Question about Refrigerators
Gsl251frfbs Need to replace the door water dispenser lever. How do you get to the water dispenser valve area on the freezer door? Can it be removed from the front or the back to replace the water lever?
  • 18 Answers
SOURCE: Ice/Water Dispenser in Freezer door not working
Sounds like a frozen waterline. I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Posted on Jan 07, 2008
SOURCE: no water at the door 2
hesshouse ---- thanks for the tip. I only had to leave the light on in the dispenser for less than 5 minutes and the water's running fine now!
Posted on Jan 22, 2008
rylee_smith
  • 8619 Answers
SOURCE: Kitchenaid kscs25fjss01 (2002) front panel not working
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 02, 2009
  • 71 Answers
SOURCE: water dispenser line leaking at bottom of freezer
if you have enough room left you can just cut out the hole and go to any hardware store and pick up a water line coupler and repair it....if it is too short or broke up inside the door then you need to remove the water/ice dispenser and pull the line through and run the new one down the track.
Posted on Oct 03, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Ge model gsl251frfbs side by side. Ice
I would check the door switch that turn the light on for freezer. When the door opens the switch changes to deactivate the controls on the dispenser panel and when shut should turn it back on. I will help you trace the problem because sometimes there is a broken connection from the dispenser panel to control board. Let me know, Sea Breeze
Posted on Dec 16, 2009
I have a kenmore cold spot model 106.57285791 and the water dispenser doesn't work. Is there a water strainer on the fridge that might be full of sediment
Check the filter it should be below the freezer door in the kick plate. there is no strainer on the dispenser itself. The valve that lets the water in is located on the back of the refrigerator. Pull the refrigerator out and remove the back cover. follow the water lines to the valve. there are two valves one for the ice maker and one for the dispenser. Remove the wires from the valves noting which went where. Put your test leads into the wire removed from the valve have someone press in on the water dispenser lever and see if you get voltage there. Then test the other set of wires in the same manner. If you get a reading on either the dispenser is ok the valve will need to be replaced. It is sold as a complete valve only. (both valves)
Apr 01, 2018 | Kenmore Refrigerators
Water dispenser does not work, any time it is used water just drains out of bottom of freezer area onto floor. Ice cubes works
Hello Melissa;
My name is Peter. I am a retired field service refrigeration technician.
I am sorry to say you have a serious problem.
The water supply line to your ice maker runs up the back of your refrigerator from the ice maker solenoid. It is a separate water supply line.
Your water dispenser water line runs from the water dispenser solenoid under your unit and up from the bottom of you freeze door.
You have a plastic tubing leak within your freezer door. Calling a service company to replace the freezer door tubing - a good service technician would not replace the tubing - the damage has already been done.
The insulating material in your freezer door is soaked. The water in the door will cause the door liner to expand and crack. There is no way to completely dry out the insulating material.
The only fix is to replace the freezer door. So, $300.00+ for the door and $150.00+ for the service tech. No, a hair dryer will not do it.
May I suggest:
1.) Remove the bottom toe plate (Kicker plate) in the front of your refrigerator.
2.) Turn the leveling screws counter clockwise so you can pull the refrigerator out to get behind it.
3.) Unplug the unit.
4.) Remove the screws from the bottom cover.
5.) There are two connectors to the solenoid valve to the water dispenser. It is the larger diameter tubing running under your refrigerator.
This will disable your water dispenser. If you see cracks on the inside of your freezer door, seal them with a high temperature silicone adhesive.
If you elect to purchase a new unit, check out Sears Outlet (Scratch & Dent) Stores.
May 08, 2015 | Refrigerators
No water from dispenser Matag New filter solenoid valve working, tube to dispenser seems to be blocked
Hello Hans;
There could be several areas that would effect your water dispenser not working:
1.) When you depress the water dispenser do you hear a 'Click'? If not you have a bad water dispenser contact switch.
I would send you a diagram but I do not have your model number.
2.) In the lower back of your fresh food section is your water dispenser water tank. At times this can freeze near the freezer section. Look in the lower corner of the freezer & your fresh food section for ice build-up.
3.) You could have a bad water filter. This does happen often. Remove the water filter and test you water dispenser.
4.) Do you have water leaking out of the bottom of your dispenser door? If so you have a split in the tubing in your water dispenser door.
5.) Is your ice maker working? Often the water valve to your refrigerator becomes plugged up and you do not get sufficient water pressure 60 PSI to operate your water dispenser solenoid valve.
Nov 15, 2014 | Maytag MFD2561HE Stainless Steel Bottom...
Ice switch dispenses water
If the refrigerator water dispenser is not working correctly the water supply tube in the door may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Apr 27, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
I have a samsung cool n cool american style fridge freezer with two tabs on the front. One for cool water and one for ice. The water works perfectly but no ice is being made to fill the bucket, why is
If the refrigerator water dispenser (or ice) is not working correctly the water supply tube(s) may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined (this is most likely the culprit) , third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch (try this first), when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Mar 30, 2014 | Samsung Refrigerators
Water dispenser not working ice maker okay water line to valves okay appears line in door frozen
GE has a fix for frozen water line in freezer door. WR49x10173 is a heater kit that is installed in the dispenser area. It uses a minor amount of energy, but enough to keep the area warm. You have to pull off the dispenser board, remove the 4 screws to remove the dispenser cradle and unplug the wiring. Then follow instructions to crimp on the heater wires. Allow about 3 days for frozen water line to defrost. .
Jul 15, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Model #GSH25JSTCSS---Not getting any water from the water dispenser but still have ice coming out---What's the problem?
I have this same model and problem. The water line may be frozen inside the freezer door. (the line enters at the bottom hinge area of the freezer door)
Shut the unit off and leave the freezer door open ( you will need to remove your stuff you want to save first)
Next disconnect the line coming out of the Freezer door near the bottom hinge (should be a quick disconnect coupler, you will need to remove the front air grill assy to allow access to the line/coupler) and lay the line out on the floor.
After thawing the water should run out the line leaving a small puddle on the floor. Reconnect the line, plug the unit back in and test your dispenser.
Although this method restored my water dispenser to working condition, other possible causes for this include the line freezing up in the refridgerator section, bad water valve, bad relay on the motherboard, that triggers the water valve, bad motherboard. Hope this helps.
Sep 26, 2010 | GE Refrigerators
No Water from Door
Same problem with mine, no water, but could hear humming when pushing dispense lever. There is a coupler in the water line below the freezer door, I pulled it and opened it*, water came out when actuating the dispense lever. So it wasn't frozen between there and the wall, had to be frozen inside the freezer door. Solution? Turn off freezer side of the fridge and leave door open for an hour or two, voila, water in door again. *little blue coupler, push white collar in towards blue plastic to release line, push line back in all the way to replace it. This line has pressure only when dispensing water, and then not much pressure.
Dec 19, 2009 | Hotpoint HSS25GFP Side by Side...
Ge model gsl251frfbs side by side. Ice maker/water dispenser not working when activated. makes ice, just won't dispense ice or water through front door. don't hear motor activating.
Dec 16, 2009 | GE Refrigerators
I have a Hitachi R-M800GM.
When i operate the water dispenser, water flows out from the dispenser [not strong flow]. There is also water flowing out at the bottom of the freezer door [hinge area]
I think the line running inside the freezer door may have come loose? If so, how to reattach it? Do u have any layout drawings of how the hose is being connected.
Please help.
Thanks,
Rick
May 31, 2009 | Amana ARS2464B Side by Side Refrigerator
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
