Question about RCA L46WD22 Television
RCA l46wd22 tv gets sound through surround sound but not from actull tv speakers how do I get to the sap
Want to get to sap
4 Suggested Answers
SOURCE: No Sound on RCA L46WD22
I own the L46WD22 for a few months and lost the sound and analog inputs, only HDMI worked, apparently this is a design flaw and they should have recalled all units. I didn't really needed the speakers because I have a sony receiver where I playback the sounds, but I decided to repair it myself after I neglected to take it out to the repair center and use the warranty. If you have a little soldering experience you can fix it, or you can buy the fuse and take it to any repair center, the problem is a surface mounted fuse that is located in the PCBA where all the signal inputs are, the component location is 1C33 the fuse has the letter F printed on it, you can't miss it, it's about 2 inches behind the tuner where you plug the coaxial cable. the fuse I bought it's marked with a G letter, it's 750mA, I just soldered it on top of the one it has, now I can hear the speaker and use the analog inputs (and now I'm the hero and have a very happy wife). the whole fix took me about two hours
Posted on Sep 28, 2008
SOURCE: RCA L46WD22 firmware
I have same problem, any solution?
Posted on Nov 10, 2009
mpaint
  • 36 Answers
SOURCE: My RCA L46WD22 TV turns on but there is no picture
This is a very common problem with these models.
The problem is a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
Posted on Jul 23, 2010
I have rca DVD surround can I hook up so reg TV and DVD is surround sound both
you have to start with surround sound to get surround sound so no,but if you want sound out of the speakers on the surround sound from your tv,you can do that.
May 10, 2015 | RCA Televison & Video
Sentry 2.1 surround sound speaker system. i have my rca cords plugged in to my tv, but i only get sound from my tv, nothing out of the speaker itself. it only works when i have my headphone jack into
Most televisions have a setting that controls whether the TV uses its internal speakers or sends the sound to the audio out jacks for an external amplifier or speakers.
Try going through the settings menu and follow through the audio/speaker selections and confirm that the TV is set to use external speakers.
Best Regards,
Sep 01, 2017 | Televison & Video
MY TV ONLY HAS SOUND WHEN IT IS HOOKEDUP TO THE DVD PLAYER AND A SURROND SOUND SPEAKER BUT NOT FROM THE TV OR WHEN HOOKED UP TO THE SPEAKER ON TV OR XBOX
Hi,here is the solution......
Since you successfully connected your
DVD /Receiver to play video on TV (one way only ) ,here is the second reverse action to listen your TV on DVD /Receiver
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV ,
** to "TV input "or "AUX input" or "Optic Cable input"
of your DVD /Receiver (whichever you want based on the necessary cables on your hand )
** than just switch to respective mode on
DVD /Receiver corresponding the connector you have used on the back of DVD /Receiver ..
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
There you go..Both Tv and Xbox sound are on the
DVD /Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your DVD /Receiver SURROUNDING SOUND .
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 03, 2011 | RCA L46WD22 Television
How do I get my rca truflat tv to get out of mono?
Hello
Press the MTS on the remote control handset to select STEREO, MONO or SAP. All the options will be available only when the current TV channel is broadcasting that option. Channels will not always carry programes, that have all MTS options. If "STEREO" appears on the screen when you select a channel means stereo sound is available with current programme. You can hear sound from both speakers. If broadcast is not strong and clear, stereo sound will not be available. Press "MTS" button to change it to "Mono". This will eliminate the noise. If "MONO" appears on the screen when you select a channel, stereo effect will not be availabe, even though you have set it to stereo. If "SAP" appears when you select a channel 'Second Audio Programe' [SAP] broadcasting is available for that programme. Press the "MTS" button to 'SAP' and you can hear that programe in different language or some other kind of audio.
Oct 28, 2010 | RCA TruFlat 27F520T 27" TV
TO GET SURROUND SOUND I NEED RCA CABLES WERE DO THEY GO ON MY TV
You won't get surround FROM your TV. It's just a lightshow device with bare minimum speakers and audio chops.
Get the TV-related audio from the same source IT IS WATCHING - Cable/SAT/DVD/BluRay/Game. Digitally, if possible. Otherwise you'll just get stereo analog sound.
Jun 10, 2010 | Audio Players & Recorders
My sound went out on my TV, so I set up our surround sound. I turned off the TV speakers via the menu. I am trying to set up a Wii but I can't get Vid1 Vid2 or the component ports to work. I get sound...
I would check that both your tv and the wii are set to thew same video resolution. Usually around 480i, depending on what type of cable you are using. If you are using component cables. make sure the green and the blue are not in the wrong ports. very common mistake as the look the same color.
good luck
May 24, 2010 | RCA L46WD22 Television
I have a 42 inch sanyo tv I am trying to hook up saround sound or just extra speakers
Extra speakers without having the external speaker jacks in the rear is definitely a NO NO. The surround sound is used by connecting the RCA jacks from the TV that say Audio Out to the surround sound audio input on the receiver.. The RCA cables are cheap, you can get them at Home Depot ect....
Nov 27, 2009 | Sanyo Televison & Video
L46wd22yx5 rca tv lost sound thru tv speakers, sound works thru home theater system...? no other problems seen...
Verify first in the audio setup on screen menu that the speakers are not set to OFF. Otherwise you may have bad power amp sections.
Nov 02, 2009 | RCA L46WD22 Television
No surround sound on normal tv just dvds
Do you have a cable box or satellite box? If you do, try hooking up your TV sound through the box. Look for audio out in the back of box (white/red RCA Jacks). Hook RCA cable from cable box to surround amp. Even if the audio out jacks are being used already, you can use Y connectors to hook up the surround amp to the box.
Hope this works for you!
Jul 23, 2009 | RCA Audio Players & Recorders
Analog or Digital?
This tv is analog, EDTV is only enhanced definition tv ,480p resolution, not the HDTV 1080i or 1080p resolution, the mts/sap tuner has to do with the audio decoder. For example: SAP would allow you to view a station broadcast in english to be heard in spanish. MTS is surround sound broadcast. Thanks
Apr 02, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
RCA L46WD22 Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
