Question about Canon EOS 400D / Rebel XTi Digital Camera
Internal flash pops up all the time - Canon EOS 400D / Rebel XTi Digital Camera
    Top Expert:
  • Canon Master
  • 6,702 Answers
Is your camera always in the auto mode? Try to put the main dial to P. Your camera is almost automatic, but won't use the flash, unless you put it up yourself.
If your flash pops up, even when the camera is of, you have a mechanical problem. Something broke off.
Posted on Feb 16, 2014
Testimonial: "Thanks It only occurs when i press the shutter when in auto. In other modes it seems to function normally."
The internal flash on my canon eos 60d camera won't pop up
On the hot shoe when you fit a flashgun it pushes two tabs down to disengage the pop-up flash some times the tabs don't fully return after flashgun removal
Jan 17, 2016 | Canon EOS 60D Digital Camera
Canon 60d internal flash
  • is your settings set to manual ? if you are set to manual mode and the flash does not pop out try pressing the flash button located near the EOS 60d label
  • if the flash won't pop out after pressing the button try to follow the steps on this you tube link
How to fix the This menu cannot be displayed External flash is attached...
Aug 17, 2014 | Canon EOS 60D Digital Camera
I have conon 60D it is brand new that i have often used but pop up flash does not work after using external flash also I do not have flash indicator light on. inside light meter in the build in flash...
The problem is under the hotshoe plate. There are extremely small hols where the sensor for the internal flash are positioned. These sensors tell the camera when an external flash or some other accessory is mounted on the camera and not to open the internal flash. What happens is because the alignment of these hols is so precise and critical any amount of movement or minute partial of dirt can upset or stick these sensors.
What has happened is that when you removed your external flash the sensors did not reset because of dirt or misalignment so show the setting as if the external flash is still mounted and that's why the internal flash won't pop up.
How to fix it, well for a repair person it may be a simple fix by slightly loosening the hotshoe and cleaning the dirt from under it and realignment. It'll work again until it gets dirt in there again or misaligned. This is one area that Canon shouldn't have been so precise.
I'm not suggesting you do this but when I had the same thing happen to one of my field cameras I took a hard plastic coffee cup and lightly started tapping on the edges of the hot shoe. After a few light taps around the shoe I the internal flash popped up. Once I finished my shoot I sent the camera to Canon to have the problem repaired properly. Repair and shipping to a Canon facility cost me $65.00 Canadian.
Apr 05, 2011 | Cameras
I bought my new canon eos 60D..i put on external flsah to use..then after i take off the external flash, my camera's built in flash cannot pop up to take flash even i had press the flash button. How?
Hi, What external flash did you use on your Canon 60D? The internal flash will not automatically pop up if in the "Creative Zone" it will pop up with the button in the creative zones (M, AV, TV and P) it will not pop up with the button if you are in the the full auto mode (that's the little green box mode) but, should pop up automatically if required. The flash should pop up automatically in the basic zone for Portrait, close up and night photography, the button won't activate (pop up) the flash. Also the internal flash will not pop up if there is an accessory in the hot shoe. Again what external flash was it you used and did it flash?
Jan 27, 2011 | Canon EOS 60D Digital Camera
My Canon 60D's internal flash will not pop up after removing my speedlite 430EX II. Carl
I encountered this same issue on new 60D. There is a micro switch under a guide blade in the shoe on the right side. Mine was not stuck down but bent just enough downward that the switch was being actuated. I used a pointed pocket knife blade to pry up on the guide blade making it arch slightly upward and everything is fine now. Now i wonder is this going to be a problem every time i mount and unmount my external flash. Time will tell.
Dec 17, 2010 | Canon EOS 60D Digital Camera
Internal flash not working on olympus e500
The Xenon flash tube in modern strobes rarely 'burns out'. I would guess that a switch that is activated when the flash pops up is not working properly. More info can be found here: http://forums.steves-digicams.com/olympus-dslr/159660-e-500-built-flash-not-working.html
Dec 08, 2009 | Olympus EVOLT E-500 Digital Camera
D70 internal flash not firing
Check if something is preventing the flash to pop up 'fully'. Check for some dust or other particles trapped between the flash and the body. Does the screen say 'Subject is too dark'? If so, the flash has not popped up fully.
Nov 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Flash bulb has gone and onboard flash wont catch the clip
First, some clarity:
What do you mean by "flash bulb has gone"? Is the internal flash not working any more?
What do you mean by "onboard flash won't catch"? Do you mean that the internal (pop-up) flash doesn't work?
Is it possible that you have the flash turned off completely?
Dec 18, 2007 | Nikon D70s Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
43 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
