Question about Kenmore 20172 Top Load Washer
Washer lid switch replacement - Kenmore 20172 Top Load Washer
scottowa
  • 87 Answers
SOURCE: how do I get to the lid switch to replace it on my washer
Pull of the end caps #14 & 11 on the diagram. Remove the screws and the front panel will flip up. Then there are 2 clips connecting the bac to the cabimet. Snap those out and the the WHOLE front of the machine comes off if you tilt it forward. Go to sears.com and parts to bring up any model for anything and you can kind of see how things go together. Good luck.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11022852100&productCategoryId=0153200&brandId=0582&modelName=WASHER&diagramPageId=00002&componentDescription=CONTROL%20PANEL&documentId=P0103381&backToLink=Return%20to%20Sub%20Components%20list
Posted on Jan 23, 2009
  • 14 Answers
SOURCE: Washer won't drain and spin. replaced timer, lid
HAVE YOU CHECKED BRUSHES IN MOTOR
Posted on May 15, 2009
SOURCE: washer leaking after I replaced lid switch;I removed back panel
I called a local shop today to see what they said about it. So note to others who read this. This updated coupler is tight. The one I got may have been a bit more. There is a dimple in it that makes it tight and you do need to tap it on. So use a bit of oil on shaft, use a socket BUT make sure it is small enough to ONLY touch the metal part and NOT the outer plastic..
If the old one fails I'll then go back and try again with new one (i think i can tap the metal insert back into the plastic).
They also said I installed the two part thrust plug properly.
Posted on Aug 26, 2009
canbruce75
  • 1776 Answers
SOURCE: lid switch on a 20802 kenmore washer
Check the video at the following link and see if it is of assistance to you in changing out the lid switch. Sure hope so and best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Posted on Sep 25, 2009
  • 27 Answers
SOURCE: I HAVE A KENMORE 90 SERIES WASHER JUST REPLACED
it mounts to the metal where the lid closes, not on the drum... there's usually two holes where the screws go through... and a third hole where the actuator(plastic post) on the lid goes through to activate the lid switch...
Posted on Sep 26, 2009
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
How to remove washer lid to replace lid lock
Remove power to the unit.
Locate the console and remove two phillips head screws. Most
models have them in the front, bottom of the console. In some of the newer models they are located in the back, bottom of the console. Some washers require you to remove two end caps on the console to access the screws.
After you remove the two screws, slide the console slightly forward and then up. The console will then hinge to the back of the washer.
With the console now hinged back, locate the lid switch harness.
Disconnect the harness and check for resistance between the 2 grey wires (outside) on the lid switch connector connected to top of washer. With the lid down the circuit should read no resistance. If the circuit is open(infinite resistance) then the switch needs to be replaced. You can also use a insulated jumper on the lid switch harness to determine if its the switch.
To replace the lid switch you will now have to remove the cabinet. Use a flat head screwdriver to remove the two clips holding the back of the washer to the outer shell of the washer.
Disconnect the lid switch harness(If not still disconnected).
You can now pull the outer shell away from the washer. Do this by
grasping the outer shell (I open the lid and grab it there.) and tilt the shell forward (toward you) and out. The shell is now removed and you can see the tub. Be careful not to bend the outside walls of the shell when removing and setting aside. This will help greatly when reinstalling the shell. Remove the 2 screws attaching switch to cabinet. Remove the screw connecting the ground on the cabinet. Use a flat blade screwdriver to push tabs on lid switch connector block to remove. Finally remove the whole harness from the 2 remaining retainer clips under the cabinet. Install new lid switch harness assembly and reassemble washer.
Apr 09, 2014 | Washing Machines
Top Loader stopped during spin cycle and now won't work
The lid switch cuts off power to the washer and will cause the washer to stop and not to start at all when it fails or when the lid switch strike breaks. Check the lid switch strike located on the middle right side of the lid. Replace the lids witch strike if it is broken with part number 3950298.
Push and hold the lid switch, using a screwdriver, through the hole on the right side recess of the top cover and start the washer. The lid switch actually clicks when activated.
Check the continuity of the lid switch when activated if the washer still doesn't start when the lid switch is pushed and held. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Remove the screws at the front bottom corners of the console then slightly pull the console forward to clear the console tabs from the slots on the cabinet, and then flip the console to the rear of the washer.
Disconnect the wiring harness connecting the timer to the lid switch wiring harness connector on the cabinet then using an ohmmeter, check the continuity of the lid switch while it is being pushed. Set the ohmmeter to XR1 then touch the test leads to the right and left terminals of the lid switch connector. Replace the lid switch when the resistance reads open.
Apr 06, 2010 | Washing Machines
there is a screw right on the edge of where the clothes go in the washer on the right side,remove the top cover ans unplug lid switch harness, remove lid switch and then replace lid switch and reverse the procedure
Oct 28, 2009 | Sport & Outdoor - Others
Lid switch on a 20802 kenmore washer
Sep 25, 2009 | Kenmore 24032\24036 Top Load Washer
Need to replace Lid Switch for Maytag Atlantis 2002 Washer
Hello, I can help you.
Let me explain to you how the Maytag washer lid switch works.
The lid switch is located on the controls panel, and is activated by opening and closing the washer door. The purpose of the lid switch is to prevent the washer from working with the door open.
It is a safety device to prevent the user from sticking their hands inside of the washer while the washer is agitating or spinning.
When the washer lid switch stops working, the result could be that the washer won't wash, drain, spin and in some cases the washer will not work at all.
You will need a multimeter to check the internal contacts on the washer lid switch.
You will also need to use the wiring schematic to see what contact should be close when the lid switch supposed to be on.
You will need to remember that the Maytag washer lid switch is one of the first parts that you will need to check, when the washer don't want to start filling, agitating, draining or spinning.
Jun 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
MY WASHER IS FULL OF WATER BUT WILL NOT START CYCLE. POWER IS ON TO THE WASHER
Need to replace your lid switch.
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Dec 18, 2008 | Whirlpool GSW9800PW Washer
DOES NOT TURN ON
need to replace lid switch.
Question about whirlpool catalyst 27" washer
F3 means lid switch failure. Heres what the service manual for your washer says about the failure.
Flashes if the lid is NOT opened after the cycle was completed. The
electronic control board must detect that PAUSE/CANCEL was
pressed during a cycle or the lid was opened at least once at the end
of any cycle. This is continually tested to ensure proper lid switch
operation. If “F 3” is flashing, check continuity of the lid switch.
• With the lid closed, lid switch contacts should be closed.
• With the lid open, lid switch contacts should be open.
• If the lid switch has failed, replace it.
• If the lid switch is good, replace the electronic control board.
Apr 05, 2008 | Washing Machines
Kenmore 20172 Top Load Washer Logo
23 people viewed this question
Sal De
fordexpert
Robert Rankin
