Question about Frigidaire Kenmore Washer Tub to Pump Hose 134455900
KENMORE 60514 Garbage - Frigidaire Kenmore Washer Tub to Pump Hose 134455900
Need to replace kenmore 1/2 hp garbage disposer 60505. Would like install to be easy. What new model replaces the old 60505?
Hey,
Here's the info:
Kenmore 1/2 hp Garbage Disposal Model# 72433 Reg Price: $99.00
Savings: $19.12
$79.88
Source: http://www.kenmore.com/kenmore-1-2-hp-garbage-disposal/p-02206011000P
Dec 28, 2014 | Electrical Supplies
Kenmore 3/4 hp garbage disposer does not work, it only hums.
Do not turn on... humming sound will overheat motor
See if cutter disc located inside disposal can be moved and rotated using broom stick:
If disc rotates freely, then try motor again... if still hums, then replace disposal
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene h
Mar 25, 2014 | Kenmore 3/4 hp Food Waste Disposer
Our new kenmore garbage disposal shoots the water up rather than sucking it down
Check the drain is not clogged.
Does sink opening have splash guard?
Check that plumbing is vented as required by code:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#slow
Gene h
Mar 23, 2014 | Kenmore 3/4 hp Food Waste Disposer
Need to replace water filter on ge side by side gss25jeta bb model and need to know what type of filter to replace it with.
Pull the old one out and see what it is. Check you owners manual for proper replacement instructions. If you do not have and owners manual copy and paste the below URL into your address bar.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60514-2.pdf
May 31, 2011 | Refrigerators
Frigidaire Kenmore Washer Tub to Pump Hose 134455900 Logo
47 people viewed this question
Top Kenmore Vehicle Parts & Accessories Experts
Tom Chichester
syspro
ericschnidri
ericschnidri
Level 1 Expert
Are you a Kenmore Vehicle Part and Accessory Expert? Answer questions, earn points and help others
