My acer aspire 5630 when turned on does not boot it only give me f2 setup option
    Master:
  • 788 Answers
Possibly your hard drive is dead, or the boot up section is damaged.
Posted on Feb 17, 2014
5 Suggested Answers
SOURCE: my acer aspire one netbook tries to boot ,but then
i was able to go on the acer website on another pc and found that if when you turn on your acer and hold down ALT key while hitting F10 that will bring you to a system recovery screen. you can restore factory settings from there. It will wipe out all of your documents and pix but it does fix the problem.
Posted on Apr 22, 2009
  • 788 Answers
SOURCE: Acer Aspire One - blue screen only when try to boot
You may have to remove and reset the HDD and Memory on the unit.
Next, you will recv. the F-2 to continue or F-12 to enter setup.
Enter setup and change date and time.
Save and try.
You may have a damaged HD or boot partition and reloading the operating system will be necessary.
Reseating the HD will assure that you have a good connection and the same with the memory.
Also, if the unit has been dropped, you may have a damaged HD and may need to change it.
Posted on Sep 26, 2009
  • 389 Answers
SOURCE: How to replace Acer Aspire 5630 Hard Drive
The link below gives you the user manual. On the computer views is the base view which will show you the correct bay on the bottom of the computer. You will loosed the screws to that bay, remove the cover andl you will see the hard drive. Althought I have not removed this particular laptop hard drive, these drives usually pull up or back using a tab provided. The hard drive will probably have a cradle the actual drive is connected to. You will have to removed the old drive from this cradle and put the new drive back on the cradle exactly the way the old drive was attached,
I hope that this information helps and gives you a place to start solving your issue.
Brian
Posted on Jan 24, 2010
  • 82 Answers
SOURCE: i have forget acer aspire 5630 setup password
Window Password Unlocker is safe and reliable software which allows you to burn a password reset CD/DVD for Windows 7/Vista/XP, etc. If you forgot windows 7 password, you can reset it in less than 5 minutes, no matter your lost password length and complexity.
Posted on Dec 28, 2012
Boot from dvd
Try to tap F2 key right after you turn on the Acer laptop (BIOS setup). Other option: Insert DVD media and tap ESC key while booting.
Mar 09, 2014 | Acer Aspire 5250-0450 laptop
Del enter setup f12 boot
u may have to remove then rem,and hard drive then put back then reboot,f2,or f12 will give you option to boot from a disc
Jan 14, 2014 | Acer Aspire T310 PC Desktop
BIOV PASSWORD
RESTART THE PC AND PRESS F2 TO BOOT OPTION AND SCROLL THE B.I.O.S VERSION MAKE SURE TO UPGRADE IF NEED IT
Sep 10, 2013 | Acer Aspire 5630 Notebook
F2 setup richiede passsword qual'e'
Windows Password Recovery Basic
google or http://www.windowspasswordrecovery.net/index.html
download
burn the image
boot to disc
locates the password
Nov 23, 2010 | Acer Aspire 5630 Notebook
I have an Acer Aspire One notebook. I cant seem to start it. I turn it on and this displays : Check cable connection..! PXE-E63 : Error while initializing the NIC PXE-M0F : Exiting Intel PXE ROM. No...
It happens when no boot device is selected, the default is network boot first, you must select CDROM/DVDROM or HD as your first startup device. boot up machine and enter bios setup think its F2 key to enter bios generally it del or f1 or f2 it may say onscreen at start if f2 doesnt work
in the bios set boot order to HD as firstboot option then save and exit
hope this helps
dont know if all acers do this but also if you press f12 on boot up it gives you current boot options select HD that way is current boot and would have to be done everytime
Nov 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Turns on but wont go pass the startup screen
Try to put an operating system boot disk in your drive then turn on laptop.
When the screen says press any key to boot from cd/dvd press a key.If it is vista when you do boot from cd it will give the option in the lower right corner to repair-click on this-select repair startup option.if that fails try a re-install of your op sys.
May 31, 2009 | Acer Aspire 5610 laptop vista combo with...
How can I password-protect all files on my laptop?
Hi there.
You can set a bios and hard drive password either by using Acer Empowering Technology application or entering the bios itself by restarting the computer and hit F2 while its just starting up, make sure you keep your password safe because if you forget the the passwords you may find yourself locked out of your own computer and bios passwords are very hard to crack.
Good luck and thanks for using FixYa!!
May 13, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
How to off fn keyz in acer aspire 5920
when you turn it on in the top right hand corner it will say setup F2 or F12 so go to setup an in one of the pages it will say Fn and you should be able to turn it off
Feb 06, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5630 PC Notebook Problem
This could be an issue with your OS, you will probably need to boot from windows cd or start in safe mode.
May 18, 2008 | Acer Aspire 5630 Notebook
My Acer Aspire 3000 has a blank screen
I suggest you check the settings of your bios. Normally this happens if your Hard drive is unreadable. Change the settings of the boot function to first boot on Hard disk and try to disable all other bootable hardwares like CD or network card.
Hope this helps.
Apr 22, 2008 | Acer Aspire 3690-2196 Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
