Question about Kodak Esp 5250 All-in-one Inkjet Printer
Printer error shows error code 3802 and won't print
    Sergeant:
  • 260 Answers
  1. Upgrade your printer firmware to the latest version
  2. If your printer firmware is already up-to-date:
  3. If the error continues:
  4. If the error continues,
for more help visit https://cbrtechsolutions.net or
CBR Tech Solutions
Posted on Sep 30, 2015
SDtester
  • 41 Answers
SOURCE: Fatal printer error
1. First open the top of the unit remove the ink tanks and set them aside.
2. Remove the printhead and then unplug the printer. re-insert the printhead back into the printer. Remove it again and re-insert it. Do this 3-5 times. If you need help doing this, there are instructions on installing a printhead in the electronic manual PDF file provided by Kodak. (What this removal and re-install is doing is scraping of anything that might be disrupting the contact between the printhead and the printer)
3. Now install the printhead and install the ink tanks.
4. Plug in the printer want for it to bootup.
5. If the error comes up again you need to contact to Kodak about getting a new printhead or Return your printer and exchange if for a new one.
Also do be sure to update your software and printer firmware through the Kodak site or through the software provided. These printers print nice photos and the ink is cheep. Dont let this road bump turn you away from them.
Kodak and or I am not responsible for any data loss or any damage to any equipment that occurs as a direct or indirect result of following the procedures described above.
Posted on Feb 25, 2008
SOURCE: Error 3802
printer can not talk to printhead... power off. wait. power on
Posted on Sep 17, 2008
SOURCE: ERROR CODE 3802
This is how I fixed this problem may or may not work for you. I removed the ink!!! Then I removed the ink tray. This is fairly easy if you fell the top of the ink tray you will find a small square that is slightly raised push in on the square while pushing down on the tray this will release the print head. Very carefully clean with 92% alcohol and a q-tip! Don't apply pressure to the print head it will ruin it!!!!!!!
This allow to air dry for at least a 5min. Reinsert then recalibrate the printer! go to printer status and at the very top you will see a rench and hammer icon press it then follow directions!!!!!!
Good luck and god bless
Posted on Dec 25, 2008
Mykel_N
  • 315 Answers
SOURCE: printhead failure error code 3802
You need to contact kodak and ask for a replacement print head, explain the code and whats been happening.
www.kodak.co.uk
They will probably tell you to download new drivers and wash your printhead ect ect but nothing that helps.
I had the same problem with the same printer.
I couldn't get Kodak to send out a printhead, so after weeks of messing around, I took it back for a refund.
If you do manage to get a new printhead here are the instructions on how to remove and replace it.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Posted on Jan 31, 2009
SOURCE: kodak 5300 first said error 3802 now says print head missing or loose
I got the same Problem as listed above. This is the way how I was able to solve it:
  • Remove the color and black ink cartridges and the printhead. (the 5300 Printhead can be removed by pressing a button on top of the carriage and a slight pull --> for better instructions use this official Kodak PDF)
  • Try to clean the printhead and the carriage with a slighty wet cloth from ink. CAUTION!: better not touch the green electronic chip! Be carefull while cleaning.
  • Reinstall the printhead and the ink cartridges.
  • If the printer detects a 'new' printhead just do a calibration and your are done. If not try to print a test page.
Hope this solves the Problem. Best wishes
Posted on Apr 19, 2009
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
Error code 3802
CBR Tech Solutions
Jan 19, 2014 | Kodak Office Equipment & Supplies
Printer showing error code 3802, says to go to kodak. com/go/aiosupport
I am new user of Kodak printer and i used to get error code 3802.
The main cause of the error 3802 is improper installation of printer driver. To get rid of this error you always ensure that properly install the printer driver.
I was looking for the solution and then found this using google. I found this link helpful.
http://printersupportsnumber.weebly.com/blog/kodak-printer-error-code-3802-its-cause-and-solution
Any other suggestions are welcome.
Thanks in advance.
Jan 20, 2012 | Office Equipment & Supplies
Printer will not clear the Error 3802 , what do I do?
Hello and Welcome to FixYa!
Error 3802 generally occurs in the Kodak Inkjet Printers.
To solve this error Turn the printer off and then turn on, this problem is solved by doing this mostly.If the problem still there then remove the ink cartridges and the print head and after few minutes put it back in the printer .If you are still facing this then do it again almost five times & if still your problem is not solved and you still get error code 3802 then probably your KODAK EASY SHARE 5500 All-In-One Ink Jet Printer is in need of servicing by a service professional.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you and Keep using FixYa!
Aug 17, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
Getting problem code 3802
Hello thanks for using Fixya
Error 3802 Mean Print head Failure
Turn the printer Off and On, This problem is solved by this mostly.If the problem still there then remove the ink cartridges and the print head and after few minutes put it back in the printer .If the problem still there then do it again almost five times & if still problem not solver and you get error code 3802
then it is probably that your KODAK Esp 3250 Allinone Multifunction Printer is in need of servicing by a service professional.
So go to the KODAK Service Center
Your problem will be solved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation "if it is helpful"
THANKS
Keep Using Fixya
Feb 28, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Printer wont copy error code 3802
Hi,error 3802 Means Printhead Failure
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it again for (5x)
And if the problem still there,
i will suggest you contact their customer care for further assistance.
Apr 16, 2010 | Office Equipment & Supplies
Error code 3802
You give scant information for your comment - you don't really ask a question - so I am flying in the dark so to say.
Here is what I did find and I hope you fine it applicable and useful. http://www.fixya.com/support/t4349159-printer_shows_error_code_3802
As I said you dont give much info - like make and model of printer ...
Mar 19, 2010 | Office Equipment & Supplies
Printer shows error code 3802 printer will not print
To resolve this error:
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Wait 30 seconds to allow the printer to reset.
  4. Connect the power adapter to the printer. Turn the printer on if necessary.
    • After the printer completes powering up, the message "Printer access door open" will appear.
  5. Close the printer access door.
  2. Remove and install the printhead two times.
  3. Close the printer access door.
  4. Wait until the printer is ready to use.
If the error continues, contact Kodak.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 16, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
ERROR CODE 3802
Nov 03, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak 5300 first said error 3802 now says print head missing or loose
May 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak Esp 5250 All-in-one Inkjet Printer Logo
64 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
