Question about Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed
The pump will rum on first stage but is tripping power on second speed
    Scholar:
  • 94 Answers
Hi Martin, Thanks for the question. It sounds as though the pump relay or the pump itself is fried. I would recommend calling a service technician. If you know how to check voltage yourself, use a multimeter or (fluke meter) to test the voltage between the pump relay. if that reads normal then test the pump itself. It could be the difference between buying a new pump, or a new spa pack. I hope this helps, Thanks again!
Posted on Feb 18, 2014
I have a DSZC16 manual indicates 2 stage compressor does that mean it increases speed when needed?
2 or 3 stage compressors normally run at a constant speed
the stages are from different size pistons
1st stage is a large piston for low pressures that feed to a second smaller piston for higher pressures and for 3 stage to an even smaller piston to get really high pressures
for example 1st stage =100psi
2nd stage =1500psi
3rdstage =3000psi
your manual should explain the set pressure for the compressor if the compressor speeds up , that is a two speed unit
Sep 12, 2017 | Air Tools & Compressors
2009 GSXR600 ignition powers up starter turns will not start
Do you hear the fuel pump rum for approximately 3 seconds when turning the key to on position and right handleswitch in the run position. If not research the vehicle down sensor also known as the tip over sensor as well as the fuel pump relay. These are the most common problems with no start situations as you describe.
Oct 18, 2014 | 2009 Suzuki GSXR600
Just replaced a Aqua Flo motor because the second stage of the two speed pump would not come on. Unfortunately the same thing is happening with the new pump. I can here a clicking noise, but it won't...
How is the pump being actuated to go from low speed to high speed?
If it is an air switch the relay may have gone out. This is in a switch box and not related to the motor.
Dec 12, 2013 | Pool & Spa
Power trips out when jets are switched on
I'm going on somewhat limited information here not knowing if the tub is newly installed or if this is a spa that has been working in the past and just started doing this. It would be helpful to know if this is a recently installed pump as well. That said here are a few things to check.
If it's a new install: Your electrician has more than likely wired the spa incorrectly. Be sure that the spa pack has 220V going into the pack and that the GFCI is wired correctly.
If it's an old spa with a new problem: A lot of times a bad heater element can cause a spa to trip the breaker. If you have a bad element the spa will operate normally for about a minute when you turn the power on, then trip the breaker as soon as the heater kicks in.
If it only trips the breaker when the pump is turned on to high speed, more than likely there is a problem with the wiring of the pump or the relay on the pump itself.
May 04, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I have a 919.167780 2 Stage Twin V Portable
two different problems here! first when it trips the breaker and you try to reset the breaker and not turn off the compressor on its pressure switch it does not unload the air off the head of the pump when you try to start it again,,, ( when it shuts off normally you hear the air drain near the switch,, this unloads the pump to restart)
The most likely reason it is tripping the breaker is that the second stage (smaller cylinder) is not doing the work it needs to do and the first stage (bigger cylinder) is pumping more now!,,,, higher pressure on this side makes the motor work harder.
I would advise rebuilding both sides to get the pump back up to correct running levels it had new.
Feb 25, 2010 | Craftsman Air Tools & Compressors
STV 2118B Chroma trips with bright horizontal line and power supply switches off. What may be the reason?
the verticle stage is fault, causing the power supply to trip.
check the ic of the verticle stage
the amplifier of the verticle stage not working.
Dec 31, 2009 | Televison & Video
Is the Bryant 661CJ030-A heat pump single- or multi-stage?
Single stage heat pump. But you must have a two stage tstat for backup electric heat. You single stage cool two stage heat. The second stage brings on the electric heat in case the heat pump can not keep up. Wiring goes r y w1 on most heat pump tstats are switchover valve or o terminal. W2 second stage heat or emergency heat. g is fan c is common terminal.Rus
Nov 11, 2009 | Bryant 463AAC008BA Air Conditioner
High speed spa pump shuts off
Pump speed Selector Switch Contact Probably Missing, Checkout
Feb 01, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed  Logo
Top Aqua Flo Pool & Spa Experts
Ian Kime
Ian Kime
Bill Jordan
Jay Finke
Jay Finke
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
