Question about Dryers
Need to replace belt on drum on a maytag dryer but there is no model number on door how can I get the right part.
yalmer
  • 549 Answers
SOURCE: How to replace drum belt.
Opening the cabinet and removing the drum of GE dryer models
Note:
Disconnect the power source to your dryer before you begin to remove the drum. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself. Reach inside and release the belt tension by removing the belt from the motor pinion.
Older GE dryer models have a small drum bearing inspection plate in the center of the back of the dryer. This drum bearing inspection plate provides access to the dryer's circlip (also known as an e-ring). This clip holds the rear drum shaft in place. Newer models do not have this circlip or the drum bearing inspection plate.
If yours is an older GE model with an inspection plate, remove the plate now. It will be held in place with a single screw. With the plate removed, you will be able to see the drum support shaft and the e-ring (circlip) holding the shaft in place. Use a small screwdriver to remove the e-ring. You may also want to use a magnet to keep the circlip from falling into the dryer. You will also find several metal and nylon shims between the bearing and the e-ring, inside the bearing, and between the bearing and the drum. Take careful note of how they come off so that you will be able to put them back on again in the right order.
Now remove the front panel of the dryer. There are a couple of different ways this is accomplished. Whichever method you use is dependent upon your model. Some older models have two spring catch clips under the cabinet top, one on the left side, and one on the right side of the front. Use a putty knife, or some other flat and thin object to wedge in under the cabinet top. Release both spring catches and lift the cabinet top off the dryer. In some newer models, there will be screws joining the cabinet front panel to the cabinet top. You will have to open the door in order to find these screws. Once they are found, remove them and then slide the cabinet top forward and lift it off the unit.
Next, there are two screws located in the bottom of the front panel, one in each corner. Loosen these, but do not remove them just yet. Locate and remove the two screws at the top inside of the dryer's front panel. Again, there is one screw in each corner. Proceed to remove the other two screws you have just loosened. Disconnect the door switch wires and then lift the front panel off your dryer. With the front panel removed, lift the drum and slide it out of the dryer.
NOTE: In some models, you will have to remove the dryer drum glides before you can remove the drum. Also, now that the interior of your dryer is completely exposed, it might be a good time to vacuum out all of the dust and lint that has built up in there.
Posted on Feb 05, 2008
captaynkyrk
  • 170 Answers
SOURCE: dryer belt replacement
remove the front panel. you may need to remove a kick panel below the front panel. the top panel connects to the front panel by some plastic push in retainers (you can loosen them with a screwdriver) You need to prop the top panel up. the belt goes over the top of the drum down to a drive wheel that is located at the bottom of the dryer.
Posted on Jul 07, 2008
CMV9
  • 594 Answers
SOURCE: We have a maytag neptune
i would replace the belt usually over time the belt streaches due to the weight of the clothes. the screaching ou are hearing is probably the belt going aound the drum instead of turning the drum.
Posted on Aug 16, 2008
ngfam1
  • 639 Answers
SOURCE: Belt replacement for a Maytag dryer - Model No. DE410
Peace Friend,
ngfam1 At your service!
There are many variables!
Every year thousands of people die trying to repair electrical appliances them selves!
You are worth more than that!
Bless you!
Only a trained laundry tech can make the electronic diagnoses.
Below I referred you to a great service nation wide!
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505 near me they only charge $75 service call which is reasonable in today s market!
Unfortunely, another point to consider!!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF*****
Posted on Sep 02, 2008
aborcass
  • 2651 Answers
SOURCE: Need to replace the screws that holds the drum baffle in place
remove the scresw holding the door on, remove the door, the remove the 2 screws oppisite th edoor inge and the front panel will lift off. there will be 2 5/16 screws holding the top down to the frame of unit, the top will then lift up[ giving you acces to the outside of the drum to resecure the drum baffle
Posted on Nov 21, 2008
Maytag model no: de410 Looking for manual
I need the 6 digit model number from your dryer.
