Question about Zynga Texas HoldEm Poker
Rs 1 code error - Zynga Texas HoldEm Poker
Motor error 0010
Estou com um erro na roland RS 640. Erro service call 0109!
May 20, 2013 | Roland Versa Art RS 640 64-inch Printer
Hi i have got a 2007 aprilia rs 125 there is a red traingle with an exclamation mark inside it what is this.
This means you have a fault code(the bike equivalent of a check engein light)
Aprilia fault codes; From ignition off, press and hold the LAP/PASS switch on the left handlebar. Turn on the ignition but don't start the bike ( keeping LAP/PASS held ). After 30 seconds or so the temp display on the dash will display error code numbers or 0 if none are displayed. Note that the codes are cleared after this operation.
http://img.photobucket.com/albums/v223/DaCat/Aprilia/RSVFaultCodes-1.jpg
Feb 27, 2011 | 2007 Aprilia RS 125
What is error code 99 for a hobart HL 600 mixer?
error 99 stands for communication fault between timer board and the sr drive.there are 5 things that can cause this error.1.rs-485 cable disconnected or malfunction 2.1 con monitordisconnected or malfunction. 3.run/stop wiring disconnected or malfunction. 4.timer board malfunction. 5.sr drive malfunction. hope this helps, dont forget to vote, thanks, monomoy
Jan 29, 2010 | Hobart HL600 Legacy Stand Mixer
CANON ERROR CODE 5010
There is an issue with the purge unit inside the printer.
If you are under warranty you are in luck, but first ask yourself how old is the printer and is it worth fixing and if not get a new one.
Jul 07, 2017 | Canon Pixma MP500 All-In-One InkJet...
Error code on robert shaw 9600 thermostat
i am having a ER on my shaw robert theromostat model RS-9420
Jun 30, 2009 | Shaw Robert RS-9420 Thermostat
Pls help in this VB code, Sato CX400 barcode printer
jst try this u create a label from label printing software using ato font then make a prn
then attach u r vb code in to prn it will work
rohitjain
prn example-------------
A
Z
A
CB+18
Z
A
CD250,3300
Z
A
AR
Z
A
A100950647
Z
A
%2h416v0072BG01031>H23456111
%2PSP02h573v0021L0101XS922
%2PSP02h618v0021L0101XS18K
%2PSP02h415v0089L0101XS17125
%2PSP02h416v0039L0101XSPO124
%2PSP02h416v0022L0101XS215gms
%2PSP02h618v0043L0101XSDR37/0.20
%2PSP02h618v0064L0101XSDR37/0.20
%2PSP02h618v0085L0101XSDT/B44/0.82
Z
vb code example------------------
Open "LPT1" For Output As 1
Do While rs.EOF = False
For I = 1 To Val(Text1.Text)
Print #1, "A"
Print #1, "*&"
Print #1, "Z"
Print #1, "A"
Print #1, "CB+18"
Print #1, "Z"
Print #1, "A"
Print #1, "CD250,3300"
Print #1, "Z"
Print #1, "A"
Print #1, "AR"
Print #1, "Z"
Print #1, "A"
Print #1, "A100950647"
Print #1, "Z"
Print #1, "A"
X = "%2h380v0065BG01031>H"
Y = rs.Fields(6).Value
X = X + Y
Print #1, X
Print #1, "%2PSP02h618v0085L0101XSKT"
Print #1, "%2PSP02h600v0085L0101XS", rs.Fields(1).Value
Print #1, "%2PSP02h618v0064L0101XSNetWt"
Print #1, "%2PSP02h600v0063L0101XS", rs.Fields(2).Value
Print #1, "%2PSP02h618v0043L0101XSDiaWt"
Print #1, "%2PSP02h600v0041L0101XS", rs.Fields(3).Value
Print #1, "%2PSP02h618v0021L0101XSColWt"
Print #1, "%2PSP02h602v0021L0101XS", IIf(IsNull(rs.Fields(4).Value), " ", rs.Fields(4).Value)
Print #1, "%2PSP02h430v0084L0101XS", rs.Fields(5).Value
Print #1, "%2PSP02h371v0028L0101XS$"
Print #1, "%2PSP02h405v0028L0101XS", rs.Fields(7).Value
Print #1, "&"
Print #1, "Z"
Print #1, " A"
Print #1, " #E5"
Print #1, " Z"
Print #1, " A"
Print #1, " CS2"
Print #1, " Z"
Print #1, "A"
Print #1, " 0000"
Print #1, "TEXT1.TEXT"
Print #1, "/"
Print #1, "Z"
Feb 04, 2009 | SATO CX400 Thermal Label Printer
I have a RS Medical RS-4i stimulator , how do I reset it ?
This is the code that I was given about 7+ years ago to reset our RS Medical RS-4i Stimulator and it worked fine.
Turn unit on & press ch. 4. Then you press ch. 1 until it shows a "F". Then ch. 2 until it shows a "7", ch. 3 until it shows a "B", & ch. 4 until it shows a "A".
Hope this helps.
Jan 18, 2009 | Computers & Internet
Vb variable error
Change the code:
strdbname = "d:\vivek\company.mdb"
Set DB = DBEngine.OpenDatabase("D:\VIVEK\COMPANY.MDB")
strrsname = "company"
Set RS = DB.OpenRecordset("COMPANY")
comp.Text = RS!COM_CODE
compnm.Text = RS!COMPANY
isinno.Text = RS!ISIN
AD1.Text = RS!ADD1
'AD2.Text = RS!ADD2
'AD3.Text = RS!ADD3
AD4.Text = RS!ADD4
BK.Text = RS!BOOK
'PG.Text = RS!Page
to become:
Set DB = DBEngine.OpenDatabase(strdbname )
Set RS = DB.OpenRecordset(strrsname )
AD1.Text = RS!ADD1
AD2.Text = RS!ADD2
AD3.Text = RS!ADD3
AD4.Text = RS!ADD4
BK.Text = RS!BOOK
PG.Text = RS!Page
mostly to eliminate the extra "quote" (') characters,
and to use the values you set.
Dec 10, 2008 | Computers & Internet
I need coding for below description
1700x=1.2(2000)
1700x=2400
x= $1.40 ???
1700=1.2
_______
3000= x
3000(1.2)=1700x
x=$2.11
Apr 28, 2008 | Computers & Internet
Rs 232
try unplugging and uninstalling the rs232 and reboot then turn off then plug the cable back in and turn on. it should detect and install.
Oct 28, 2007 | HP (158800-001) for Compaq Presario 1246,...
Zynga Texas HoldEm Poker Logo
29 people viewed this question
Top Zynga Facebook Apps Experts
 Grubhead
Grubhead
Are you a Zynga Facebook App Expert? Answer questions, earn points and help others
