Question about HP Pavilion Computers & Internet
I need Tp replace case and motherboard - Pavilion HP Computers & Internet
  • 127 Answers
Just Buy It !
Posted on Feb 18, 2014
I have a Hiteker TL50Z10AH-TP. The picture is dark on half of screen. Could you tell me what is causing this issue, and if there is anything I can do to fix this
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 11, 2016 | Hiteker ESI TL50Z10AH-TP 50 Class LCD HDTV...
Need to find part number for motherboard replacement on a Lenovo Edge 15 301DCU
You need contact Lenovo or download the advanced user manual from Lenovo's website for your specific model. These types of information are usually mentioned on the motherboard itself.
Regards
David
Sep 17, 2013 | Lenovo TP EDGE 15W CI324 1564GB 320GB DVDR...
Need to reset tp factor settings for my acer pc
remove the power from CPU then remove the side covers in the motherboard near the c mos battery you will see a three pin jumper with 2 pin shorted remove them and insert the jumper to the 2 and 3 pin then switch on the computer in some case the computer doesn't work switch off and remove the power and replace the jumper to early position and connect the power and restart the computer this will reset the system to default
Oct 27, 2011 | Acer Computers & Internet
Hi. I am a novice so my question could sound quite dumb. Can you recommend an internal modem that I can plug into the motherboard to accept a wireless internet connection or is there one already on the...
I think you want your desktop computer to be able to "grab" an existing wireless Internet connection, right? In that case, what you need is not an internal modem, but a "PCI Wireless Adapter". It's just a typical card that goes inside the computer, but instead of ports, has an antenna. Check Newegg.com for "PCI Wireless Adapter", and you'll find several of them. TP-Link, Asus and Netgear are good options.
Feb 11, 2011 | Gigabyte GA-8ST800 Motherboard
WATER IS DRIPPING FROM THE OUTLET VELVE LOCATED ON TOP WATER HEATER.
That sounds like the TP valve is leaking.
http://waterheatertimer.org/Water-heater-leaking.html
1) Leaking TP valve can be caused by defective TP valve
How to replace TP valve:
http://waterheatertimer.org/How-to-replace-TP-valve.html
2) TP valve can also be caused by overheated tank.
Turn down thermostat.
Install expansion tank on incoming cold water line.
Electric heater: thermostat or element may be bad and tank needs troubleshooting
Gas heater: thermostat is connected to gas valve and gas valve may need replacement.
3) First step is replace TP valve and see if that solves problem.
4) Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on water heater.
Jan 03, 2011 | General Electric Water Heaters
Relief valve on my water heater is dripping.Can I fix this?
There are two solutions:
1) Replace TP valve with same temperature/pressure as existing TP valve.
Buy the TP valve at hardware store or home center or plumbing supply.
Turn off water heater so water cools.
Hot water inside a tank is explosive ... so open the TP valve and test water temperature.
If TP is on top of tank, you don't need to drain much water before unscrewing
If TP is on side of tank, use the TP valve to drain water -or- use the drain valve
Unscrew TP to remove.
Put teflon tape on new valve threads so it will seal against leak.
2) If the new TP replacement starts doing the same thing, there may be a thermostat problem -or- thermostat is set too high.
If you keep the water temperature set high, you can add expansion tank to incoming cold water line.
Home Depot sells expansion tanks. Plumbing supply carries them,
The tank for residential water heaters is about same diameter as a football and it goes on cold water line.
Oct 31, 2010 | Water Heaters
The pci ethernet card tp-link is crashing the startup process with windows 2000 and damages the boot files
Try and replace the ethernet card or try and start it up without the ethernet card present. If it works you know its sucessful then the Card is faulty
Jun 08, 2010 | A-Trend ATC 6220 Motherboard
I forgot my tp link router paswor
You will find a very small hole on the back of it. Straighten out a paper clip and hold it in for 5 secs with power on. This will reset it back to factory defaults. Cheers from Scott
May 19, 2010 | Intel D945GCNL Motherboard
My dell inspiron 1521 mousepad has stopped working, any suggestions on how to repair it would be appreciated
in BIOS, check if the touch pad isn't disabled (may be called internal pointing device). if this is enabled, the TP is almost certainly broken and needs to be replaced. in few cases, the flat cable connecting the TP may have come loose. any way, the laptop should be at least partially disassembled for repair.
Oct 12, 2009 | Dell Inspiron 1521 Notebook
Need Last Drivers
Your drivers will be at www.viaarena.com. For your board and windos XP, I would Suggest:
Chipset/AGP/IDE driver: ht tp://www.viaarena.com/Driver/VIA_4in1_443v.zip
Audio Driver: ht tp://www.viaarena.com/Driver/vinyl_v700b.zip
Dec 17, 2007 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
