-pre-2007/2916-removal-rear-wheel-an400.html
Suzuki AN 400 Burgman 2001
Feb 19, 2017 | 2001 Suzuki AN 400 Burgman
Does my 1999 Suzuki An250 Burgman have a final drive that needs oil replacing/top-up when servicing?
Hi, Harry the answer is yes what you really need is a service/owners manual sorry you can't find the first and best tool you ever bought for your Suzuki despair not for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
https://www.louis.de/en/rund-ums-motorrad/bike-datenbank/suzuki-an-250-burgman/an/0941
07 Suzuki Burgman 400 Final Drive Oil Change
https://www.tradebit.com/filedetail.php/278704118-1999-2000-suzuki-an250-service-repair-workshop-manual
http://www.airgad.gr/Suzuki-Burgman-AN400-Service-Manual-Eng.pdf
May 08, 2016 | Suzuki Motorcycles
How to install a fuel pump for a 2008 Suzuki burgman 400
Hi, Louis sorry you can't find the first and best tool you ever bought for your Suzuki despair, not for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
http://burgmanusa.com/forums/14-burgman-400-pre-2007/27300-burgman-400-fuel-pump-problem.html
Suzuki Burgman 400 2007
Mar 21, 2016 | 2008 Suzuki Burgman 400
How to reset oil change light on 2002 650 burgman sazuki
650 - Resetting Oil Change Indicator
(The Owner's manual is not very clear on this)
  • 1) Turn off ignition.
    2) Hold both the SELECT and RESET buttons in.
    3) Turn ON ignition
    4) After 2 seconds the indicator to change oil should extinguish.
__________________
Jul 29, 2014 | 2006 Suzuki Burgman 650
My change oil light soon light won't go off. My oil and filter were changed 2 weeks ago and my husband forgot to reset it in our 2007 Suzuki XL7. We just bought this car a month ago and the oil li
it wont go away because their is a mechanical problem and or problem with oil change [ not enough oil wrong filter etc ] will need to have vehicle scanned for the fault code to determine the problem most auto stores offer this service for free
May 17, 2017 | 2007 Suzuki XL7 AWD
Where can i find the oil filter of my bajaj ct100?
Hi, Jjmodia for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
03 06 Suzuki Burgman 400 Oil Change Oil Filter Replacement
Vespa GTS 125 How to Change the oil and oil filter
DOWNLOAD BAJAJ CT 100 SERVICE MANUAL
http://www.marutibajaj.com/pdf/ct100.pdf
Bajaj Auto Ct 100 2015 User Manual
Oct 07, 2010 | 2007 Bajaj CT 100
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
