Question about Homelite Ut80993 Honda Gas Pressure Washer
What is a pump vent plug - Homelite Ut80993 Honda Gas Pressure Washer
Can u please describe were a vent plug is on a pump and what it looks like
The vent plug is always on the top of the pump, generally it is also the fill plug with a small vent hole in it. The head may be a hex (like a a six sided nut, or finger turnable). The drain is on the extreme bottom side or on the bottom of the pump. Change oil at least yearly, use a good synthetic non-detergent pump oil.
Mar 02, 2015 | Garden
Echo CS345 chain saw doesn't pump fuel
Best case is the vent for the fule tank is plugged. Next best is the vent hole in the diaphram cover of the carb is plugged.Worse case is the carb diaphram needs to be replaced.
Aug 04, 2013 | Echo Garden
Stalls slowing down
Air filter plugged - Clean air filter
Tank vent faulty - Clean or replace tank vent if necessary
Leak in fuel line between tank and fuel pump - Seal or renew connections and fuel line
Pump diaphragm damaged or fatigued - Fit new pump diaphragm
Main jet bores or ports blocked - Clean bores and ports
Fuel pickup body dirty - Fit new pickup body
Fuel strainers dirty - Clean fuel strainers
May 01, 2013 | Husqvarna Garden
'04 yukon denali. Gas pump shuts off at every $2.00. Excessive pressure when cap is removed to fill. Not sure if vent is clogged. Need help. Any suggestions?
Sounds like vent tube or vapor canister is plugged. Try compressed air into vent tube. If that doesn't cure, vapor canister filter is plugged.
Mar 17, 2011 | 2005 GMC Yukon Denali
The vents on the dash are not working in my 1980 corvette. the fan is working when the heater is on. but can not get the dash vents to blow.
If you have A/C. When you put the heater on defrost it activates the A/C pump so it will not freeze up from not being used. If you don't care about the pump disconnect the plug that engages the clutch on the pump and use a jumper wire to bridge the plug to itself and your defrost should work
Aug 25, 2010 | 1980 Chevrolet Corvette
Bad smell fro macerator when toilet flushed after being left overnight
Typically on macerating or grinder pumps there is a small 1/2" breather hole on top of the lid, about the size of a dime or nickel. That breather hole must be kept plugged or seal cap. If left open, odor will escape through there. Make sure the pump is vented using an 1 1/2" vent pipe which must be vented to the open air so air can flow in and out of the vent pipe at all times. Also you might want to check for loose connection or waste water leaking from the pump, toilet or any of the connections.
May 21, 2010 | Saniflo & Saniplus& Macerator Pump
How can I minimise the smell of my macerator
The pump has a 1/2" breather hole and an 1 1/2" vent connection. The unit must be vented to the open air using the 1 1/2" vent connection, air must flow in and out of the vent pipe at all times. The 1/2" breather hole is only used for European installations. In the US you must keep it plugged or seal capped, if left open odor will emmit through there.
May 13, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Assembly
HI your machine would have been delivered with a blanking plug in the pump. You will need to remove this and fit a vented pump or your pump will build up too much pressure inside.
Apr 13, 2010 | Comet BXD2527 Pressure Washer Pump
When toilet is flushed the pump will continue to pump.
The air breather hole must be kept plugged in the US as odors will emmit through there is left open. I was told that it was only used for European installations. In the US the breather hole mut be kept plugged or seal capped. You must vent the unit using an 1 1/2" vent pipe and must be vented to the open air. As per plbg. codes it should be attached to the main vent stack or all the way through the roof.
Mar 31, 2010 | Saniflo & Saniplus& Macerator Pump
I bought an Intex 15' x 42" above ground pool at a garage sale. No instruction or DVD were included. How is the skimmer set up?
Plug the inlet & suction openings with provided plugs
Hook up the hoses.
Release vent screw from the top of the filter housing.
Remove hose plugs.
Start pump
when water comes out filter housing vent - close it.
check for proper flow.
Thanks for using FixYa - a good rating is appreciated for answering your FREE question.
Jul 08, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Homelite Ut80993 Honda Gas Pressure Washer Logo
29 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
