Question about GPS
2011 hyundai sonata gps error message. The application drfish.exe has encountered a serious error and needed to shut down
The gps in my car will not recalibrate my location and this error message pops on every time I turn on the car. How can I fix this?
rockitman187
  • 2559 Answers
SOURCE: intellinav.exe application error
The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
Usually you get this error message when performing a specific task, and if that happens you need to check the corresponding 3rd party's website/support department to see if they are aware of the problem
..a while back symantec Antivirus caused the 0xC0000005 error with an additional message about a file called SAVRT.SYS . A simple software update to the Symantec Antivirus cured the problem.
So what can you do...? well below are a couple of suggestions:
0xC0000005 - Resolution Suggestion One:
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund!
0xC0000005 - Resolution Suggestion Two:
In Windows XP Service Pack 2 Microsoft introduced Data execution prevention (DEP), a set of hardware and software technologies that perform additional checks on memory to help protect against malicious code exploits. In Windows XP SP2, DEP is enforced by both hardware and software.
Some software/application behaviors are incompatible with DEP - data execution prevention. Applications which perform dynamic code generation
(such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention. Applications which are not built with Safe SEH must have their exception handlers located in executable memory regions.
Applications that attempt to violate DEP will receive an exception with status code STATUS_ACCESS_VIOLATION (0xC0000005).
If an application requires executable memory, it must explicitly set this attribute on the appropriate memory by specifying PAGE_EXECUTE, PAGE_EXECUTE_READ, PAGE_EXECUTE_READWRITE or PAGE_EXECUTE_WRITECOPY in the memory protection argument of the Virtual* memory allocation functions.
If you are having issues with 0xC0000005 errors in DEP and a particular piece of software is causing the offense, contact the vendor for a resolution...
Note: It is possible to "Turn Off" DEP in the boot.ini file but this really would be a last step!
/NOEXECUTE
This option is only available on 32-bit versions of Windows when running on processors supporting no-execute protection. It enables no-execute protection (also known as Data Execution Protection - DEP), which results in the Memory Manager marking pages containing data as no-execute so that they cannot be executed as code. This can be useful for preventing malicious code from exploiting buffer overflow bugs with unexpected program input in order to execute arbitrary code. No-execute protection is always enabled on 64-bit versions of Windows on processors that support no-execute protection.
There are several options you can specify with this switch:
/NOEXECUTE=OPTIN Enables DEP for core system images and those specified in the DEP configuration dialog.
/NOEXECUTE=OPTOUT Enables DEP for all images except those specified in the DEP configuration dialog.
/NOEXECUTE=ALWAYSON Enables DEP on all images.
/NOEXECUTE=ALWAYSOFF Disables DEP. (This setting doesn't provide any DEP coverage for any part of the system, regardless of hardware DEP support. The processor doesn't run in Physical Address Extension (PAE) mode unless the /PAE option is present in the boot.ini file.)
0xC0000005 - Resolution Suggestion Three:
I have also seen this error in the gaming community when folks have updated drivers for their graphics card. If this happens just roll back your drivers.
0xC0000005 - Resolution Suggestion Four:
Microsoft Internet Explorer 6.0 stops responding when you try to open an HTML document or a Web page. Additionally, you receive the following error message:
Access Violation (0xC0000005 exception)
CAUSE:
This problem may occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags. If a SPAN tag is not closed correctly by using the </SPAN> tag, an access violation may occur.
WHY are you using IE6 still??? Upgrade to IE 7 today!
...and that should have now resolved the 0xC0000005 error for you!
Please rate this fixya
Posted on Jan 29, 2009
SOURCE: Fatal Application Error/Pioneer AVIC-S1
my sun format my avic-s1 and i did't know what can i do ? any one can help me with this assu
Posted on Dec 03, 2009
nonontech
  • 4737 Answers
SOURCE: I am receiving an error message on my GPS.
If I am right, your device is a product of Nextar, as you know, this is another common issue, some got fixed easily while some didn't.
Connect the GPS to your computer using the usb cable that came with it, then see if it gets charged from computer and does it turns on. If it does, then the car charger has an issue or the car plug isn't giving correct output voltage and in turn interrupts the operation of the device. If this is the issue, you'll need to replace it.
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS device, this error may show up either because of software or hardware failure.
Locate the Reset button, press it or push the stylus into the "Reset" hole, to see if the navigation software can load successfully.
If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure.
In either case, please return the unit for exchange or repair to the retail location from which you purchased it. Your unit should have a one year warranty and Nextar will give you free repair / replacement whether you purchased it or someone gifted it to you. Here's Nextar contact details and return policy.. (click here)
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 22, 2010
  • 13 Answers
SOURCE: how do i take off
Rand is working on this. A new version may be available soon that addresses this issue.
Thanks,
Mark
Posted on Nov 05, 2010
SOURCE: error message when starting up gps
how to fix this problem
Posted on Feb 09, 2011
Snooper Truckmate pro Sound DB8500: error asimap.exe
Advanced Computer User Solution (manual update):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Snooper Application Error Asimap.exe) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Mar 20, 2016 | GPS
When i turn on my smartbook a thing pops up and says:: APPLICATION ERROR application explorer.exe encountered a serious error and must shut down ive shut it down at least 5 times now i need help!
See if going into safemode would get you the same error, if the error persists, then it could be hardware related issue if it doesnt, simply reformat your OS.
Jan 31, 2016 | Computers & Internet
How do i fix an application shell.exe error on a pkc0pc - 5.0 gps
your going to have to send it in if it want reboot thats all you can do
Jun 04, 2014 | GPS
On starting skycaddy sgx, I get the following message on screen: application servicesd.exe encountered a serious error and must shut down
Find the maual or go to ther website. see if they have a software fix for it if not you are most likely going to have to reinstall the software. Errors like these are startup errors and there is no work around that i know of.
Nov 04, 2013 | SkyGolf SkyCaddie SGX GPS Receiver
How do i take off the message application herems2.exe encounter a serious error and must shut down on TND 500 Rand mcNally
Thanks,
Mark
Oct 24, 2010 | Rand Mcnally TND 500 Car GPS Receiver
Fatal Error Application comes on when turning on the GPS
The problem i,m having is All the routes i have taken have Now a Permanent Orange Heavy Line and i can not identify any Roads on my Navigation 4000
Feb 03, 2009 | GPS
GPS Logo
454 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