May 28, 2008 | Dryers
I have a maytag dryer model # mde308dayw. How do you access the heating element to replace it?
remove 2 screws on the front cover by the floor lift bottom of front cover outward toward you and remove ,then undo wires at door switch,then remove drum belt and drum,then the heater element is at the right side near the base in a duct assembly
May 04, 2011 | Maytag MDE308DAYW Electric Dryer
Maytag gas dryer broken tumber belt. how do i replace it myself? the tumbler doesn't turn, the belt thah goes around it is broken. i need to put a new belt on.
Each dryer is made differently on how to access the drum (tumbler) and belt replacement. If you can provide a model #, that would be very helpful. On most dryers the model# is located on the door frame usually to the left when you open the door. This will get you started in the right direction.
Mr Tin Man
Dec 19, 2010 | Maytag Dryers
My maytag dryer makes a loud noise when on. It sounds like a belt. Can I fix it and how? It's an older model, I don't know where the model number would be. It's loudest when first turned on. Thankyou
To remove the belt go the the rear of the dryer and remove the two or four screws holding the inspection door near the bottom corner of the dryer.Remove this small door. Unplug the dryer. Look inside and see how the old belt is positioned on the pulleys. Releive the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go the the front of the dryer and remove the two screws holding the front panel on. Tilt the dryer front forward and remove. Mark and remove the two door switch wires and move the front panel out of the way. Undo the four screws holding the drum support from the front of the dryer and remove. Grab the drum and sllide it forward out of the dryer.
Vaccum the inside of the dryer and inspect to make sure the rollers move freely. If they don't move freely or show wear, replace rollers and lubricate with light oil. Replace belt.
Put belt over drum. Reinstall the drum into the dryer. On some of the older dryers there were teflon drum gliders located inside the front drum support. Inspect glides and replace if needed.
Reinstall the front drum support and four screws. Reinstall the front panel with two screws.
Replace door switch wires.
Lift the top and make sure the belt is positioned on the drum where the old belt was.
Go the rear of the dryer and pinch the belt sliding threw the belt tentioner under the pulley and over the belt pulley.
Reinstall the rear door with all the screws.
Faster the top down and plug the dryer in and test.
Your done.
Jan 03, 2010 | Maytag PYE2300AY Electric Dryer
Maytag gas dryer. Belt broken. How do I open and replace it?
On the right front and left front of the panel there are 2 phillips head screws. They are about 4 inches up from the floor. Remove these 2 screws,lift the door panel out then down to dislodge the top clips. Remove the door switch wires and set the door aside. Remove 4 screws from the front drum support. @ on the right,2 on the left. Remove the drum support.Install the belt around the drum. The smooth side of the belt goes against the drum. Re-attach all the parts in front. Remove the belt access panel on the rear of the dryer on the bottom right side facing the dryer to arrange the belt around the motor pulley and tension roller.
Aug 21, 2009 | Maytag Dryers
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
Install dryer belt
more information needed to specifcally match the model
however dryers are all similar so
generically, UNPLUG dryer
A:top mounted lint filter (kenmore maytag(New))
  • remove lint filter
  • remove screws in lint filter housing
  • with putty knife or other flat blade depress lock tabs at front corners of top body panel
  • tilt top panel up
  • remove screws 1/3 way down each side, remove door switch wires
  • remove front panel set aside
B:dryers with screws at bottom of front panel (maytag speedqueen)
  • remove screws from bottom of front panel
All
  • pull drum forward & out
  • examine drum felts, rollers, and slides for wear replace if worn
  • wrap new belt round drum at old wear marks
  • insert drum
  • wrap belt round motor pully
  • pull tensioner pulley hard to end of travel against spring
  • wrap belt round tensioner pulley
  • release tensioner
reassemble
Oct 19, 2008 | GE Dryers
Dryers Logo
11 people viewed this question
Top Dryers Experts
