Question about KitchenAid KESC307 Electric Kitchen Range
One electric burner wont work kesc307 kitchenaid range
  • 718 Answers
SOURCE: Finding a replacement night light bulb for kitchenaid superba
KitchenAid KESC307
The bulb inside the oven is 40 watts appliance
You did not indicate which bulb you need but you can go to
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=251681
and click on the diagrams in the left-hand side to locate the bulb you need.
Posted on May 09, 2009
SOURCE: Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Posted on Sep 05, 2009
fixyourboard
  • 310 Answers
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Oct 13, 2009
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
  • 38 Answers
SOURCE: My Mother has a Kitchenaid electric range (20 yrs
The element could be faulty. The thermostat could be faulty. The wiring to the element could be faulty. The wiring to the thermostat could be faulty.
Do not attempt repairs unless the POWER IS OFF.
Posted on Nov 22, 2009
pctech1
  • 1940 Answers
SOURCE: My Kitchenaid Electric Range Model
Oven element does not heat:
  1. No line voltage.
  2. Loose or bad wiring.
  3. Check circuit breaker.
  • Repair or replace wiring (see wiring diagrams).
  • Defective element. Test and/or replace element.
To test the bake element (located inside the oven, at the bottom), perform the following steps:
1. Use an ohmmeter and set the range switch to R x 1.
2. With no power applied, disconnect one wire from the element terminals. You should obtain a reading of between 19 ? and 28 ?. If the reading is not within the range shown, the element is defective, and should be replaced.
To remove the bake element:
a) Remove the two screws from the mounting plate and pull the element forward as far as the wires will allow.
b) Disconnect the wires from the bake element terminals and remove the element.
If the element is found to be working correctly, you may have a burned out Electronic Oven Control, bad Spark Module, etc. These components will need to be tested. If you are familiar with appliance repair/electrical repair, here is the repair manual (else, hire a service technician):
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/3cd0f44c2da9595785256a8c0063802f/$FILE/4322525.pdf
Posted on Jun 14, 2011
My kitchenaide oven kers206x won't work. lights comes on
I do not know your unit but it sounds like one of the fuses has failed if you have them. If burners work then probably the thermostat. This is just a guess.
Apr 16, 2014 | KitchenAid KESC307 Electric Kitchen Range
How do i remove the glass top to replace a burner?? it is to a kitchenaid electric range suberba, model KESC307HBS0. Thanks!!
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Range-Parts/Model-KESC307HBS0/0593/0124160/W0105111/00001?blt=06&prst=0&shdMod=KESC307HBS0 this parts breakdown gives you an idea of what pieces you need to remove to get to the burners. Start off by removed the trim pieces (careful they scratch easily). Then you should be able to raise remove the glass top - careful that you secure it somewhere that it doesn't fall over and break.
Jul 02, 2011 | KitchenAid KESC307 Electric Kitchen Range
Best Regards,
Bruce
Oct 12, 2009 | KitchenAid KESC307 Electric Kitchen Range
Back burner not working properly
We have called a technician, who believes it may be the switch.
Nov 10, 2008 | KitchenAid KESC307 Electric Kitchen Range
KItchenaid supera gas stove
thers is a thermal cut-offs under the main control area little black thermostat one controls display andother turns fan on/off
Feb 08, 2008 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
15 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
